November 8th, 2021, 10:51 PM | #1 |
Join Date: Oct 2021 Motorcycle(s): 2010 Ninja 250R Posts: 56
Outback Ninja Struggling a little - Similar to Detrailer's
Outback Ninja is getting close to its debut, so I think I need to address this performance issue.
-Bike runs a lot better when hot -Seems to struggle switching between RPM ranges -Doesn't like too much throttle in low RPMs Here is a video of it running: https://youtu.be/iZgC1WUhIco Context of video: -Was ridden around block twice 20 mins before -Petcock not working see https://www.ninjette.org/forums/showthread.php?t=367649 -Have done carb clean -Holes for adjustment were already drilled out when carbs pulled out I would be fine with this but because first gear is high, the low RPMs are needed for the rougher terrain where I need to slow down.
Bringing Ninjas to The Outback! |
November 9th, 2021, 01:45 AM | #2 |
Update: Fixed Petcock, problem remains
November 9th, 2021, 05:50 AM | #3 |
If the carbs are really clean, the stumbling when you slam the throttle open should be able to be corrected by adjusting the idle mixture screws. Have you set them to max idle speed, then a small amount richer?
November 9th, 2021, 08:57 PM | #4 |
No, I will try that. What is the quickest way to pull the carbs out for you? Airbox out of back and carbs as well? I really do not want to damage the hoses...
November 10th, 2021, 05:48 AM | #5 |
Why you ask now about carb removal?
pilot screws require to be adjusted with carbs in place, running, and temp full hot, no?
November 10th, 2021, 04:59 PM | #6 | |
Join Date: Sep 2021 Motorcycle(s): 07 Kawasaki Ninja 250 Posts: 343
https://faq.ninja250.org/wiki/How_do...dle_mixture%3F |
November 10th, 2021, 09:38 PM | #7 |
Yeah, I use these:
Or this is better as you won't burn yourself on hot engine. https://www.dimecitycycles.com/carb-...ting-tool.html |
November 22nd, 2021, 07:06 AM | #8 | |
November 22nd, 2021, 07:06 AM | #9 |
Because I think they will be coming out a lot unfortunately
November 22nd, 2021, 09:43 AM | #10 | |
Join Date: Jul 2013 Motorcycle(s): 2007 SV650S 2005 EX250F Posts: 486
Also, like spooning a tire on a rim, if you're breaking a sweat removing carbs then you're probably doing it wrong. Once you get the airbox loosened up and the boots out, the carbs are a 10-15 minute hassle-free job. It pains me to see so many people ask about pod filters just because they struggle with the factory airbox It's not hard... people just make it hard.
Don't think, look! |
November 22nd, 2021, 09:52 AM | #11 |
Trick to removing and installing carbs in less than 10-minutes is to remove only left manifold boot. This frees up lots of space to slide carbs out. Also leave right manifold boot clamped to head. Makes more room that way without it getting in way.
I've had to remove carbs multiple times at 1st race of season to desperately clean them due to letting it sit over winter. Also optimum jetting requires downsizing main jets during lunch due to hotter weather in afternoon. Without emergency cleaning, that's still 4x in 2-days. No problem at all if you focus on using efficient procedures. |
December 5th, 2021, 11:56 PM | #12 |
Adjusting the Air screws on the ninja sounds to me like what is needed on the video.... their just a tad too lean....
I set mine to what the manual said and regretted it it didn't even want to start ! but after opening up each air screw 1/2 turn it started to run fairly good but you need to watch the tach and turn the air screw and peak the RPM's while adjusting the air screws... I used the smallest slot screw driver tip of my bit-type screw driver and turned it with a long pare of needle nose plyers from under the carbs the left one was easy , the right one was a real P.I.T.A on my bike.... but using a small bit type screw driver tip worked for me after I ground it a small amount on the sides to fit into the hole where the air screws are... .... I added a nut to the bottom of the bit to make it bigger in diameter to turn it easier which helped alot... I just crushed the nut onto the bit with the bench vice. .....good luck ! Bob......
[webbikeworld.com] - REV'IT! Outback 2 Jacket Review | Ninjette Newsbot | Motorcycling News | 0 | July 24th, 2016 04:10 PM |
[motorcyclistonline] - Tested: CruzTools Outback’r M14 Multi-Tool | Ninjette Newsbot | Motorcycling News | 0 | December 17th, 2015 05:10 PM |
Milw WI; seeking Ninja or similar for trade | windingroads | New Members | 7 | February 8th, 2015 07:48 AM |
FL ride to Outback Crab Shack | CC Cowboy | Group Rides and Local Events | 0 | April 1st, 2011 08:45 AM |
[topix.net] - 11 September 2009French outback Australian attack | Ninjette Newsbot | Motorcycling News | 0 | September 13th, 2009 03:32 AM |
