April 18th, 2010, 08:08 AM | #1 |
Just curious, Who has ported their head?
So i have a stock Cracked head sitting around. Thinking about playing around with it. Has anybody ported their head? I know there is some work to be done in there. I saw this site and thought it was pretty neat.
http://www.eurospares.com/ex2501.htm and kinda this thread http://www.ninjette.org/forums/showthread.php?t=9698 I have kinda been toying around with pulling the head and jugs off the bike and re-ringing it, but it probally doesn't need it. Still runs real good. Just looking to get a little more toothpaste out of the tube if you know what im saying. |
April 18th, 2010, 08:29 AM | #2 |
MOTM - Sep '18, Feb '16
I need to get it done . I am having an engine built it will have extensive head work .
From what I read looking into it for doing it myself. Everything I read said don't . Other than obvious flashing .I would be surprised to find any in a motorcycle engine. But it could happen. One thing I found about the new head is the ports are very small. So the best thing to do is go with bigger valves. Then port the head . There is a hole for the clean air system in the exhaust port that will need to be welded shut . With out a flow bench there is no way you can tell if you cause more harm than good . Air velocity is the thing .Not volume.So shaping is critical . So I will have to pay some one to do it. |
April 18th, 2010, 09:07 AM | #3 |
What about Grinding the valve seats to the "margin"? A bigger valve is just something bigger for the air to hit before it gets to the chamber. My uncle builds and races bikes and that is what he does. He doesn't put bigger valves in it. The valves already overhang the cylinder a little. That would just be more shrouding.
I dont plan on makeing anything bigger. Just work on the floor on the intake side, and the bowls. If i remember correct, the roof of the exhaust side leaves a little to be desired. But i mainly want to work on the bowls. Did you see this picture? its on one of the websites i listed. good reading there. This will get alot straighter path to the chambers. |
April 18th, 2010, 03:05 PM | #5 |
Join Date: May 2009 Motorcycle(s): '98 EX250, '02 EX250, '08 250r, '03 SV650, '98 GSXR750 '03 Hayabusa, '87 YSR50, '84 ZX900, +MORE Posts: A lot.
I have a ported head on one of my pre-gen race bikes. The work was done by Mike Norman at G-force. He is one of the most knowledgeable EX250 engine builders. He built most of the fast bikes out here. I remember him saying that the ports are very restrictive and proper porting yields the biggest gains on these motors. I don't believe he used over sized valves. I may even have a spare G-force ported head in my spares collection that will come out when I do my spring cleaning.
CraigHarris.org Pacific Track Time CraigsWeb See you at 2014 MotoGP Laguna Seca! We'll be camping on Fox Hill. AFM #278 |
April 18th, 2010, 05:24 PM | #6 |
I was speaking of over sizing the valves on new engines. 1mm is what I have seen. My over all point is I don't think it is something you can just do yourself. But from what I have heard it is worth 4 to6 hp when done properly.
I would love to see some close up photos of a professionally ported head . |
April 22nd, 2010, 08:28 AM | #7 | |
Im not planning on putting bigger valves in, I just want to work on the ports. |
I'm curious about what brand oil to use | Alpen10 | 1986 - 2007 Ninja 250R Tech Talk | 31 | May 19th, 2014 04:06 PM |
Very curious! | skilletmo | 2008 - 2012 Ninja 250R Tech Talk | 14 | October 17th, 2012 08:02 AM |
New to bikes, but curious.... | Captcha | 2008 - 2012 Ninja 250R Tech Talk | 11 | October 28th, 2011 06:57 PM |
curious about 250 owners | scorpio_vette | Off-Topic | 63 | August 11th, 2009 07:29 PM |
curious, interesting, factual and.... | ninjabrewer | Off-Topic | 10 | March 15th, 2009 09:27 AM |
