June 7th, 2009, 09:27 AM | #1 |
Join Date: May 2009 Motorcycle(s): NINJA 250R 08 Posts: 27
confused about air filters amongst other things
im about to get a boat load of performance upgrades next week...namely a dynojet kit and a area-p full exhaust....the DIYs seem pretty straight forward, but while im at it, i figure i might as well do a bunch of other stuff such as installing my shogun kit, changing the sprockets, and modifying the air filter/box...
so that's where im at a loss, what's the difference between a "pod filter" and an k&n r-0990...what about these bmc filters, there's so much terminology being intermixed with each other that i'm not really sure what would be best for me. I've seen from the jetting database that many just remove their snorkels and that would suffice as an intake mod??? i do not mind spending extra money on a filter or pod filter...but what the heck am i doing...i still dont know what the difference is between these different filters. other questions....has anyone ever tried installing the shogun crash kit....it says i need a standard floor jack, and i'm would really like to avoid buying one simply because i know this is one of the only times in my life i will ever need one. Thanks in advance for all your help, TC |
June 7th, 2009, 09:53 AM | #2 |
regarding the filters, there are 2 different ways to think of them.
one is to keep the stock airbox and the other is to remove it. if you keep the stock airbox, you can remove the snorkel and put in a drop in replacement airfilter. if you remove the airbox, you will need to use replacement airfilter(s). This replacement can be the single oiled gauze unit r0990 k&n, the 2 separate oil/gauze type BMC filters or the "pod" type filters from Uni. regarding jetting- if you keep the stock airbox, the main jets will be somewhere about 98/100 Keihin. if you remove the airbox, the main jets will be in the 110/112 Keihin range. |
June 7th, 2009, 09:53 AM | #3 |
Join Date: May 2009 Motorcycle(s): 09 ninja 250(red) Posts: 193
As for the K&N and BMC filters I don't konw anything about them as I don't have either one of them. But I think the K&N cost more. If your are going to remove the air box you might need a bigger main jet as most poeple are using 110 main jet with air box removed. The dynojet kit only ges to 100 main jet. I would say that removing the snorkel is a intake mod because you are modifying the air box to let more air in.
Hope this helps Kelly beat me to it Last futzed with by CANTFUNCTION; June 7th, 2009 at 10:06 AM. Reason: Kelly can type faster than me |
June 7th, 2009, 11:50 AM | #4 |
so disregarding costs and effort, which is the better route? taking out the air box?
June 7th, 2009, 12:38 PM | #5 |
better for what?
June 7th, 2009, 04:01 PM | #6 |
If you want to know if you should remove or keep the air box, I would just keep the air box in and remove the snorkel for now. And if you are not happy with it then get the filter. As you could see if there was any HP gain by doing this.
If you are talking about which air filter is better. I would get get the K&N as they look like they are easier to put on and take off. But the BMC filters look like they flow more air. |
June 7th, 2009, 06:17 PM | #7 |
so say i'm taking the snorkel removal route....i should pop in one of these...? http://www.solomotoparts.com/product...cat=320&page=1
again thanks for all the helpful replies |
June 7th, 2009, 08:11 PM | #8 |
R&T Suspension
Join Date: Jun 2009 Motorcycle(s): Too many to list Posts: 175
If its a streetbike keep the airbox.
June 7th, 2009, 08:34 PM | #9 |
Sarcasm: Yea that'll work
Join Date: Dec 2008 Motorcycle(s): '08 Ninja 250R Posts: 330
I'm going to throw my two cents in here. Keep the airbox in there. You won't get much power gains with the airbox removed, and I hear it's a royal pita to get out. Not only that, but your mileage will drop even more with the airbox out.
I recently put in Dynojet Needles, Drilled the Slides, and Removed the Snorkel. I have the stock exhaust. I rode it around for a few days while my drop-in K&N came in the mail. It came yesterday and I put it in there. I have to say, it's expensive, but worth it I think. I wasn't expecting much of a difference just because of the K&N, but there was one. The engine pulls hard throughout the entire rev range and gets up to redline pronto. The only thing I have left to do is mess with the idle/low end mixture screws to help it around 5000rpm. Since you're also putting on a new exhaust, you'll get all the power you want, and removing the airbox wouldn't be worth it in my opinion. Last futzed with by kazam58; June 7th, 2009 at 08:36 PM. Reason: stupidity on my part |
June 7th, 2009, 10:56 PM | #10 |
ok thanks all...
so uhm, does the link i have above ...http://www.solomotoparts.com/product...cat=320&page=1 ...will that work as a "drop in filter"? |
June 7th, 2009, 11:00 PM | #11 |
it should.
June 7th, 2009, 11:05 PM | #12 |
Ramen Rider
Join Date: Jan 2009 Motorcycle(s): 2015 BMW R1200R, 08 Honda VFR800A (sold), 09 Ninja 250R (sold) Posts: A lot.
June 8th, 2009, 03:57 AM | #13 | |
Psychic war veteran
Join Date: May 2009 Motorcycle(s): Kawi Green '09 Ninja ZX6R Posts: 663
* If you're arguing with some idiot over the internet, chances are pretty good he's doing the same thing! Zodiac Mindwarp and the Love Reaction |
June 8th, 2009, 02:33 PM | #14 |
My K&N fit fine. It has a rubber frame, which seals pretty damn well on its own it seems, but they also supply some grease to add to the outside edge of the filter. You just have to watch which end is tapered.
'08 Blue - Seat Cowl - A-Tech CF Fender Elim - Zartan's Exhaust Hanger - Dynojet Kit - Drilled Slides - Snorkel Removed - K&N Drop In Air Filter - Tech Spec Grips - Sportisi Windscreen & VR Exhaust |
Pipercross air filters. Where??? | evidens83 | General Motorcycling Discussion | 4 | February 9th, 2014 09:12 AM |
Air Filters | 102dalz | 2008 - 2012 Ninja 250R Tech Talk | 2 | September 18th, 2013 06:42 PM |
[sportrider - latest stories] - K&N Air Filters Named as Official Air & Oil Filter Su | Ninjette Newsbot | Motorcycling News | 0 | June 11th, 2012 06:00 PM |
The truth about aftermarket air filters | mrlmd | General Motorcycling Discussion | 43 | September 23rd, 2010 09:12 AM |
Air Filters? | mista350z | 2008 - 2012 Ninja 250R Tech Talk | 3 | July 29th, 2009 04:03 PM |
