February 10th, 2012, 10:29 PM | #1 |
Join Date: Jan 2012 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 347
Dash lights/ front headlights flickering?
Hey guys i gotta little dilema. So about a week ago, i washed my bike, and i think i mighta gotten some water somewhere i shouldnt have. Because, a day or two afterwards, i noticed when i was behind someone at a redlight, that my headlights were flickering off thier car, and im like wtf?? Then i studied it more carefully, and saw that my dash lights including all the otherlights(highbeem, neutral) flickered as well. When my bike is OFF but ignition turned on, i dont think it does it. And if i rev it, it will flicker with the rev sometimes.
Any suggestions on what might have happened? i already checked all the fuses, and their great, but i dont know where to go from there. And im not an electrical fanatic so yeah... This isnt huge, as everything still works the way it should, just a little pest. |
February 10th, 2012, 10:36 PM | #2 |
Join Date: Aug 2011 Motorcycle(s): 2008 Kawasaki Ninja 250R, 2003 Honda CBR600RR Posts: 721
Mine does the same thing from time to time, but goes away as rpm's get higher than idle which means it has something to do with the alternator output more than likely. I haven't been too overly concerned about it though as the flickering isn't bad enough to make it a hazard and if anything, makes my headlights even easier to spot (as if purple headlights weren't ALREADY easy to spot...) Curious, do you ride with you high beams on? I always have mine on, I've never tried switching to lowbeams while the flickering is going on to see what happens.
ATGATT |
February 10th, 2012, 10:39 PM | #3 |
Yes sir ALWAYS with high beams on, but even with the low beams only on it still flickers a little bit, and at idle it will flicker as well. I dont really notice it as it gets higher into the rpms as well now that i think about it...I just want to know why i just noticed it AFTER i washed it. And yeah thats exactly what i was thinking, we got free pulsing headlights
February 10th, 2012, 10:44 PM | #4 | |
ATGATT |
February 10th, 2012, 11:26 PM | #5 | |
Yeah, sometimes it completly stops but for the most part its their but not much. And yeah its not putting the lights out, so im good there |
February 11th, 2012, 12:01 AM | #6 |
I had a similar issue once. Tighten the battery terminals. If that does not fix the problem. Charge the battery on a charger.
- if your lights on the Ninja 250 begin to flicker or your gauges or engine speed start to act erratically, check your battery connections http://www.ninjette.org/wiki/Battery |
February 12th, 2012, 07:34 PM | #7 | |
February 12th, 2012, 09:07 PM | #8 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
Stop tapping your right foot to the music. The load from the brake light can dim the headlight at idle.
Posted via Mobile Device |
February 12th, 2012, 09:11 PM | #9 | |
Milkshake Drinker
February 12th, 2012, 09:22 PM | #10 |
Haha I'd turn them off if they were a problem. The roads here in Vegas even at night are bright, I've never had anyone flash at me with their high beams or put their hand up to their mirror to cover up my lights so I know I'm causing a problem. My brother's 250 on the other hand DID have that problem. He started riding with his high beams on all the time as I do with the factory lights, but his were aimed SUPER high cars all the time would flash at him or hold a hand up to their mirrors. I don't do it to be an idiot or anything, it's just if no one seems bothered by it, then I don't have a problem keeping them on full time. The moment someone complains I'll turn them off immediately without hesitation.
ATGATT |
February 13th, 2012, 12:04 AM | #11 |
^^ Skippii has a good point here. With the brights on, the bike doesn't have a lot of extra juice, especially if the bike isn't above about 4k in the rpms. Even the blinkers or brake light can cause the headlight and gauge lights to go dim and bright again in accordance to when the other lights are on or off respectively. That's part of why I converted everything except the brake light to LED's; I found the dimming to be annoying.
February 13th, 2012, 12:15 AM | #12 | |
ATGATT |
February 13th, 2012, 12:30 AM | #13 | |
Milkshake Drinker
February 13th, 2012, 12:36 AM | #14 |
Milkshake Drinker
...to the same degree as other batteries. Some batteries will drop almost immediatley from charging to resting voltage when power is removed. Others will fade down more slowly (we're still only talking fractions of a second.) Basically, you want the voltage drop to be less than a volt between peaks. In a house in the usa rectifying ac, that would be 1/120 of a second with a full wave rectifier. On a bike, it's equal to rpm*peaks per revolution, which depends on the design of the alternator.
February 13th, 2012, 01:03 AM | #15 | |
ATGATT |
February 13th, 2012, 01:39 AM | #16 |
Milkshake Drinker
I don't know the alternator output. HID ballasts work differently than halogen, though, and they really shouldn't dim so noticably. Their current draw isn't determined only by the resistance of the circuitry, but rather by the reactance as well, which is determined by frequency and the inductance. Because that, rather than resistance, is the limiting factor, available current shouldn't make much difference.
February 16th, 2012, 08:23 PM | #17 | |
So the bikes still flickering, but i still havent gotten around to checking the battery connections yet. That seems like thats what the problem might be, loose or some corrosion on the wires. I'll find out next week during winter break |
February 27th, 2012, 08:42 AM | #18 |
Hey guys, so pulled off my seat yesterday, and check my battery connection. Sure enough my ground wire(black) was LOOSE!! Tightened her back up, and shes good as new Thanks for all your guys' help!
Dash lights flickering no starter ?!?! | jamasda | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 6th, 2014 08:06 PM |
no headlights or high beam dash light? | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 2 | June 6th, 2013 08:50 AM |
...Dash Lights. | himynameisjoe | 2008 - 2012 Ninja 250R Tech Talk | 11 | January 20th, 2013 09:57 AM |
LED Glow kit = dash and headlights flicker? | agalloch | 2008 - 2012 Ninja 250R Tech Talk | 2 | August 12th, 2012 03:39 PM |
Help Oil lights flickering | mrscbw | 2008 - 2012 Ninja 250R Tech Talk | 58 | April 1st, 2011 12:18 PM |
