April 30th, 2010, 11:16 PM | #1 |
Join Date: Apr 2010 Motorcycle(s): Yellow n black 2002 ninja ex250 Posts: 11
changed battery n plugs started right up 5 min latter won't do anything?
Ok I've been a lurked here for awhile n thanks to everyone who posts n who replys this place is a wealth of info on these bikes.
So thanks to everyone,. Ok here's my problem 250 2002 new battery new plugs fired right up sounded great, shut off the bike grabbed my gear went outside n when I tried to start it up it wouldn't do anything. When you press the starter it doesn't click or make any noise. The directional lights work as well as the LCD stuff in dash. The horn doesn't work. The only thing I can think of is when I changed the plugs I wasn't sure how the (black wire that attaches to the top of the plug) connected wasn't sure if it screwed in or you pressed it down on top of the plugs. Can some one tell me which is how it's done I'm hoping the connection is just loose based on this. However why wouldn't my horn work isn't that battery related. And the battery is bran new plus I had them test it in front of me this is my first starter bike n I havnt rode it further then down the driveway. I also work 70 hours a week n have little time each week to work on it. Ok enough sob story any help is apreciated n thanks agan to everyone out here if only you could knew how much someone like me who is new gains from your posts Tom m bostonninjabastard Posted via Mobile Device |
May 1st, 2010, 12:11 AM | #2 |
Join Date: Jan 2009 Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock Posts: A lot.
it almost sounds like some sorta safety feature is keeping the bike from starting.
make sure the RUN, switch (rt. handlebar cluster i think)..is in the proper position. make sure the bike is in neutral if you're starting without holding in the clutch lever. sent you a PM also
Remember when sex was safe and motorcycles were dangerous? |
May 1st, 2010, 12:16 AM | #3 |
Hey thanks yeah went over all the basics in neutral clutch in key turned to on fuel selector on all that stuff. But yes it does seem like something is happening that keeps me from a normal start like I said when you hit starter it
does nothing thanks tho Tom m Posted via Mobile Device |
May 1st, 2010, 12:48 AM | #4 |
i'd look at fuses next.
do you have a maint. manual? i can help direct you to a wiring diagram if you need.
May 1st, 2010, 12:57 AM | #5 |
Hey man great advice I've been looking at that online tonight I think maybe the ignition fuse Ima try that next I'll keep the board informed n thanks again
May 1st, 2010, 01:05 AM | #6 |
good luck!
something about your horn not working is bugg'n the pineapple juice outta me...so much so i went outside to see iffn the horn works with ignition energized and it does. i'm assuming it workd prior to your problem yes? ...got me wondering bout that left side handlebar cluster... but thats just me
May 1st, 2010, 08:17 AM | #7 |
You may want to check your battery to make sure it has enough charge. Starting the bike the first time took a lot of juice out of the battery and you may not have let it run long enough to re-charge it.
May 1st, 2010, 02:10 PM | #8 |
Join Date: Jan 2010 Motorcycle(s): 2005 Suzuki S50, 2006 Kawasaki Ninja EX250F, 1990 Honda PC800, 2000 Yamaha TW200 Posts: 848
If that was a new AGM battery, regardless of what the dealer says when he fills it with acid and says it's good to go, that is wrong! All AGMs have to be put on a charger first and must be FULLY CHARGED prior to first use or they will fail. They will have no capacity, they may not start the bike more than one or two times. Put your battery on a 2 amp charger (not a battery tender), charge it up for 4 hours at least, take it back to the dealer and have him do a load test on it. I bet your battery is no good. Before you use the new one you get as a replacement, make sure it is charged up first, do it yourself, not the dealer, or you'll be back there again.
If you just charge your battery and start up your bike, it may do that a few times and then may crap out. Getting it load tested is the only way to see if it is any good, it can read 12.6 or 12.8V and not be able to start your bike more than one or two times. To be sure your problem is the bad battery, hook up your bike with jumper cables to a NON-RUNNING car and see if it starts. (If you have the car running, the alternator output will fry all the electronics on most bikes - be warned). It's perfectly safe if the car engine is not running, you are just using the 12V from the battery. And like most bikes, the clutch lever has to be pulled in to start the bike, that's a safety feature, otherwise the starter will not engage. Don't start to rip your bike apart - see if it starts from jumping it, then charge up and have your battery checked, charge the new one up before you use it, and I bet you'll have no more problems. |
May 1st, 2010, 08:26 PM | #9 |
You explained it much better than I did. |
May 2nd, 2010, 12:29 AM | #10 |
Haha thanks guys, yeah I did the car hook up ( without starting car with the last battery, the one the previous owner said was bran new) so I will hook it up again n see if bike starts that way if not I'll check the fuses. Quick question since you guys r so helpful if I hook it up to my car n my bike starts what should I do next let it run for awhile or unhook it still running n let it idle for awhile or should I imedatly get that charger you tolde about. When my dealer sold me the battery he tested it right in front of me n told me it was at 75%.
Also when I was parking the bike ( my first ride on it literally bought it week ago n my first bike) i let the clutch out to far n it stalled could this be what caused the problem? Would stalling it hurt the battery such to mess up fuses or kill batttery. Let me know what you vets think n my most sincere thanks to all that responded I'll throw some pics up once I het to take it for that first ride Tom m Boston ninja bastard Posted via Mobile Device |
May 2nd, 2010, 01:49 AM | #11 | |
i think rick and marc got you pointed in the right direction...i wouldn't bother trying to charge the battery if you get the bike started. take it back to where you purchased it per marc's comments
(boldface emphasis mine) Quote:
May 3rd, 2010, 08:35 AM | #12 |
If the battery tested at 75% that means it was DEAD. That's why you got one start out of it. Your dealer doesn't know squat about batteries.
If you get the bike started by jumping it, that tells you the problem is your battery. Once you start the bike, unhook it from the car so you don't share the bike's alternator output between the car and the bike. If you went for a long ride, like an hour, you might charge up the battery, idle probably won't. But that battery is toast now, so don't screw with it or waste any time on it. Bring it back for a full replacement and you will see it load tests bad. There is nothing wrong with any of your fuses if the bike started from a jump, don't start looking around for other problems, Get the battery replaced and fully charge up the new one before you use it and you'll be fine. |
Changed out spark plugs after winter. Give gas and dies. | Twitchy Stitch | 1986 - 2007 Ninja 250R Tech Talk | 56 | March 2nd, 2015 04:02 PM |
Changed Spark Plugs; Right Side Boot Won't Snap In Easily | Lil_Green_Demon | 2008 - 2012 Ninja 250R Tech Talk | 8 | February 16th, 2015 10:09 AM |
Changed spark plugs - idles lower with choke | ajnin | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 2nd, 2011 10:16 AM |
New battery, still won't start | frankfong | 1986 - 2007 Ninja 250R Tech Talk | 9 | January 12th, 2011 10:08 AM |
Changed plugs, bike won't idle.. | pixelpete | 1986 - 2007 Ninja 250R Tech Talk | 9 | April 20th, 2010 11:22 AM |
