August 12th, 2013, 02:55 PM | #1 |
Join Date: Aug 2012 Motorcycle(s): Ninja 250 2001 Posts: A lot.
Nails in tire
Just saw that I have some tiny nails that have flattened against my rear tire. I've patched car tires with the rubber inserts and glue I was wondering if there is any reason I couldn't do it to my bike tire?
Mods: Offset clutch pressure plate |
August 12th, 2013, 02:58 PM | #2 |
Hmmmm nails as in plural? A pic may be in order here. Yes, people plug their tires from time to time but that is normally for a single hole.
August 12th, 2013, 03:00 PM | #3 |
Internal flat patching is better.
August 12th, 2013, 03:01 PM | #4 |
August 12th, 2013, 03:07 PM | #6 |
Remove tire from wheel
Grind area down on inside of tire Apply glue and patch Allow time to dry Pray you did a good job because they don't like to hold unless it's done well
August 12th, 2013, 03:09 PM | #7 |
Take the tire to a bike or tire shop, they know how to.
The plugs work, but they break internal cords that the little nails didn't.
August 12th, 2013, 03:10 PM | #8 |
Hmm, sounds like a pain. Then to remount the tire and check the balance.
August 12th, 2013, 08:12 PM | #9 |
I told you bro
Join Date: Jun 2012 Motorcycle(s): 1996 Ninja 250r Posts: 680
You take the nails out yet? I had a nail in my tire that was due to be replaced anyways, so when I took it off it turned out to be a very short nail that didn't puncture anything at all.
August 12th, 2013, 08:18 PM | #10 | |
Soapy water is your friend in this case.
August 12th, 2013, 08:24 PM | #11 | |
I told you bro
Yeah, and if that doesn't seem to work check your pressure as well. Should tell you if you have a major leak. |
[visordown.com] - Dakar bikes are tough as nails | Ninjette Newsbot | Motorcycling News | 0 | December 29th, 2014 11:30 AM |
Nails, nails, and more nails... | headshrink | General Motorcycling Discussion | 13 | March 13th, 2014 09:07 AM |
Fake Nails | TnNinjaGirl | Off-Topic | 60 | March 25th, 2011 01:42 PM |
[superbikeplanet.com] - Paris: Nine Nails | Ninjette Newsbot | Motorcycling News | 0 | March 6th, 2010 01:00 PM |
Rubber VS Nails | demp | General Motorcycling Discussion | 4 | August 21st, 2009 10:04 AM |
