June 16th, 2011, 12:26 PM | #1 |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
Turn Signal indicator problem!
Its been going on for a while, just kept forgetting to ask. When I installed the LED's in my dash, the left turn signals wont activate the indicator. The actual blinkers flash but the indicator doesnt. However the right side works fine! Indicator works just fine.
Its not a huge issue but I keep forgetting the left turn signals are on
----> My Youtube! <---- Unregistered, watch my youtube page! |
June 16th, 2011, 12:34 PM | #2 |
I'd put my money on you having a polarity-sensitive LED dash indicator bulb (very common and [relatively] easily fixed). If you do the diode mod, I think it'll fix it.
An easy test for ya: Pull the bulb out of the socket and flip it, so it's plugged opposite how it was. Then try your blinkers. I'll bet it starts blinking for the left side, but not the right. Why: Incandescent bulbs (at least the kind we've got in the dash) will light regardless which way the electrons are flowing, or more to the point, which way you put 'em into the socket. Most LEDs though, only work one way, so polarity is important. The way the blinker indicator is wired, the bulb connects to one pole of each side of the blinkers (e.g. 'hot' for the right side and 'hot' for the left) making the entire flasher signal system a single circuit, in effect. Once the voltage that powers either the left or right blinker pairs reaches the indicator, it's only got enough "juice" left for one more bulb (the dash indicator). The bulbs on the other side (the side you didn't mean to light) still get some power, but it's not enough to light them, unless you've installed LED turn signals. To get the LED dash to work right, you need to designate one pole as "hot" and the other as "ground" which is accomplished (along with other things) when you do the diode mod. After the diode mod, the light will only work in one orientation in the socket, but it should light for both sides of the blinkers. Instructions and diagrams for the diode mod are available here: How to build the diode bridge Where to install it, whether you built it yourself or bought one Diagram of above & how it fits into the circuit
June 16th, 2011, 12:42 PM | #3 |
KThanksBye
That makes sense, However If I remember correctly, I tested the stock bulb (non polarity dependent) it still didnt flash I have to double check, next time the bike is apart. But I could be wrong (probably am )
June 16th, 2011, 12:59 PM | #4 |
Hehe, sounds like you already knew what I just spent 10mins typing. All the better
Definitely let me know if the test I suggested doesn't work and/or if the stock bulb doesn't work for the left signal. If that's the case, I'd suspect a ground (possibly damaged wire or connector) between the front left bulb and the indicator.
June 16th, 2011, 01:25 PM | #5 |
Internet Slut
Join Date: Sep 2010 Motorcycle(s): 04 FZ1, 07 FZ6 Posts: A lot.
Its the LEDs we installed, i am having the exact same issue, we just crapped out and when we tested them happened to turn them to the one side that flashes lol.
June 16th, 2011, 01:55 PM | #6 | |
KThanksBye
So yours is doing it too?
June 16th, 2011, 02:28 PM | #7 |
Join Date: Mar 2010 Motorcycle(s): Ninja 250r Special Edition 25th Anniversary Posts: 17
Mmm , that's why my dash don't blink but I also realize when I put 1st into 2nd the neutral blink a little bit also 2nd into 1st.
so , the only way can fix is to do the diode mod? |
June 16th, 2011, 02:52 PM | #8 | |
I suspect the LED for your neutral indicator is likely to blink a little when going between 1st & 2nd (shifting up or down) because the LED needs so little power to light that even the momentary, slight power provided by the neutral indicator switch (when it passed by N when changing between 1 & 2 [and from 2 to 1]) is enough to get it to come on briefly. I honestly don't know how to fix that one, other than putting a capacitor or timer in the system. That said, I haven't looked at that wiring before.
June 16th, 2011, 03:15 PM | #9 | |
KThanksBye
June 16th, 2011, 03:24 PM | #10 |
And now that I think about it, I'm fairly sure even my stock incandescent neutral light does that.
June 16th, 2011, 03:34 PM | #11 |
Internet Slut
It's the LEDs, Sharon just took the 250 apart and we put the stock bulb back in an it flashes left and right now, change back to stock and you should be good
June 16th, 2011, 05:23 PM | #12 | |
But if that's what ya'll are going with, I'm almost curious enough to bypass my diode mod, restore my stock incandescent signals and if I can duplicate your symptom. Almost. Maybe this weekend if I don't wind up working.
March 22nd, 2014, 09:17 PM | #13 |
Join Date: Oct 2013 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 219
i just put in all leds on my dash, and i am having the problem where my led blinkers are working fine, but my dash blinker indicator does not illuminate at all.
i have a diode kit installed. prior to putting leds in my dash, the blinker indicator stopped working a few weeks ago. i figured the bulb burnt out, but now since the led bulb is not working too, i think there is a more underlying issue at hand. any ideas what it could be? |
Indicator Problem - Turn Signals Not Working | alex192 | 2008 - 2012 Ninja 250R Tech Talk | 6 | December 7th, 2014 09:56 AM |
dash turn signal indicator | jnz | 2008 - 2012 Ninja 250R Tech Talk | 3 | October 8th, 2013 09:05 AM |
Turn Signal Indicator Issues | menikmati | 2008 - 2012 Ninja 250R Tech Talk | 9 | December 12th, 2011 08:17 PM |
Turn signal indicator? | crazyjayp | 1986 - 2007 Ninja 250R Tech Talk | 2 | September 11th, 2011 11:49 AM |
Turn Signal Problem | shawn57187 | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 17th, 2011 02:13 PM |
