April 11th, 2013, 03:29 PM | #1 |
cuz
Join Date: Jul 2011 Motorcycle(s): 09 ninja 250r Posts: A lot.
Dunlop unbeaten 02
How do you like em?
I will most likely go w/these tires next currently on the rosso II. Im in a transition into a track oriented bike.
THE GOOD LIFE |
April 11th, 2013, 03:38 PM | #2 |
Join Date: Feb 2013 Motorcycle(s): 250 kawasaki Posts: 9
i use them on jennings on my last race.. and to me they are pretty good!!so far no complains but i havent get them to the limit yet..
April 11th, 2013, 03:43 PM | #3 |
cuz
Thanks for the input
THE GOOD LIFE |
April 11th, 2013, 03:44 PM | #4 |
cuz
What psi?
THE GOOD LIFE |
August 20th, 2013, 08:14 AM | #5 |
Join Date: Aug 2013 Motorcycle(s): CRF450X, CRF250R/SM, Husky 630 SMS, Ninja 250R Posts: 144
Also interested.
Looking at these and Bridgestones slicks; bike is a track machine only so DOT approved tire is not needed. I have tire warmers, so that's also not a problem. |
August 21st, 2013, 10:02 AM | #6 |
I like them alot, I was running Supercorsa SC1 and Rosso II rears, 110/140 combo
They have similar feel to the pirelli combo, 150 rear profile I thought was crazy but not much difference on the rear rim, we can't run slicks up here. Pirelli's and Dunlops are alot better that the BT003's. I've run the 3 combo's at The Ridge for comparisons sake I've noticed alot of bikes running the Supercorsa 110 SC1/120 SC2 rear combo as well. Run warmers on tires to keep the heat cycles to a minimum. 26/26 PSI Cold |
August 21st, 2013, 10:10 AM | #7 |
CVMA#747 Ⓓⓜⓔⓝⓣⓔⓓ ⓡⓐⓒⓘⓝⓖ
Join Date: Sep 2011 Motorcycle(s): 09 250R * 09 Yamaha R6 * 08 CBR 1000RR * 04 NSR 50 * 02 KX 250 Posts: A lot.
half of our cvma grid run bridgeston slicks. just ake sur eyou get the hardest compounds available.
**CVMA#747**AFM#747R**M1GP#77**LeoVince*RaceTech*Hotbodies*Cyclemall*Bridgestone * Motorad*Dainese*PolyMoto*Woodcraft**Visit The Dmented Racing Youtube Channel* |
August 22nd, 2013, 06:28 PM | #8 |
Join Date: Jul 2011 Motorcycle(s): Triumph Thruxton, Ninja 250 Posts: 148
I like them, but have no point of comparison as these are the only ones I've riden so far. The guys at Dunlop told me to run them at
Front 30 psi cold 33 psi hot Rear 28 Pisa cold 33 psi hot |
August 22nd, 2013, 06:42 PM | #9 |
I'm told that front is Soft and with rear I have an option of going with Soft or Med. Why do you recommend going with the harder compound? 'stones dealer actually seems to favor Soft / Soft combo.
August 22nd, 2013, 11:04 PM | #10 | |
Join Date: Nov 2010 Motorcycle(s): '09 250 Street, '09 250 Race, '13 300 Race Posts: A lot.
The front is available in ultra soft, and soft. The rear is available in ultra soft, soft, and medium. The socal bridgestone guy recommends f:soft/r:medium. He says these tires are designed for 125cc gp bikes which weight alot less than our 250s. Because of this extra weight, you need the extra stiffness the medium tires offers.
CVMA #55 |
August 23rd, 2013, 07:08 AM | #11 | |
September 29th, 2013, 10:55 PM | #12 |
Join Date: May 2012 Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike) Posts: 748
I'm running the Dunlop Unbeaten 02s. Previous to that I was running the Pirelli Diablo Supercorsa SC2 front with a Pirelli Diablo Rosso II rear.
The Dunlop Unbeaten 02s feel stiffer. I may just need more time with the Dunlops to get a feel for them. I was racing Darren pretty good using the Dunlops. Check out his latest video
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear |
October 25th, 2013, 09:46 PM | #13 | |
cuz
THE GOOD LIFE |
October 28th, 2013, 01:20 AM | #14 |
Sorry, my apologies since I have 2 sets of wheels with different sets of tires.
Going back to my post with initial settings. When I softened the settings on my emulators it made the front end a lot worst. I figured that I was actually supposed to stiffen up my emulators to actually help deaden the energy transferred since the carcass is harder and will not absorb as much as a softer carcass would. I spent a trackday testing and tuning and got it to work. However that trackday was also spent testing and tuning for my Pirelli setup. At the end of the day, I found a setting that is a compromise for both tire brands (but was slightly favoring more towards the Dunlops) Fast forward to this weekend for my races. I was on the Pirelli setup and doing something different too...The Pirellis I was actually now using a 120/70/17 slick SC2 compound and it worked phenominal with the Pirelli Rosso II rear. I was running a faster pace and so now my tire wear is faster. I wore out my rear tire past the wear bars and wanted to buy another rear tire but the Pirelli vendor was out of them. Luckily I had my other set of wheels with the Dunlop Unbeaten 02s. I went out and practice but I was a lot faster than last month's races and the chattering was back. I was near the end of what I can adjust on my emulators and decided to pull the plug. I pulled the front wheel off that had the Dunlop on there and put on the Pirelli 120/70/17 front and found out this combination actually worked really well. I was able to do lap times of 2:06's. The Dunlop vendor (Jim Cox Racing) remembered me and asked for my feedback. I told him my thoughts about the front and he told me immediately that some riders have the chattering issues and some dont. He told me the good news is that those that have the chattering issues that the solution is to use a Dunlop 211GPA medium compound 120/70/17. I spooned on a 211GPA front and tried it on practice. It felt REALLY GOOD!!! Fast forward to my races....I PR'd at 2:05.6 and ran consistent 2:06s.
October 28th, 2013, 10:19 AM | #15 |
Join Date: Aug 2012 Motorcycle(s): '13 Ninja 300, '99 SV650 tracked Posts: 378
I wanna have some of whatever Koolaid Matt was drinking this weekend, Smashing times dood. Anyone know what the smallest size a rear 211 comes in? If they make a 160 slick, would be fun to try 120/160 211's on the 300. . .
October 28th, 2013, 10:40 AM | #16 | |
As for if Dunlop makes a 211 in a smaller size than a 180, I have their fitment and data sheet and the smallest 211 GPA they make is a 160/60/17...so you can "try" to see if it will fit your bike Joel. If it clears your swingarm, I may want to give it a shot too. Joel, you don't have to really worry too much about rear grip because our bikes don't put out much power. The biggest concern with the smaller bikes and running blazing fast lap times is to make sure you have really good rubber up front since you are trying to maximize preserving momentum (heavy front tire use) instead of adding it (heavy rear tire use).
October 28th, 2013, 10:43 AM | #17 | |
CVMA #55 |
October 28th, 2013, 11:04 AM | #18 |
Dean, how bad's your 300? My lowside in front of you took care of my brake line guides, so I have tons of room for rubber. I like the idea of having bigger slicks on the bike, but yeah, I know we don't make the HP to worry about a larger contact patch. I just kinda tripped on the "twitchiness" of the 90/120 'stones, felt like there wasn't enough touching the ground, but that was my first set of track tires, and I haven't tried them again (its been a year and lotta suspension changes).
Dean, did you run Bstone slicks on your 300? |
October 28th, 2013, 01:03 PM | #19 | |
Only fairing scrapes, rearsets didn't bent in cause the folded up peg worked nicely. Tank, tail, and front untouched. Just need put a little fiberglass down. Bstone slicks can work on the 300 if you use the 250 rear rim .... But that's not quite with in the SS rules.
CVMA #55 |
October 28th, 2013, 03:13 PM | #20 |
I actually had the Bstone slicks on the 300 already, they mounted fine, even with the 4.5" rear on the 300, I just prefer a bit more rubber under me when I can. . . may try the 160 next round.
November 4th, 2013, 01:36 PM | #21 |
Joel, try the Dunlop combo of a Unbeaten 02 rear 150/60/17 and a 211 GPA medium front. The total cost for both is about $310. So far the rear is wearing much slower than the Pirelli.
November 4th, 2013, 08:28 PM | #22 |
November 5th, 2013, 11:00 AM | #23 |
Night and day difference. I'll always go with a GPA medium front.
November 7th, 2013, 02:08 PM | #24 |
Thanx Matt, spoke w/ Jim yesterday, my just try a set next round, gotta save some pennies, as I iz broke though. . . .
November 7th, 2013, 03:58 PM | #25 | |
Cool! Hopefully they work well for you. I know I like the setup.
November 7th, 2013, 04:11 PM | #26 |
Less than 30 minutes and the tires were fully cold since I didn't make it to first practice.
CVMA #55 |
November 8th, 2013, 01:31 PM | #27 |
Just curious, anyone tried the Q 3's yet? I ran a set of Q2's on the SV, and they weren't quite as sticky as the Pirelli slicks, but were still very sticky, 1/2 the cost and lasted longer. . .
November 8th, 2013, 01:37 PM | #28 | |
You can't really compare the Q2s to Pirelli slicks...apples to oranges. Street tires to pure race tires.
November 10th, 2013, 10:31 AM | #29 | |
Join Date: Sep 2012 Motorcycle(s): Daytona 675 Posts: 123
December 2nd, 2013, 09:08 AM | #30 |
Join Date: Aug 2013 Motorcycle(s): 1 2005 Ninja EX250, 1 2008 Ninja 250, 1 2009 Ninja 250 Posts: 37
Question -tires and forks
I have been following this and other threads looking at options for my son for spec 250 racing. He has been running the bt003 but we are looking at other options since some are running the Pirelli combo and some running the bstone b10 or similar on the front now in the 120 size.
If you go with this Dunlop combo with the 120 medium front do you need to make any substantial front end geometry adjustments to make it work with the non standard front size? Also where is a good starting point for pressure? We have not started using tire warmers yet either, so curious as to whether they are a requirement or not for this combo. Thanks! Steve |
December 2nd, 2013, 02:54 PM | #31 | |
You WILL need tire warmers for these though. A good starting point is to set the cold pressures at around 31 front 28 rear. I have the warmers on the tires for an hour. Right before you go out, set your hot pressures to 33 hot front and rear. After your session, or race, or whatever, put the tire warmers back on but DO NOT power them on. 20 minutes before the start of your session or race, plug the warmers back on. If the tires will be sitting for more than 2 hours of no use, then you need to do the whole cold and hot pressure setting all over again.
December 2nd, 2013, 08:25 PM | #32 | |
Could we get away with running them without warmers for one race weekend? I don't have a set yet. Thanks, Steve |
December 3rd, 2013, 11:00 AM | #33 |
Join Date: Dec 2013 Motorcycle(s): Ninja 250R (race), Aprilia Tuono 1000R, CRF250X, DR650 Posts: 18
Good info tooblekain
I just picked up a 250R to race next season with OMRRA. The bike came with Bridgestone slicks 120 front and rear. Seems to be the popular setup up here. The rear tire wear looks perfect but there is a lot of unused tire up front which makes me think the 110/140 Pirelli setup would be good size wise at least. I don't like Pirelli's though on the track so I want to try to stick with either Dunlop or Stone. Does the Unbeaten 110/150 combo wear evenly? How about when you jump up to the 120/150 combo? Does the 150 rear mount up on the stock rim? Seems like too much tire for the stock 3.5" rim... BTW, I have yet to ever turn a wheel on the bike so I am not speaking from any experience... Edit: Does Bridgestone make a 110 front slick? I have yet to see one but a 110 front with the 120 rear (125GP tire) could be a good setup. |
December 3rd, 2013, 11:09 AM | #34 | |
For the Dunlop setup, I much prefer a front using a Dunlop 211GPA medium compound 120/70/17; and for the rear a Dunlop Unbeaten 02
December 3rd, 2013, 11:17 AM | #35 | |
I never tried the Bridgestone RT10/BT003 combo yet. I did run BT003RS front and rear on someone else's Ninja 250 and got both the front and rear to slide around. I may have to give the Bridgestone RT10/BT003RS combo a try. As for the Supercorsa/Diablo Rosso II combo....its different. There are some things I like about the Dunlop setup versus the Pirelli setup...and vise versa. Its funny...my girlfriend has called me "The Tire Whisperer" before and I guess I see it now. As for running the Unbeatens without warmers, Im not so sure. Maybe contact the Dunlop distributor in your area on what he says. Or maybe contact who Ive been getting my Unbeatens from...Jim Cox of Jim Cox Racing. http://www.jimcoxracing.com/contacts.htm Jim definitely has some racing background, so I trust what he says.
December 3rd, 2013, 11:42 AM | #36 | |
Maybe with a 150 rear you would be able to get a 120 front to wear to the edge... |
December 3rd, 2013, 02:40 PM | #37 | |
FWIW. Talked to a couple of fast guys who really like the Pirelli, I haven't tried them myself though. As far as tire warmers, I think it kind of depends on the outside temp and if you're racing or track riding. I didn't run any when I raced in the summer when the outside/track temps were pretty hot with no ill effects. I did use tire warmers at the GNF when it was much cooler. Without the tire warmers I would set my tire pressure to 30 PSI front and 28 PSI rear cold. I would ride hot on the practice cool down lap and check them as soon as I came in, and adjust to 33 PSI front and back. IMO the tire warmers make it easier to set correct tire pressure. Unless it's cold out, the warm up lap is usually enough to get them up to temp. |
December 19th, 2013, 09:36 PM | #38 |
cuz
I guess Ill give them a try
I can get the pair for $200
THE GOOD LIFE |
March 12th, 2014, 08:44 PM | #39 | |
Hows the front fender clearance? Any issues with 211GPA tire? |
March 13th, 2014, 12:17 AM | #40 |
Clearance is fine for me. I am running "installed-when-I-bought-the bike" Hotbodies bodywork (including fender)
[American Motorcyclist Association] - Janniro stays unbeaten at Fast Fridays | Ninjette Newsbot | Motorcycling News | 0 | June 2nd, 2014 07:10 AM |
[crash.net - MotoGP] - Espargaro continues unbeaten run, Crutchlow misses cut | Ninjette Newsbot | Motorcycling News | 0 | March 21st, 2014 12:40 PM |
[crash.net - MotoGP] - Pedrosa unbeaten in Friday US MotoGP practice | Ninjette Newsbot | Motorcycling News | 0 | July 27th, 2012 04:10 PM |
[topix.net] - Whibley Unbeaten Again In Indiana OMA | Ninjette Newsbot | Motorcycling News | 0 | October 17th, 2011 04:00 PM |
[crash.net - MotoGP] - Capirossi unbeaten at Motegi since 2004. | Ninjette Newsbot | Motorcycling News | 0 | September 22nd, 2008 11:54 AM |
