May 17th, 2014, 12:52 AM | #1 |
Join Date: May 2014 Motorcycle(s): 1986 Kawasaki Ninja 250r Posts: 4
2007 tank fit
Made the mistake of purchasing a 2007 fuel tank for my '86 EX250.
Of course, when I hauled it over to the bike's location the bolts/frame mounts do not line up. Is there a way around this? The tank is in doable condition with no leaks or rust and I would hate to trash or sell it unless it is impossible to make do. |
May 17th, 2014, 10:05 AM | #2 |
Join Date: Apr 2014 Motorcycle(s): 02 Aprilia RS70 97 Ninja 250 Posts: 53
86 and 07 should be compatible right? You sure you didn't buy an 08 tank?
May 17th, 2014, 10:20 AM | #3 | |
http://m.ebay.com/itm?itemId=331197350703 Biggest problem I am running into is the rear bolt holes on the tank sit at a 45 degree angle (approx) and the frame mounts at flat, as are the original tank bolt holes. |
May 17th, 2014, 10:24 AM | #4 |
That's a pregen tank, pics of your mount holes? Does it fit in the front?
May 17th, 2014, 11:03 AM | #5 |
May 17th, 2014, 11:27 AM | #6 |
'86/'87 are EX250E while '88-'07 are EX250F and '08-'12 are EX250J. There are a lot of differences. The J-bike's tank petcock interferes with the F-bike's frame so I hope there's no similar issue here between the F-tank and the E-frame.
May 17th, 2014, 11:28 AM | #7 |
I'm wondering if someone swapped your rear mount, where the seat fits in. The seat is stock correct?
2007 OEM Silver gas tank and front fender only | Ghostt | Items Wanted | 7 | February 17th, 2017 08:49 AM |
*WANTED* 2007 250EXE Tank bag | seth hall | Items Wanted | 0 | August 21st, 2014 08:12 AM |
WTB: Gas Fuel Tank for a 2007 Ninja 250 (PRE-GEN) | vman1313 | Items Wanted | 1 | October 27th, 2013 02:53 PM |
2007 Tank Hoses Placement? | tgoff | 1986 - 2007 Ninja 250R Tech Talk | 4 | June 7th, 2012 10:37 AM |
