August 10th, 2013, 07:21 PM | #1 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
Gear Review: Earplugs - EP7 Sonic Defenders® Ultra
I originally started using Sonic Defenders EP4s (http://www.surefire.com/ep4-sonic-defenders-plus.html) when I went shooting. They worked great and I started using them for riding.
I found when I rode with them that the rubber flange would start to irritate the inside of my ears. I switched to the cheap disposable foam ones but for some reason I'm too much of a moron/lack the dexterity to use them. If they are brand new I can get them in quickly but if I've used them once and taken them out it takes me forever to get them back in. Or the worst scenario is when I think they're in, I put on my helmet, I put on my gloves, I start riding, and I realize that the earplug in one ear is only partially in and I'm starting to go deaf in that ear. I was looking for non-disposable earplugs when I came across these - http://www.surefire.com/ep7-sonic-defenders-ultra.html The Sonic Defender ep7s. Its the same design as the 4 but uses a disposable foam core instead of the flange. The advantage is that the disposable foam core doesn't irritate the inside of my ear canal (I just went on an 8 hour ride and my ears feel fine) and it's really easy to jam the foam into the ear canal because the foam surrounds a hard plastic cylinder. It's a win-win but the are a little pricey as far as earplugs go. So if you use earplugs and you have trouble using the foam ones these are a great solution. PS. This review might not be applicable to anyone as I realize I may be the only person that can't insert the disposable earplugs in their ears in less than 3 seconds. |
August 10th, 2013, 09:15 PM | #2 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Great review! I hate that rubbery plastic in my ears, foamy stuff is a lot more comfortable.
August 10th, 2013, 09:22 PM | #3 |
$19.95 is not bad for a comfortable pair of ear plugs.
August 10th, 2013, 09:40 PM | #4 |
Join Date: May 2011 Motorcycle(s): 2006 GSXR 750; 1983 CB750SC Posts: 277
Are those the best models for motorcycle riding? I watched the video and they rifled through a multitude of different styles for a plethora of different applications.
August 10th, 2013, 11:25 PM | #5 |
not an actual panda
I don't know if they are the best overall. They work the best (most comfortable, easy to use, block sound) for me.
Gear blog! (Review of gear) | Upnorthmotoblogger | Motorcycle Gear | 16 | April 6th, 2015 06:22 PM |
[visordown.com] - Avon 3D Ultra Xtreme tyre review track test | Ninjette Newsbot | Motorcycling News | 0 | November 28th, 2014 09:40 AM |
[visordown.com] - Avon 3D Ultra Xtreme review track test | Ninjette Newsbot | Motorcycling News | 0 | November 28th, 2014 09:23 AM |
[tilted horizons] - Product Review: Auritech earplugs | Ninjette Newsbot | Motorcycling News | 0 | January 14th, 2014 10:00 PM |
[visordown.com] - Used: Hearwave B2 custom earplugs review | Ninjette Newsbot | Motorcycling News | 0 | September 11th, 2013 02:30 PM |
