April 6th, 2012, 10:44 PM | #1 |
Join Date: Aug 2011 Motorcycle(s): 2012 Ninja 250, 2008 Daytona 675 Posts: 212
Fork oil level: with or without springs?
I'm installing racetech springs...just finished 1 fork, it's back on the bike and secured. Then I realized...I put the oil with the spring in and set the level to 140mm (racetech recommended). Does the spring volume make that much of a difference? I'd hate to disassemble everything again.
April 7th, 2012, 02:38 PM | #2 |
Apparently it does. I opened up the forks again and set the oil level to 140mm without springs installed. That equaled about 70mm with forks in. We'll see how well it works.
April 9th, 2012, 12:29 PM | #3 |
IC2(SW)
springs out, forks compressed.
April 9th, 2012, 11:29 PM | #4 |
Join Date: Jul 2011 Motorcycle(s): 2019 Ninja 400, 2009 KLX250-SF, 2014 Zero S Posts: 269
So I don't get "forks compressed". Without the springs in the fork, the fork will totally collapse.
It seems you would set it with the fork at the top of it's travel (full extended). If yes, why is this called 'compressed'? If no... I just don't get it. |
April 13th, 2012, 11:06 PM | #5 |
Hydraulics. The fluid does not compress under pressure like a gas would, therefore, the levels must "fit" with them fully compressed. They would "totally collapse," which is exactly what they mean by "compressed."
April 16th, 2012, 02:06 AM | #6 |
Join Date: Nov 2011 Motorcycle(s): Many Two Wheels .. Posts: 611
I am using 0.8kg Sonic springs and using stock oil level height. 108/110mm. Worked perfect for me at Laguna Seca Raceway. Upgraded to 12.5W with preload caps. Testing today at Infineon Raceway.
[ex-AFM #828 | SMUSA #828 | Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers + OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com |
Clip-ons levers R6 tubes 15w fork oil .75 springs review | mr2peak | 1986 - 2007 Ninja 250R Tech Talk | 5 | June 26th, 2014 08:33 AM |
Fork oil level | Sipper' | 1986 - 2007 Ninja 250R Tech Talk | 1 | June 25th, 2014 04:08 PM |
How much for a "loose" fork oil job? Springs? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 10 | March 19th, 2012 12:00 PM |
Front Suspension: Preload Vs Stiffer Springs or Fork Oil | Daniel_Malloy | 2008 - 2012 Ninja 250R Tech Talk | 2 | February 12th, 2012 01:39 AM |
I'm getting new fork seals tomorrow. What oil level should I use? | AgentCircus | 1986 - 2007 Ninja 250R Tech Talk | 8 | August 12th, 2010 02:04 PM |
