December 20th, 2008, 04:20 PM | #1 |
7,500 mi. service quote/conversation with dealer service dept.
I just got back from my dealer (just for fun trip), and while I was there decided to pick-up some oil and talk to the service dept. to get a quote for my upcoming 7.5K service. It came out to ~ $410!!!!! CRAP, I knew I needed to put some $$ aside, but that is almost double what I anticipated. At least this includes a valve adjustment. I asked if it cost the same if it didn't need the adjustment, it does cost the same. I think everything is more expensive in CA.
I asked him how much to put on my 15T sprocket. Long story, but I tried all the tricks and can't break the nut off. The good news is he said he would do it for FREE if I brought it in at the same time. I'm planning a re-jet, so I thought I would also ask how much for that too. I was planning to do it myself, but if it was cheap and easy, so much the better. He said for all this work we may be able to work a deal, but I think he said ~$175 for the re-jet. The only thing is I don't think we where on the same page about that. He didn't seem to think it was needed with stock set-up and mentioned it was currently set-up for EPA regs..... which I understand, but I don't care about that. He acknowledged its leanness and said he could make some adjustments, but he didn't say anything about replacing jet or needles, mainly just adjustments. So I don't know if it would be worth it to have him touch it..... I don't know. |
December 20th, 2008, 04:33 PM | #2 |
I'd look for a good independent shop to just inspect the valve clearance and adjust the valves, if needed, and do the rest of the service myself to save money.
Have you looked into toku's DIY on changing the sprockets and how to break the nut loose? |
December 20th, 2008, 04:42 PM | #3 | |
I'll check toku's DIY, but my hunch is I have tried it all. The dealer should have more hands and muscle available.... and my impact wrench is a cheaper one, so their beefy one may make a difference. And if they break it, they are the ones responsible But if he does it for free, there really is no down side at all. I am hoping that after he does it, it should be easier to get the nut off at home if I ever want to put the old sprocket back on. |
December 20th, 2008, 04:55 PM | #4 | |
I'd still try to find an independent. You paid for the warranty, but they get you back through high service costs, as you are finding out. Nothing you can do but keep your warranty in effect, but that doesn't mean a dealer needs to do the work. As for the sprocket, instead of an impact gun, use a socket and a breaker bar if your gun doesn't have enough oomph. Did you try raising the air pressure at the compressor to the max allowed by the gun? If using a socket and breaker bar, put the 2x4 through the wheel as toku suggested, then using your weight on the breaker bar, step on the bar or kick the bar downwards. It should break the nut. It's the shock that will loosen it. Make sure the bike is in neutral to avoid having any of that shock go through your transmission output shaft. You did fully straighten out the locking tab on the sprocket washer before attempting to loosen, correct? |
December 20th, 2008, 05:00 PM | #5 |
I am in the Sacramento area. Actually very near the city with the state prison is (being slightly vague since this is public, but if you are from here you know exactly what I mean).
I tried every trick you mentioned. I was afraid of breaking something and dropping the bike (tried two different "spotters" to help). |
December 20th, 2008, 05:03 PM | #6 |
how long was the breaker bar? if needed, put a section of pipe on the end of the breaker bar to increase leverage.
are you sure you have the washer completely bent flat? |
December 20th, 2008, 05:08 PM | #7 |
My breaker is 2' and I can't remember if I used the pipe.... I may not have if I was afraid of breaking something and my spotter was having trouble holding the bike under pressure (with and without stands). Also didn't want to strip the sides of the nut, it slipped off a couple times.
Yes, the washer was completely bent flat, I triple checked this and then flattened more for good measure. I actually tried getting it off like 3 different times. |
December 20th, 2008, 05:15 PM | #8 | |
To keep it from slipping, as you work the breaker bar down, have a spotter hold the socket at a right angle to the nut to insure you're not applying force at an angle. last thing... lefty loosy, righty tighty! |
December 20th, 2008, 06:03 PM | #9 |
I have lived aboard a sailboat for 14 years. In the saltwater environment it is not uncommon to have 'FROZEN" bolts. There is a product available in aerosol cans called FreeAll. This stuff is incredible and will help break free the most stubborn fastener. It may be worth buying a can of FreeAll for your arsenal.
December 20th, 2008, 09:16 PM | #10 |
The socket is the correct size and of decent quality (duralast - Autozone's nicer line of tools). I did get the deep socket, thinking I would have more faring clearance, but it does increase the risk of slipping. Part of the problem is even with a spotter on the bike, holding the breaks & 2x4 in the wheel spokes, it still felt like everything was flexing.... I also tried WD40 on the nut, haven't tried other products. This thing is stubborn.
December 30th, 2008, 09:28 PM | #11 |
Join Date: Dec 2008 Motorcycle(s): 08 Green 250r Posts: 22
Maybe the it got overtightened, I took mine off over the weekend and took my ratchet and put into my son's hockey stick as leverage and a 2 by 4 on the rear wheel and have no problem taken it off.
January 29th, 2009, 03:51 PM | #12 | |
Join Date: Jan 2009 Motorcycle(s): Black 08 Ninja 250 Posts: 70
I also talked to the guy in davis at Davis Motorsports and he said that service shouldn't be more than $250. I'm gonna go get a quote from him soon. Of course, it isn't a dealer so i dunno how that would help you and your extended warrenty.
2008 Ninja 250 - Yoshi Exhaust, Brake Light Modulator, HID Kit To Come: Sliders, Fender Elim, Flush Mounts, Hugger (much later...no $ ) |
January 29th, 2009, 05:12 PM | #13 |
WOW- that is worth looking into.... only problem is I'll have to coordinate with wife to pick up, but that is a minor thing.
Thanks for the info! |
February 24th, 2012, 02:36 PM | #14 |
February 24th, 2012, 03:39 PM | #15 |
I'm not sure if you were asking me, but this was resolved years ago
I do all my own work now. This saves, and costs me, a ton of $$.
February 25th, 2012, 08:06 AM | #16 |
Russian Ninja :)
Join Date: Oct 2011 Motorcycle(s): 2012 Triumph Street Triple R, 2009 Yamaha FZ6, 2010 Kawi 250r (sold) Posts: 335
I just brought the bike back from having it serviced before the summer.
It was mostly inspecting everything, lubing everything. They added some brake fluid. And also installed fender eliminator for me. I paid $225 for all the labor (I had my own fender kit). I thought it was expensive, since they didnt really do anything (not counting the fender kit), but maybe it was ok.... Not to highjack, but looking for advice thats kind of related. My dealer charges $65 dollars per tire to mount new ones. Is that reasonable?
2009 Fazer (2009 Yamaha FZ6), 2012 Triumph Street Triple R |
February 25th, 2012, 01:04 PM | #17 | |
That's twice what I've heard. I you ride much, thereby needing frequent tire replacements (once a year or less), I highly recommend learning to do it yourself.
February 25th, 2012, 01:40 PM | #18 | |
Russian Ninja :)
Also, on the quote: They charge $35 dollars per tire if I bring just the rims. And $65 if the wheels are on the bike. Maybe thats why it seems twice as expensive? I was planning on bringing the entire bike in. Thanks for your reply though.
February 25th, 2012, 02:54 PM | #19 | |
My advice to you is to read several DIYs from different sources, and watch a handful of youtube videos. This way you understand the procedure, see it done, and eventually can picture yourself doing it.... this worked for me, and I saved a ton of $$. If you are new to riding, it may be prudent to pay the dealer to change your tire the first time, while you get used to riding more, and taking on more basic maintenance of your bike. By the time it is time to change your next tire, you will likely be ready for it. I usually do it by myself, but it is always much easier with a buddy too.
February 25th, 2012, 03:26 PM | #20 |
I just watched the video above (new one for me), and I learn something new every time. I never thought of using the rope on the rim protectors to hold the spoon!
February 25th, 2012, 05:11 PM | #21 |
1/4 English, 3/4 Kick Ass
Join Date: Sep 2011 Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold) Posts: A lot.
My local shops arte quoting me from $260-350 for the 7,500mi servicing/valve adjustment.
I hate the fact it's so expensive, but maybe one of these days I can learn to do it myself. |
February 26th, 2012, 08:56 AM | #22 | |
Russian Ninja :)
May 30th, 2016, 12:10 PM | #23 |
Well, the valves should be inspected at 7500 miles but it's likely they won't need adjustment. Engines todays are built and assembled very, very well.
Do it myself or take it to the dealer? 7500 Mile Service | Sykes92 | 2008 - 2012 Ninja 250R Tech Talk | 14 | November 3rd, 2014 07:19 AM |
Cost for dealer service? | ChaoSS | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 6th, 2014 11:48 PM |
HD Dealer for service? | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 9 | September 10th, 2009 01:30 PM |
600 mile dealer service | NickH | General Motorcycling Discussion | 5 | July 20th, 2009 08:50 PM |
600 Mile Dealer Service? | sm0kediver | 2008 - 2012 Ninja 250R Tech Talk | 12 | March 29th, 2009 11:33 PM |
