Old September 10th, 2018, 06:30 PM   #1
bowlbug
Motorcycle(s): 3rd gen Magna's !st gen magna's And now 250 ninja's
06 250 carb hose routing
I have an 06 250 I have been working on for a while. Sent the carbs out had them rebuilt. Trying to get it run not so good. I THINK the problem might be it is a Federal bike and possible California carbs. I can not find any decent diagrams for this. I have tee fittings coming off the carbs that seen to go nowhere. Any help wood be great. Thank you.
bowlbug is offline   Reply With Quote
Old September 11th, 2018, 01:36 AM   #2
Ceeloo Yello
Motorcycle(s): 250
You mean like these?
Old September 11th, 2018, 02:18 AM   #3
CA and Fed models use exact same carbs. Only difference is one extra vacuum line that goes to EVAP system.
Old September 11th, 2018, 05:01 PM   #4
bowlbug
Wow Thank you. That answers more question than I thought I had.
Old September 11th, 2018, 05:31 PM   #5
Ceeloo Yello
Motorcycle(s): 250
You're welcome
Old September 11th, 2018, 05:44 PM   #6
bowlbug
Thank you I can see that now. I play with 3rd gen Honda Magna's. big difference.
need to know carb hose routing 08+ 250 gitter 2008 - 2012 Ninja 250R Tech Talk 29 November 6th, 2017 05:45 PM
2008 250R Carb hose routing? devildogae 2008 - 2012 Ninja 250R Tech Talk 12 November 6th, 2016 04:32 PM
Carb Hose Routing jschatte 1986 - 2007 Ninja 250R Tech Talk 6 July 8th, 2014 08:30 AM
vacuum hose routing Sebastian f7 1986 - 2007 Ninja 250R Tech Talk 2 July 28th, 2013 07:06 AM
Need Visual Confirmation of Carb Hose Routing indr 2008 - 2012 Ninja 250R Tech Talk 3 June 23rd, 2013 07:49 PM
