Old April 3rd, 2010, 04:46 PM   #1
JeffM
Mr. 988
JeffM's Avatar
Motorcycle(s): One
Just performed my first valve adjustment
and boy are the exhaust lash adjusters hard to get to. It took me three hours (with breaks) to take the head cover off (after moving the radiator, coils and removing the front engine mount ) and get those set. The intakes took all of 20 minutes.
All of the valves were tight - could not get the feelers between the cam and the tappet . I set them at the loose end of the adjustment range.
Filled the float bowls and fired it up and ta-da it started and seemed to like the adjustment. Nice and smooth with no valve train noise. Next I'll sync the carbs and good to go for another 6000.
Jeff
JeffM is offline   Reply With Quote
Old April 4th, 2010, 02:10 AM   #2
cnichols79us
Fastly Slow!!!
cnichols79us's Avatar
Motorcycle(s): 2007 Kawasaki Ninja EX250, 1980 Honda XL125
Good Job Jeff. I took mine in and had the valves done cause I am SURE I would have punched someone in the face before completion.... Glad you had the Patience!
cnichols79us is offline   Reply With Quote
Old April 6th, 2010, 04:44 AM   #3
drstimpy
two wheels good
drstimpy's Avatar
Motorcycle(s): 04 ex250 and 08 Triumph Sprint ST and custom calfee carbon race tandem
valves
My cover is off now and all mine are on the tight side at 500 miles too. I'm thinking about all four of those exhaust valve adjusters and scratching my head...not a job to do without coffee or alcohol involved!
Some must watch while others must sleep
drstimpy is offline   Reply With Quote
Old April 6th, 2010, 08:12 AM   #4
JeffM
Mr. 988
JeffM's Avatar
Motorcycle(s): One
John, I really think a beer would have helped even more - except I wouldn't trust my work as much!
The worst part was stressing about dropping a socket or something down into the bowels of the engine. I actually tied my feeler gauges to a string and had a big tie-strip tied to the other end. That set up came in handy as I could hang it on the bars and have it at the ready all the time.
Old April 6th, 2010, 08:22 AM   #5
2WheelGuy
2WheelGuy's Avatar
Just stuff a paper towel between the cam chains.
AFM #278
Old April 6th, 2010, 08:44 AM   #6
Snake
Snake's Avatar
My bike is at 18,000 miles and needs the valves checked / adjusted but I don't know if I have the patients to do it like I used to. My dealer did a great job last time and the price wasn't bad.
Last futzed with by Snake; April 6th, 2010 at 10:31 AM.
Old April 6th, 2010, 08:56 AM   #7
Flashmonkey
Professional belly dancer
Flashmonkey's Avatar
Motorcycle(s): 1992 GSX-R 750
Adjusting the valves definitely isn't that difficult to do, but you do need to set time aside for it as you don't want to rush yourself and screw everything up.
I love the fact that this bike is so ridiculously easy to work on.
Old April 6th, 2010, 11:28 PM   #8
drstimpy
two wheels good
drstimpy's Avatar
cam chain
Yes imagine the words as my 9mm rachet bit rattled down the cam chain galley! It was binding and pulling off the ratchet extension and I would just pull it off with needle nose pliers and of course it slipped on the final Right side intake. Thank heaven for that little magnet on the end of an extension thingie!! Will surely stuff a rag down there next time eh?
Old April 25th, 2010, 03:33 PM   #9
Gyrene
Motorcycle(s): 2004 Ninja 250
Snake - How much did it cost to have it done?
Gyrene is offline   Reply With Quote
Old April 27th, 2010, 07:39 AM   #10
HotWheels
Motorcycle(s): EX 250
Average price for me before was about $300.00 before at stealerships
HotWheels is offline   Reply With Quote
Old April 28th, 2010, 10:00 AM   #11
mikesova
Motorcycle(s): 2002 XR200r
I'm going to be doing mine in the next week or so. I'm not too excited about it, but it will be an adventure. I'll take it nice and slow.
mikesova is offline   Reply With Quote
Old April 28th, 2010, 10:31 AM   #12
JeffM
Mr. 988
JeffM's Avatar
Motorcycle(s): One
Go here for reference. Read all the articles a few times and get everything ready in advance of actually doing the job.
Definitely block out enough time to do the job.
Old April 28th, 2010, 12:09 PM   #13
drstimpy
two wheels good
drstimpy's Avatar
be sure and put a rag or something in the cam chain galley! I had fun fishing out a small socket with a magnet!
Old April 28th, 2010, 12:14 PM   #14
beowuff
beowuff's Avatar
When I do mine, I set aside 2 days. One to take everything apart. The second day to adjust the valves and put everything together.
That way, I'm fresh when doing the actual adjustment.
But I also have 2 250's in the garage (mine and my wife's) so I still get to ride when working on one
beowuff is offline   Reply With Quote
Would you do your valve adjustment? Bigballsofpaint 2008 - 2012 Ninja 250R Tech Talk 30 July 24th, 2013 09:04 PM
Valve Adjustment Help THE BIG SITT 2008 - 2012 Ninja 250R Tech Talk 15 April 10th, 2013 04:59 PM
Valve Adjustment to Come Soon! gilmorec61 2008 - 2012 Ninja 250R Tech Talk 54 June 22nd, 2012 03:43 PM
Valve Adjustment-Really Tight adjustment screw? mikesova 1986 - 2007 Ninja 250R Tech Talk 5 May 2nd, 2010 04:57 AM
Valve adjustment Apex 1986 - 2007 Ninja 250R Tech Talk 7 September 1st, 2009 05:53 PM
