June 6th, 2023, 10:10 AM | #1 |
[roadracingworld.com] - 2024 Kawasaki Ninja ZX-6R Gets Updated 636cc Engine, Brakes,
2024 KAWASAKI NINJA® ZX™-6R MOTORCYCLE SUPERSPORT OBSESSION The Kawasaki Ninja® ZX™-6R “636” motorcycle remains a staple in the Ninja® ZX™ supersport lineup, and for 2024, it benefits from several performance […]
The post 2024 Kawasaki Ninja ZX-6R Gets Updated 636cc Engine, Brakes, Styling appeared first on Roadracing World Magazine | Motorcycle Riding, Racing & Tech News. 2024 KAWASAKI NINJA® ZX-6R MOTORCYCLE SUPERSPORT OBSESSION The Kawasaki Ninja® ZX-6R “636” motorcycle remains a staple in the Ninja® ZX supersport lineup, and for 2024, it benefits from several performance and styling updates that push all boundaries with track-ready performance that prioritizes confident handling during high-performance sport riding. Kawasaki’s Ninja® ZX supersport models have always been renowned for their circuit riding potential as well as their ability to provide the exhilaration desired for real-world riding. The Ninja ZX-6R continues to offer superior performance across the rev-range with its potent 636cc liquid-cooled in-line four-cylinder engine and nimble handling thanks to its race-derived chassis that allows the rider to become one with the machine whether on the racetrack, navigating canyon roads, or cruising city streets. The 2024 Ninja ZX-6R receives all-new styling that is inspired by the Ninja® ZX-10R, yet retains its own distinct supersport identity. Its smooth, flowing styling was designed to turn heads and capture hearts. New compact LED headlights, an intricately layered front cowl, and a sporty windshield bring a new face to one of the most feared models in Kawasaki’s supersport lineup. Riders are greeted by a new 4.3” TFT color instrumentation as well as smartphone connectivity, integrated riding modes, and other enhanced features. The brake discs are now round, further contributing to the supersport image, while engine and exhaust updates enhance low-rpm. KAWASAKI NINJA ZX-6R HIGHLIGHTS
Ultra-fine atomizing injectors emit a droplet size of less than 60 microns to ensure efficient air-fuel mixing contributing to combustion efficiency. Precise settings contribute to a reduction in engine emissions while ensuring that power and torque feelings are maintained for riders who have come to know and love the Ninja ZX-6R power plant. Feeding the Ninja ZX-6R power plant is a large-volume 5.09-liter air box, which helps to create peak power and smooth power delivery. The intake funnel design features a revised shape that increases low-to-mid rpm performance. To protect the heart of the engine, the piston skirts feature a molybdenum coating, which keeps friction to a minimum. To maximize performance and reduce pumping loss, the engine features connecting passages between each of the cylinders. The exhaust design of the Ninja ZX-6R contributes to *optimal engine performance. For 2024, the header pipes, including joint pipes and the collector pipe feature a revised layout for cleaner emissions. Improved feedback from the O2 sensor was achieved thanks to the revised layout, optimizing catalyzer volume and load. An exhaust pre-chamber helps minimize silencer volume, contributing to mass centralization while the silencer’s triangular cross-section enables the requisite volume while ensuring a high lean angle and a compact image. TRANSMISSION The Ninja ZX-6R uses a cassette-style transmission, which facilitates *changes to gear ratios *and makes for efficient set-up time for track days. Its 15/43 final gear ratio further emphasizes the engine’s strong low-end; meaning it is well suited on both the racetrack and on canyon roads. ASSIST & SLIPPER CLUTCH Complementing the transmission is an Assist & Slipper Clutch, race-inspired technology that offers both a back-torque limiting function as well as a light feel at the lever. The Assist function provides a lighter pull at the clutch lever, helping to reduce rider fatigue, especially in stop-and-go traffic situations. The Slipper function is noticed when excessive engine braking occurs as a result of quick or accidental downshifts. The slipper cam comes into play, forcing the clutch hub and operating plate apart, which relieves pressure on the clutch plates to reduce back torque and help prevent the rear tire from hopping and skidding. CHASSIS The Ninja ZX-6R features a pressed-aluminium perimeter frame design. The two-piece sub-frame is made from aluminium die-cast pieces, consisting of a front and rear section. This layout enables a very precise, lightweight construction. It is also very narrow, allowing the rear of the bike to be very compact and slim. The base frame components offer a superb balance of flickable handling, mid-corner composure with the ability to change lines on command, coupled with excellent chassis feedback. SUSPENSION Complementing the chassis design, the Ninja ZX-6R is equipped with the Showa SFF-BP (Separate Function Fork – Big Piston) fork. Combining the concepts of Showa SFF and BPF, this advanced fork offers both racetrack performance and everyday usability. The Showa SFF-BP offers smooth action at the beginning of the stroke that contributes to excellent composure under braking. The large-diameter damping piston is much larger than what is found in a cartridge-type fork of the same size. The result is greater control as the fork begins to compress and a very calm attitude change as vehicle weight shifts forward when reducing speed, offering greater chassis stability on corner entry. The fork settings are designed to handle back roads as well as deliver a high level of performance for the track, while also accommodating highway and city riding. SFF-BP offers convenient adjustability. All the adjusters are located at the top of the fork caps: preload on the left, compression and rebound damping on the right. Each component only needs to be adjusted once. The Showa rear shock and suspension design contribute to rear ride comfort, offering a more plush feeling when riding in town or on the highway. The shock offers riders the ability to adjust preload, rebound damping and compression damping. * BRAKES & WHEELS
Handling the stopping duties up front for the Ninja ZX-6R motorcycle is a pair of powerful, highly rigid, radial-mount opposed four-piston monobloc calipers. These grip a new pair of large-diameter semi-floating 310mm stainless-steel round discs, offering superb control and a firm feel at the lever and contribute to strong braking. In the rear, the radial-pump master cylinder ensures excellent touch and offers superb control. The radial-pump master cylinder has been paired with a 220mm round disc and a lightweight rear brake caliper, which offers good anti-fade performance. The new round shape found on the brake discs contributes to a strong Ninja ZX family image. New Pirelli Diablo Rosso IV tires can be found in a 120/70ZR17 M/C (58W) front and 180/55ZR17 M/C (73W) rear, offering excellent grip in a wide range of riding conditions. ELECTRONICS KAWASAKI QUICK SHIFTER (KQS) The Ninja ZX-6R features a highly reliable contactless-type quick shifter with the KQS, which allows for ultra-quick, full power upshifts and seamless acceleration. The system detects that the shift lever has been actuated and sends a signal to the ECU to cut ignition so that the next gear can be engaged for clutchless shifting. * KAWASAKI TRACTION CONTROL (KTRC) The Ninja ZX-6R is equipped with Kawasaki TRaction Control (KTRC), which has three performance settings riders can choose from: Modes 1 and 2 prioritize maximum forward acceleration, while Mode 3 provides rider reassurance by facilitating smooth riding on low traction surfaces. The three modes of KTRC offer options for a wide variety of riding conditions. Riders also have the option to elect to turn the system off. KAWASAKI INTELLIGENT ANTI-LOCK BRAKE SYSTEM (KIBS)
POWER MODE SELECTION Riders can set power delivery to suit conditions and/or preferences, choosing from Full and Low. When combined with the KTRC and Power Mode options, riders have eight combinations from which to choose. Each system can be set independently to best suit rider preference, riding location, and road conditions. NEW INTEGRATED RIDING MODES All-inclusive modes that combine KTRC and Power Mode settings allow riders to easily set traction control and power delivery to suit a given riding situation. Riders can choose from three settings (sport, road, rain) or a manual setting (rider). In the manual “rider” mode, each of the systems can be set independently.
NEW TFT COLOR INSTRUMENTATION* A new 4.3” all-digital TFT color instrumentation gives the cockpit a high-tech, high-grade appearance and offers additional features unavailable on the previous model. It features a full-color display with TFT (thin-film transistor) technology, delivering a high level of visibility. The screen’s background color is selectable in black or white and screen brightness automatically switches between three rider-set levels to suit available light. Display functions include: digital speedometer, digital bar-style tachometer, gear position indicator, shift lamp, fuel gauge, odometer, dual trip meters, current and average fuel consumption, remaining range, average speed, total time, coolant temperature, clock, battery voltage, Kawasaki service reminder, oil change reminder, riding mode indicator, smartphone call and mail notices, Bluetooth indicator, and economical riding indicator. NEW SMARTPHONE CONNECTIVITY** Utilizing Bluetooth® technology built into the instrument panel, riders can now connect to their bike wirelessly. Using the smartphone application “RIDEOLOGY THE APP*”, a number of instrument functions can be accessed, contributing to an enhanced motorcycling experience. Available functions include:
STYLING
The front cowl’s new layered design is complemented by winglet-style inlets and angled chin spoilers to form a highly distinctive image. The inlets help keep the wind off the rider, contributing to ride comfort. Unlike the Ninja ZX-10R’s horizontal chin spoilers, which are used to create downforce*when racing down the straight, the Ninja ZX-6R’s chin spoilers are angled, conveying an image of downforce while cornering. The new compact headlight’s low-beams feature plastic projector lamps with mono-focus LED technology, while the high-beams and position lamps are reflector-type lamps. The deep-set position of the reflectors of the unlit parts of the headlights makes them appear dark, creating a fierce expression. Black extensions between the low and high-beams contribute to the black image and help deliver a high-quality finish. The area surrounding the RAM Air Intake is completely painted, unlike the previous model, contributing to the sleek design. A new sporty windshield is short and contributes to the Ninja ZX-6R’s supersport image. Similar to the Ninja ZX-10R, the front cowl supports the sides of the windshield. Holes in the windshield relieve pressure build-up behind the screen to help reduce buffeting when riding at elevated speeds. Like the design of the tail cowl, the front and side inner cowls use interwoven layers to create a 3D effect with the multiple layers adding to the high-class design. In contrast, the side outer cowls and lower cowl are smooth. The bodywork’s smooth, flowing design draws the eye from head to tail and hints at the Ninja ZX-6R’s supersport performance. New LED turn signals complete an all-LED lighting package that begins with its new compact headlights and ends with its Ninja ZX-10R-inspired taillight. Blacked-out engine covers, and a black-painted silencer contribute to the supersport image. The silencer also features a buffed end-cap. ERGONOMICS The Ninja ZX-6R rider triangle remains unchanged, utilizing Kawasaki’s Ninja supersport seat to pegs-to-bar orientation, which offers a naturally aggressive riding position. A slim and flared fuel tank makes it easy for riders to grip the tank with their knees. The seat is short front-to-back for excellent comfort and feedback from the chassis. It is also narrow in the front section to help facilitate the slim riding position and make it easier for riders to get their feet on the ground. A new windshield design blends sporty looks with real-world wind protection for sport riding while also maintaining visibility during more upright street riding. An adjustable front brake lever and clutch lever each offer five available positions. This allows riders to modify both hand lever positions to suit their hand size and preference. *RIDEOLOGY THE APP is not intended for use during vehicle operation. Only use RIDEOLOGY THE APP when the vehicle is not being operated and it is safe to do so. KAWASAKI NINJA ZX-6R Color: Metallic Flat Spark Black / Ebony, Pearl Robotic White / Metallic Graphite Gray MSRP: $11,299 Availability: Now KAWASAKI NINJA ZX-6R KRT EDITION Color: Lime Green / Ebony MSRP: $11,299 Availability: Now * KAWASAKI NINJA ZX-6R ABS Color: Metallic Flat Spark Black / Ebony, Pearl Robotic White / Metallic Graphite Gray MSRP: $12,299 Availability: Now KAWASAKI NINJA ZX-6R ABS KRT EDITION Color: Lime Green / Ebony MSRP: $12,299 Availability: Now ABOUT KAWASAKI Kawasaki started full-scale production of motorcycles over a half century ago. The first Kawasaki motorcycle engine was designed based on technical know-how garnered from the development and production of aircraft engines, and Kawasaki’s entry into the motorcycle industry was driven by the company’s constant effort to develop new technologies. Numerous new Kawasaki models introduced over the years have helped shape the market, and in the process have created enduring legends based on their unique engineering, power, design and riding pleasure. In the future, Kawasaki Motors, Ltd. is committed to maintaining and furthering these strengths which will surely give birth to new legends. Kawasaki Motors Corp., U.S.A. markets and distributes Kawasaki motorcycles, ATVs, side x sides, and JET SKI® watercraft through a network of approximately 1,100 independent retailers, with close to an additional 7,700 retailers specializing in general purpose engines. Kawasaki and its affiliates employ nearly 3,100 people in the United States, with approximately 260 of them located at Kawasaki’s Foothill Ranch, California headquarters. Kawasaki’s tagline, “Let the good times roll.®”, is recognized worldwide. The Kawasaki brand is synonymous with powerful, stylish and category-leading vehicles. Information about Kawasaki’s complete line of powersports products and Kawasaki affiliates can be found on the Internet at www.kawasaki.com. The post 2024 Kawasaki Ninja ZX-6R Gets Updated 636cc Engine, Brakes, Styling appeared first on Roadracing World Magazine | Motorcycle Riding, Racing & Tech News.
[cycleworld.com] - Supersport Survivor 2024 Kawasaki ZX-6R Updated | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2023 09:58 AM |
[motorcycle.com] - CARB Filings Hint at Updated Kawasaki Z650RS for 2024 | Ninjette Newsbot | Motorcycling News | 0 | April 10th, 2023 03:54 PM |
[roadracingworld.com] - MotoAmerica: Can Escalante And His 636cc ZX-6R Be Beaten By T | Ninjette Newsbot | Motorcycling News | 0 | August 27th, 2020 05:24 AM |
[roadracingworld.com] - Kawasaki: AMA Pro Racing Homologates 636cc 2013-Model ZX-6R F | Ninjette Newsbot | General Motorcycling Discussion | 2 | March 7th, 2013 08:30 PM |
[hell for leather] - EPA document reveals 2013 Kawasaki Ninja 300, 636cc ZX-6R | Ninjette Newsbot | Motorcycling News | 0 | August 27th, 2012 02:50 PM |
