April 25th, 2012, 07:27 AM | #1 |
Join Date: Apr 2012 Motorcycle(s): 2008 ZX10R & 2009 250R Posts: 30
15t Kawasaki OEM front sprocket
Is there a 15t front Kawasaki front sprocket that will work with the 08+ 250? I know there are a ton of aftermarket ones but really want one with the rubber damping. Thanks!
"Sometimes it takes a whole tankful of fuel before you can think straight." |
April 25th, 2012, 04:42 PM | #2 |
Join Date: Apr 2012 Motorcycle(s): 2009 Ninja 250 (blue) Posts: 134
Now that I now the increase in noise from an un-dampened sprocket, I would have gladly spent the extra for a dampened sprocket.
I hope somebody knows a source! |
April 25th, 2012, 05:53 PM | #3 |
Yea. I used an aftermarket one on my 2006 ZX6R and it made a lot of noise. After research, I found I could use a Z1000 OEM sprocket that worked like the stock one.
15t front sprocket loose | Lewis3845 | 1986 - 2007 Ninja 250R Tech Talk | 2 | March 10th, 2014 02:07 PM |
Suggestions for a 15T front sprocket? | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 21st, 2013 03:31 PM |
15t front sprocket swap! | play2pwn | 2008 - 2012 Ninja 250R Tech Talk | 3 | October 17th, 2011 09:17 AM |
15t jt front sprocket and now noise? | greatwhiteninja | 2008 - 2012 Ninja 250R Tech Talk | 25 | August 30th, 2011 08:34 PM |
15T Front sprocket is greeaaatt! | Hokie11 | 2008 - 2012 Ninja 250R Tech Talk | 16 | September 1st, 2009 03:47 PM |
