Old June 2nd, 2009, 11:00 AM   #1
RaceBikeRentals
Pimpin
RaceBikeRentals's Avatar
Motorcycle(s): Bunch of em
Affordable rear shock? We got em
Just added the Elka 2 way adjustable rear shock to the store. Customer made for your weight & riding style. I have one on order for my personal race bike. Killer price!
http://store.racebikerentals.com/mer...Category_Code=
-Richard
MotoList.com <<<List your stuff!
RaceBikeRentals is offline   Reply With Quote
Old June 2nd, 2009, 11:04 AM   #2
any modifications needed to bolt it up to a stock bike?
how's it compare to that other unit you tried? what improvements does it make over the stock shock?
2 way??? ... compression and preload adjustment?
Old June 2nd, 2009, 11:11 AM   #3
RaceBikeRentals
Pimpin
Bolts right up to stock shock mounting positions. I haven't tried one yet. I have one on order & should have it for the next Willow Springs round in a few weeks.
Preload and compression/rebound are adjustable.
Mounting is very easy. Just put the bike on the rear stand. Have a floor jack handy to place under the dogbones to un-weight the suspension just a bit. Top and bottom bolts are easy to remove. I can change my shock in about 10 minutes
-Richard
Old June 2nd, 2009, 11:28 AM   #4
camaroz1985
camaroz1985's Avatar
Motorcycle(s): 2008 WR250R, 2006 Ural Raven (Sold), 2009 Versys Green (Sold), 2008 Ninja 250R Green (Sold)
Wow very nice. You keep adding all these nice parts to your store. Makes me think I need another bike to turn into a race bike.
camaroz1985 is offline   Reply With Quote
Old June 2nd, 2009, 12:29 PM   #5
Broom
Track Junkie
Broom's Avatar
Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike
cool... let us know what you think.
what are you running now?
Las Escobas -- Track Bikes Save Lives
JonBroom.com
Broom is offline   Reply With Quote
Old June 2nd, 2009, 12:34 PM   #6
RaceBikeRentals
Pimpin
Running a Works Performance currently. Its a good shock, but would like to try something different for comparison purposes.
-Richard
Old June 2nd, 2009, 12:38 PM   #7
Broom
Track Junkie
Broom's Avatar
double clicker?
it kinda sucks that we totally setup my bike before i even really rode it. we've got all the trick stuff on there, but i have nothing to compare it to. we're running the penske triple clicker, which is probably overkill, but i really couldn't tell you if its any better than something else.... all i know is that when the bike isn't doing exactly what i want, i tell my tuner and he twists some knobs and sends me back out... its a wonderful thing but doesn't give me any comparisons....
JonBroom.com
Old June 2nd, 2009, 03:27 PM   #8
RaceBikeRentals
Pimpin
Double clicker.... yeah, good to know what the baseline is. You could probably go back to stock in an hour or so and see for yourself.
-Richard
Old June 2nd, 2009, 03:33 PM   #9
Broom
Track Junkie
Broom's Avatar
Sold the stocker
Posted via Mobile Device
Old June 3rd, 2009, 09:24 AM   #10
RaceBikeRentals
Pimpin
Added the 3-way model to the store. Check those prices! Same quality as Ohlins for $100 less. MUCH cheaper than Penske.
-Richard
Last futzed with by RaceBikeRentals; June 3rd, 2009 at 01:30 PM.
Old June 3rd, 2009, 09:40 AM   #11
Daeldren
two wheel addict
Daeldren's Avatar
Motorcycle(s): 94 xlh 883, 1984 kawi gpz money pit
weighing only 120 lbs I'm wondering if a aftermarket shock would be worth the money for me since I barely weigh down the stock suspension. It would be nice to be able to adjust the dampening though. On another note, Im wondering if anyone is going to come out with a set of fully adjustable forks for 250 racing applications (that would be an expensive mod but it would be awesome.)
Daeldren is offline   Reply With Quote
Old June 3rd, 2009, 11:52 AM   #12
Broom
Track Junkie
Broom's Avatar
i'd only buy an aftermarket shock if you were going to race or maybe if you're a serious track junkie. a properly setup shock is amazing, but probably not necessary for riding around the streets.
at this price point though, i'm sure it wouldn't hurt! the problem is knowing how to set it up.... it takes a little magic and its highly recommended that you get a professional to help you dial it in.
JonBroom.com
Old June 3rd, 2009, 01:32 PM   #13
RaceBikeRentals
Pimpin
Lot of truth there, however..... if you're a serious street rider with access to a lot of twisties, you might be seeing cupped rear tire wear. A rear shock will give you much more confidence and properly setup, should make your rear tire wear evenly.
-Richard
Old June 3rd, 2009, 01:59 PM   #14
paterick4o8
paterick4o8's Avatar
Motorcycle(s): '08 blue 250R [sold]. '09 lime ZX-6R [stolen :( ]. '06 blue 636.
hmm so maybe this will make sense for me to upgrade? not just for tire wear but.. there are a good amount of twisties up here and I ride pretty much every week. sometimes when I hit a slight dip in a turn, I bounce up from my seat a bit. I'm guessing adjusting the preload isn't really going to make a difference to help prevent this? it's starting to get annoying not to mention makes me less confident to go fast on some turns with slight dips
paterick4o8 is offline   Reply With Quote
Old June 3rd, 2009, 02:11 PM   #15
Broom
Track Junkie
Broom's Avatar
i'm not sure what adjustments help what handling problems, but i do know i can tell my tuner "that bump in turn three is kicking my tires up off the pavement and scares the hell out of me" and he turns some knobs... before i know it that bump is a non issue.
JonBroom.com
Old June 3rd, 2009, 03:11 PM   #16
Buffalony
Buffalony's Avatar
Broom. Heres a good vid on suspension basics. Hope it'll help you communicate with ur tuner in some way.
http://www.onthethrottle.com/content/view/73/40/
Theres other good vids on that site too.
Gixxer rear shock question - rear stiffness too high cookiebug79 2008 - 2012 Ninja 250R Tech Talk 20 January 17th, 2015 08:19 AM
Rear shock set to high (rear wheel slipping)? passive101 2008 - 2012 Ninja 250R Tech Talk 6 August 10th, 2014 08:45 PM
For sale: 2003 ninja 250 rear brake pedal and rear shock ReDnEcK Motorcycle-related 0 October 6th, 2010 12:02 PM
Replacing my rear shock with a newgen rear shock... ReDnEcK 2008 - 2012 Ninja 250R Tech Talk 4 September 10th, 2010 12:38 PM
Good/Affordable Rear Stand?? Jiu Jitsu Player 2008 - 2012 Ninja 250R Tech Talk 27 April 14th, 2009 11:49 PM
