April 28th, 2012, 02:50 PM | #1 |
Join Date: Apr 2012 Motorcycle(s): 09 Ninja 250 Posts: 4
Inaccurate Tachometer
The tachometer on my '09 ninja 250 started to show higher RPMs than it used to. The idle RPM went from ~1500 to ~3000. In fact, RPMs seems to have doubled. Now I rev often to the red line before I feel the bike is ready for an up shift.
The engine is either actually reaching the higher RPMs, or the tachometer is wrong. I believe the tachometer is inaccurate, because by my previous experience, the engine doesn't sound like it's revving as high as the tachometer displays. Anyone have any suggestions? Trying to think how it could have happened, I remember that right before I noticed this, I stalled the bike on a traffic light, and started the engine again without the clutch being fully pulled in. Could that have changed anything? Thanks for any insights! |
April 28th, 2012, 03:51 PM | #2 |
Join Date: May 2011 Motorcycle(s): 2011 Ninja 250R SE GREEN! Posts: 562
Loose battery connections cause strange things to happen. My tach was all over the place whenever I used the high beam and it turned out to be a loose connection.
Otherwise I'm not too sure, a crossed wire causing it to pick up from both coils? (It should only read from one) Have you done any work/mods recently? Ever? Are you the original owner?
Trust me, I'm a banana! |
April 28th, 2012, 04:23 PM | #3 |
CBR250R Traitor
Join Date: Jun 2011 Motorcycle(s): 2011 Red CBR250R 2009 Ninja 250r SE(With 2008 Fairings)(sold) Posts: 924
Is it when it gets hot outside? This is a known issue with the stock ignitor.
It happened to me as well. |
April 28th, 2012, 06:59 PM | #4 |
It doesn't double it, it just reads a little higher. Maybe 500rpm, not near 1500+
April 28th, 2012, 07:13 PM | #5 |
CBR250R Traitor
Mine read 1k high.
April 29th, 2012, 07:18 PM | #6 |
Actually now I suspect it is a clutch slippage issue. The clutch may not have been fully disengaged. I tried to adjust the clutch cables today, on both the upper end where the lever is, and at the lower end near the oil gauge, but I don't quite know how to adjust, and didn't fix the issue.
Anyone think the clutch slippage could be the real issue there? And I need a better guide for clutch cable adjustment than what is in the manual. |
April 29th, 2012, 09:20 PM | #7 |
No problem with a clutch will make it idle at 3000rpm. And I think you mean engage
Also in the OP you said it doesn't sound like it's ready to shift. You'd hear the revs skyrocket to redline if the clutch slipped. Did you check the battery connections yet?
April 30th, 2012, 10:07 AM | #9 |
No I haven't checked the battery connections yet.
Is it just checking the connections at the battery terminal? Or is there another connection I should check? I did mean "disengage". If the clutch is not fully released/disengaged, wouldn't the engine run at a higher RPM than when clutch is engaged? |
April 30th, 2012, 10:09 AM | #10 |
oh wait, nm, I did mean "engaged". right, I was wondering whether the clutch is fully engaged.
May 1st, 2012, 06:07 AM | #11 |
Yeah, make sure they're tight on the battery
If the clutch wasn't fully engaged the revs would shoot up and you'd have problems moving.
May 1st, 2012, 03:49 PM | #12 |
Make sure the battery is good too. My friend had one that tested good but the engine would rev when the brake light came on until he replaced the battery or connected a portable jump-start battery.
May 2nd, 2012, 06:12 AM | #13 |
This too, good call. And if you're gonna test it use a conductance tester. A voltmeter won't tell you if it's good
May 2nd, 2012, 08:18 AM | #14 | |
May 2nd, 2012, 08:43 AM | #15 |
They do a conductance test
Inaccurate Speedometer | gilmorec61 | 2008 - 2012 Ninja 250R Tech Talk | 3 | January 29th, 2012 08:38 PM |
Inaccurate tachometer? | shiftdrift06 | 1986 - 2007 Ninja 250R Tech Talk | 4 | March 28th, 2011 07:17 AM |
[visordown.com] - Top Notts Cop claims speed guns are inaccurate - after being caught | Ninjette Newsbot | Motorcycling News | 0 | August 20th, 2010 10:30 AM |
[visordown.com] - Gatso speed cameras inaccurate in cold weather? | Ninjette Newsbot | Motorcycling News | 0 | May 27th, 2010 12:30 PM |
Slow inaccurate gas guage | DirtyBoy | 2008 - 2012 Ninja 250R Tech Talk | 29 | April 24th, 2009 07:53 PM |
