Old January 17th, 2017, 12:48 PM   #1
Bluberryrain
Bluberryrain's Avatar
Repainting my bike!
Sup ya'll?
Since it's absolutely freezing outside, and I'll get no riding time over the next few months, I decided to take the time to do several projects on the ninjette. Just ONE of these is repainting the whole bike.
The previous owner managed to knock the bike over and crack the left fairing pretty bad, and add a few scuffs.. I managed to patch it together to get through riding season, but it always bothered me. I figured for the extremely low price I bought the bike for. I can invest some time and money into fixing it up. I'm using all colorrite spray paints, primer, clear coat, etc. It's expensive, but it's also amazing.
Also, for the non-damaged parts, I will be sanding lightly and adding in some Kawasaki green to them. (Passenger seat fairing, gas tank, front fender and part of the main fairings)
First things first - I used the dremel tool along the cracks on both the front and the back of the fairings to create a "V" shape. I then used ABS cement on the front, back and middle of the cracks to repair the cracks (and actually recreate a piece of plastic that was missing about the size of a quarter.)
Here are some pictures before starting:
https://i.imgur.com/P1eF044.jpg
https://i.imgur.com/VsmSRvv.jpg
https://i.imgur.com/dGGldTF.jpg
Here is a picture after filling cracks and sanding. I left a little of the ABS material on there, just to show how I am doing it:
https://i.imgur.com/hft8HPz.jpg
So, with that said, here is my process thus far:
-Fix & fill cracks/imperfections
-Use 120 grit sandpaper to sand everything down flush(the whole fairing down to plastic)
-Fill any cracks or gouges or scrapes again
-Sand with 120 grit paper
-Sand the whole fairing with 400 grit paper, to ensure everything is feathered and there are no extremely rough spots. Touch is really REALLY important here. If you can feel it- sand it more. If you think to yourself "I wonder if primer will cover this"....it won't. Sand it.
Now, it's time for primer!:
-Put on latex/rubber gloves (keep oil of the part)
-Use mineral spirits to wipe the part down throughly. This will remove any wax grease etc. This is very important.
-Use a tack cloth to remove any leftover dust, hair, etc. This is sticky and will pick it all up.
-Apply the primer in light even motions. Paint the corners first!
-Wait 15 minutes and apply another coat
-Wait for it to fully dry, and WET sand with 1000 grit sandpaper to remove bumps, uneven spots etc
Here are the fairings primed, but not sanded yet:
https://i.imgur.com/2BoLPsx.jpg
https://i.imgur.com/aWAWpUe.jpg
https://i.imgur.com/rYJJtVM.jpg
This is where I'm at in the current stage with the main fairings.
As for the other parts, I've already sanded, painted and clear coated some of them green. I'll wait a couple weeks, and then I'll wetsand with 2k grit and polish.
If there's any interest, I'll continue to update this post with my progress and steps used to achieve my final result. Let me know if any of you are interested!
Bluberryrain is offline   Reply With Quote
Old January 17th, 2017, 01:17 PM   #2
Flying
Motorcycle(s): 2010 Ninja 250
Solid work on the prep!
Old January 17th, 2017, 02:04 PM   #3
Before you sand the primer, spray a light/overspray coat of a contrasting primer on the parts - no need to spray enough to cover it with the new color.
That gives you a "road map" of the surface and any defects as you are sanding. It also shows you what areas you haven't sanded, which is helpful when the entire piece is wet.
Old January 17th, 2017, 04:05 PM   #4
Bluberryrain
Thank you! I'm quite happy with how well the primer went on. I spent a couple weeks patching and sanding, sanding, and then sanding some more.
The most important thing you need when doing this job is patience, and a lot of it. Although, it's kinda "zen" for me, so I enjoy it.
Old April 27th, 2017, 06:33 PM   #5
highvoltj
highvoltj's Avatar
Motorcycle(s): 2008 Ninja 250R, 1986 Ninja 250R (x2) '06 ZX6R 636
prep/paint
WOW!!! Awesome job Nick!!! Ever thought about hiring your skilz out???
So can I ask...where did you get the Lime Green Kawi paint?
highvoltj is offline   Reply With Quote
Old April 27th, 2017, 06:38 PM   #6
Bluberryrain
Final Pics:
http://imgur.com/a/zI7p6
Hey, thanks!! I have thought about it, or at least buying some busted up fairings and turning them for a profit. Maybe someday I'll work on making that a reality
Sure! I got all of my paint from Colorrite.com. I believe the Kawi Green color is #777. Kinda pricey, but real quality stuff.
Old April 27th, 2017, 06:40 PM   #7
highvoltj
highvoltj's Avatar
re:paint
Just saw the finished product! EXCELLENT!!!!!!
Old April 27th, 2017, 06:55 PM   #8
Bluberryrain
Thank you so much, Jon!
Old May 16th, 2017, 03:40 AM   #9
djerwin02
Motorcycle(s): ninja 300
Looks great. The green color provides a nice contrast.
djerwin02 is offline   Reply With Quote
Old May 16th, 2017, 05:50 PM   #10
ROB654
Motorcycle(s): 08 NINJA 250,EX500,YSR50,86 VFR750
Nice job. What did you use for paint?
ROB654 is offline   Reply With Quote
Old May 17th, 2017, 10:36 AM   #11
Very nice!!! Which clear-coat did you use? And how many layers? thanks.
Repainting my Passenger brackets. Opinions on color? Monkeytofu 1986 - 2007 Ninja 250R Farkles 2 July 9th, 2012 02:06 PM
Finally repainting the bike/exhaust. Everything is ground up. Mekkakat General Motorcycling Discussion 7 December 27th, 2011 02:07 PM
[superbikeplanet.com] - Finally a Bike That Fits Him? Sic Tests 1000cc Honda GP Bike Ninjette Newsbot Motorcycling News 0 October 4th, 2011 06:40 AM
Repainting brake and clutch levers? HorizonXP 2008 - 2012 Ninja 250R Tech Talk 1 August 10th, 2010 07:05 AM
Repainting the bike randomwalk101 2008 - 2012 Ninja 250R Tech Talk 16 June 17th, 2010 07:19 PM
