Old April 15th, 2012, 08:05 PM   #41
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
Originally Posted by TheFranchise216 View Post
Sweet. Thanks for the info bro. A couple of my typical newbie questions: Am I ordering the "OEM EQUIVALENT keihin jets" from the right side of the page? I think that's what Blue was saying. And by "needles," you mean? I have an idea but want to make sure.
I'll order the jets and get this going. It can't hurt.
See what you have in there already, unless you don't mind ending up with a spare set of jets
Trust me, I'm a banana!
Felipe the Ant is offline   Reply With Quote
Old April 15th, 2012, 08:08 PM   #42
I use the oem equivalent 108's and have no problems. You can also use the Genuine Keihin jets on the left of the page as well. Your choice.
The needles are in your carbs. They slide up and down with the slide as more air flows through your carbs. This is because they're Constant Velocity carbs, and a larger amount of air needs a larger hole to flow at the same speed. #headspinningfactualoverload sorry.
Don't worry about the needles. You'll find those once you open up the carbs. They're in the top
Old April 15th, 2012, 08:09 PM   #43
TheFranchise216
TheFranchise216's Avatar
Motorcycle(s): 2005 Kawasaki Ninja 250
Originally Posted by Felipe the Ant View Post
If you were too rich you'll never get it started with the choke, you'll just make it worse. When you flood it you start it by winding the throttle open and trying to start it.
If your mixture was off enough to make a difference you'd know immediately because it'll run like a bag of ****.
That's exactly what it was doing before the airbox went back in. But that part seems to be taken care of now.
My guess is a vacuum leak causing the petcock to not be fully open at higher rpm. You can verify this by putting the petcock on prime and riding once you figure out how to replicate the issue. OR your float valves are gunked up not allowing enough flow at higher rpm, draining the bowls. Your floats are ok where they are because it runs
EDIT: I read the first post again and your bowls wont fill by letting it sit, sounds like you actually are rich
Could you explain your EDIT more? I'm still not exactly on point with the tech-talk just yet. What would suggest to do?
TheFranchise216 is offline   Reply With Quote
Old April 15th, 2012, 08:10 PM   #44
TheFranchise216
Can't hurt to have a spare and a nice fresh set, right?
Old April 15th, 2012, 08:11 PM   #45
eh, jets are only a few dollars each. Spare jets are never a bad thing.
Old April 15th, 2012, 08:13 PM   #46
TheFranchise216
Needles that are going through the center of the diaphragm then? That's what I thought. Just not sure where to place the washers exactly. Someone needs to create diagrams for all this stuff lol.
Old April 15th, 2012, 08:15 PM   #47
This should explain a lot:
http://www.ninjette.org/forums/showthread.php?t=11963
EDIT: this should help too.
http://faq.ninja250.org/wiki/Carburetor_photos
Old April 15th, 2012, 08:19 PM   #48
TheFranchise216
You're good at this finding stuff thing.
You said you had a Muzzy also earlier. How's yours set up? Airbox or pods? I'm assuming you use those jets you suggested to me. I ask bc since I have to take the airbox out to do the carbs, should I go with pods while I'm there?
Old April 15th, 2012, 08:24 PM   #49
Felipe the Ant
I was having second thoughts. How much cranking did you do to get it started again? If you tried a little bit and let it sit and then it started right up then it would have been flooded, but if you had to crank it forever you could have had dry bowls like I originally thought. You'd also be able to tell if it was flooded because it'd smell like a gas station
Old April 15th, 2012, 08:29 PM   #50
TheFranchise216
It was more of revving the throttle to catch and it would try to bog out so I'd rev again, etc.. until it stayed put. I wouldn't necessarily do exactly that anymore but at the time I did to get it going bc I didn't know better. But it did smell like gas after running it.. more than I thought it should.
Old April 15th, 2012, 08:36 PM   #51
Felipe the Ant
Eh, it could go either way. It's hard to say without being there. Check your jets and let us know what you find. Look at the brand as well as the size
Old April 15th, 2012, 08:43 PM   #52
I just got the Muzzy, haven't gotten it installed. I used to have Two Brothers slip-ons, and those flowed surprisingly well.
my intake/exhaust looks like this:
  • intake lid modified
  • 108 mains, 3 washers on the needles (need one more), mix screws out 2.75 turns
  • Two Brothers pipes (but will have the Muzzy installed within a day of getting home so I can ride because right now the bike just has headers)
Take the airbox out and cut off the battery box. It will make getting at the carbs tons easier, and you can still use the stock air filter and air box.
PS, there's a link in my signature to my blog, which is a list of every mod I've made to my bike, with links to many things as well.
Old April 15th, 2012, 09:15 PM   #53
TheFranchise216
My goal is to one day be able to read threads like that understand all of the technical jargon. Aim high!
Nice work on the intake cuts and nice looking bike!
Old April 15th, 2012, 09:17 PM   #54
You'll get there!
Old April 15th, 2012, 09:19 PM   #55
Felipe the Ant
fuel filter
Old April 15th, 2012, 09:26 PM   #56
TheFranchise216
After pondering the situation a bit more, this is what I'm thinking. Your thoughts are very welcome:
I'm going to take out the airbox & the carbs. So I'll almost start at square one again. Since there's a full Muzzy on it, I figure I have 2 options. First is to make it work with the airbox and original jet sizes. Second is to scratch the airbox, go with pods (I understand K&N is a good choice), and get the correct jets for that scenario. Obviously clean the carbs again while they're out just to be sure (?). I figure either way I'm most likely replacing the jets.
If I go with option #2 (since that's what was intended with the Muzzy installation) Which jets and what #s do I get? And how many 3mm washers would I need per needle?
This WILL get figured out! I thought this was a logical way to go about it and I won't be as confused. I'm ready to learn so we can celebrate success sooner than later. Thoughts?
Old April 15th, 2012, 09:41 PM   #57
Get a pair of 108's a pair of 110's and a pair of 112 main jets. Get 10 washers total (up to 5 for each needle) you will also want a pair of 40 pilot jets (just in case you have to screw the mix screws out more than 3.5 turns with the 38 pilot jets.
instructions for tuning the carbs with any combo of intake/exhaust options: http://www.factorypro.com/tech_tunin...m_engines.html
^^ when following these directions, the only difference will be with the needles. Start with 1 washer, test. 2 washers, test. 3 washers, test. 4 washers, test. 5 washers, test. Go with the best feeling number of washers.
ALSO! since you said the bike was jetted for pods, it would be a great idea to open the carbs to see what's in them. You might get lucky and they might already be set to work with a K&N R-0990
Old April 16th, 2012, 07:52 AM   #58
drdriftking007
Drdriftking007
drdriftking007's Avatar
hey bud so how is the bike going? did that JB weld work?
drdriftking007 is offline   Reply With Quote
Old April 16th, 2012, 09:50 AM   #59
TheFranchise216
I honestly haven't done it yet but it'll be done fairly soon. Been swamped with school work and distracted trying to figure out this other issue.
Old April 16th, 2012, 08:36 PM   #60
blink
Always.
blink's Avatar
Motorcycle(s): '08 Ninja 250, '05 GSX-R600
Originally Posted by greg737 View Post
Why would you post something like that?
Why would you post a reply like that?!
Sarcasm gives a sense of humor
blink-182
blink is offline   Reply With Quote
Old April 16th, 2012, 09:04 PM   #61
greg737
Motorcycle(s): -
You might need to sharpen up your understanding of the word sarcasm, paying special attention to its social/cultural context.
Old April 17th, 2012, 05:34 PM   #62
TheFranchise216
Update!!
Well.... Before I went nuts and dove into the guts of the bike, my buddy wanted to replicate the scenario as an experienced rider so he could get a feel for the situation. So what do you think happened? Yup... nothing. He came back and said it actually rode really well.
So it appears as though the temporary conclusion is that I, as a new rider, need to work on my skills coming down from a higher gear. We're going to make the same trip down the road in a day or two with him riding behind me in case I shut off again. We'll see how it goes.
Old April 17th, 2012, 05:42 PM   #63
yeah that seems weird. But make sure that if you do manage to replicate it, a) keep calm and b) pop the gas cap and leave it open to test if that fixes it.
Old April 17th, 2012, 06:57 PM   #64
blink
Always.
blink's Avatar
You needa chill out!
Go smoke some crack
blink-182
Old April 17th, 2012, 07:22 PM   #65
TheFranchise216
Definitely will! Especially the keeping calm part. Hopefully it really just is a sharpening of my riding skills.
Old April 20th, 2012, 08:06 AM   #66
Have you been able to re-create the issue? if so, have you tested opening the gas cap to get rid of possible vacuum?
If it's excess tank vacuum, I think I found the solution. Problem is, I don't know for sure if it's excess tank vacuum that's the culprit.
@TheFranchise216 and @drdriftking007 does this sound like the same thing that's happening to your bikes? (only this one didn't die completely) http://www.ninjette.org/forums/showthread.php?t=101597
Old April 20th, 2012, 01:10 PM   #67
drdriftking007
Drdriftking007
Actually I tried what you told me to do with riding with my gas tank open and everything worked fine.
Old April 20th, 2012, 01:13 PM   #68
TheFranchise216
Haven't been able to recreate yet. But I haven't really taking it out much. I've been swamped finishing up the semester. I should finally get the tank puncture sealed up this weekend and then I'll be able to take it for the ride again and hope all goes well.
bike dies with clutch pulled in slowing down robertkh100 2013 - 2017 Ninja 300 Tech Talk 62 December 24th, 2013 06:16 AM
Top Speeds? Enferno8 1986 - 2007 Ninja 250R Tech Talk 28 May 30th, 2012 05:34 PM
RPM's at speeds mohns6062 Riding Skills 1 June 7th, 2011 09:29 PM
Break in speeds! Kipawa 2008 - 2012 Ninja 250R Tech Talk 7 May 29th, 2010 06:05 PM
comfortable speeds.... im_a_ninja Riding Skills 32 August 29th, 2009 08:28 PM
