Old August 20th, 2013, 09:20 PM   #1
Chad4434
Motorcycle(s): Kawasaki Ninja 250r
09 Keyless Ignition
Can anyone help me out and tell me how to make a keyless ignition for my 09 kawasaki ninja 250 any help would be appreciated cheers
Chad4434 is offline   Reply With Quote
Old August 20th, 2013, 09:29 PM   #2
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
ummm, use a toggle switch??
who, what, when, why?
Old August 20th, 2013, 09:34 PM   #3
Chad4434
Its a bit more complicated then that, i have to wire in a 100hms resistor i just dont know what wires i have to wire it in to
Old August 20th, 2013, 09:41 PM   #4
Chad4434
And im not having any accessories, no lights or anything
Old August 21st, 2013, 05:17 AM   #5
Aodrn
It's a long boring story
Aodrn's Avatar
Motorcycle(s): 2012 Ninja 250
I'm interested in this for my track bike. I have no useful input though
Aodrn is offline   Reply With Quote
Old August 21st, 2013, 06:21 AM   #6
conrya5
conrya5's Avatar
Motorcycle(s): 2010 Metalic Island Blue Ninja 250r
http://www.ninjette.org/forums/showthread.php?t=35886
conrya5 is offline   Reply With Quote
Old August 21st, 2013, 07:41 AM   #7
Aodrn
Aodrn's Avatar
The diagram is cool, but I'm too dumb to figure out what to hotwire. I have heard the resistor is necessary though. Not sure on what wire either.
Old August 21st, 2013, 09:33 AM   #8
bruce71198
bruce71198's Avatar
Looking at the wiring diagram there is NOT a security circuit that would require a resistor to the igniter. So, put a toggle switch in place of the ignition switch and attach the white wire to one side and the grey wire and brown wire to the other side. I would recomend a 20 amp switch or larger.
Old August 21st, 2013, 09:57 AM   #9
Aodrn
Aodrn's Avatar
So to really dumb this down:
Will the toggle switch have three poles or do I put the grey and brown together and then attach it ?
Electricity is not my strong point if you can't tell.
Old August 21st, 2013, 10:03 AM   #10
conrya5
conrya5's Avatar
Would you be able to use the existing engine kill switch as a toggle switch with modifications?
Old August 21st, 2013, 11:31 AM   #11
bruce71198
bruce71198's Avatar
Buy a 2 position (on/off) switch with 2 poles from Radio Shack, The white wire to one side and the other 2 wires to the remaining terminal. If you have a 3 pole switch the third other pole is probably for a light on the switch. The handle bar switch runs through a relay and wont handle the amp draw of the ignition switch. There are handle bar switches available aftermarket that will work.
Old August 21st, 2013, 11:36 AM   #12
Aodrn
Aodrn's Avatar
Much appreciated
Old August 21st, 2013, 11:36 AM   #13
Lychee
sail away
Lychee's Avatar
If you take off all the lights and place resistors in their place, theoretically you could break a key off in the ignition leaving it in the on position. Then the existing kill switch would be your ignition toggle.
Edit: Might need to remove the 30A main fuse when not in use.
Old August 21st, 2013, 01:41 PM   #14
bruce71198
bruce71198's Avatar
Actually you could just leave all the lights unplugged and remove the 30 amp fuse when not in use.
Old September 20th, 2013, 09:09 PM   #15
bruce71198
bruce71198's Avatar
I must apologize for possibly steering you in the wrong direction. Today I put a 1991 engine in my 2008 race bike. Easy to do if you have a doner bike as you will need the old mounts and bolts. I also have a 1997. So here's what I found. The 1991 does not have a security circuit in the ignition switch. My 97 and 08 do, it's the grey wire coming out of the CDI box and it needs a 100 ohm resistor between it and 12 switched power. Sorry if this caused you any trouble.
Old October 5th, 2016, 04:12 AM   #16
tgold
Motorcycle(s): 2006 1050 Speed Triple, 2010 250 Ninja racebike, YZF320RR? Racebike
MOTM - Nov '15
Save yourself some hassle and use the Woodcraft keyswitch eliminator:
https://www.woodcraft-cfm.com/cgi-bi...on&key=43-0104
I used one of these for my SV650 racebike and they work great. No cutting of wires and the time savings for install is well worth the price IMO.
tgold is offline   Reply With Quote
ninja 250 keyless ignition timone1002 Ninjettes At Speed 18 October 4th, 2016 08:00 PM
DIY Keyless Ignition for 08 250 garth285 2008 - 2012 Ninja 250R Tech Talk 9 July 18th, 2014 01:39 PM
Is there a DIY for keyless ignition? Triple R 2008 - 2012 Ninja 250R Tech Talk 8 June 26th, 2014 02:53 PM
Keyless Gas Cap LittleRedNinjette Items Wanted 7 March 15th, 2013 10:34 AM
Keyless ignition Kevinnolde 2008 - 2012 Ninja 250R Tech Talk 3 September 1st, 2009 08:31 AM
