June 1st, 2012, 04:43 PM | #1 |
Join Date: May 2012 Motorcycle(s): 2007 EX250 Ninja Posts: 6
2007 Tank Hoses Placement?
So I did the airbox mod and cut my battery box off from the air box. Tried cleaning the carbs to the best of my ability and I am currently waiting for my k&n air pods in the mail. I am however, concerned that I put the wrong hoses back in the proper spots. This is how I have them set up. (1 goes to 1, 2 goes to 2 and 3 is the overflow)
June 1st, 2012, 05:29 PM | #3 |
What do you mean? This is my first bike and I been learning a good amount of basic maintenance from it (previous owner pretty much lied about taking care of it) So I have been fixing her up. What is unnecessary about what I have on the bike?
June 6th, 2012, 06:53 PM | #4 |
The Fireburd
Join Date: Jun 2012 Motorcycle(s): '02 Ninja 250 "Nikki" Posts: 2
Wow, that's a lot of extra tubes compared to what's on my '02. I wonder what it all does.
I just have one tube on the topside of the tank where number 2 is, and two tubes connected to the petcock. That was zero help huh Sorry bout that |
June 7th, 2012, 10:37 AM | #5 |
In a 49-state bike the vent system in the filler cap vents to atmosphere right at the filler cap. In California bikes there's a gasket and additional tubing at the filler cap that runs to the back of the tank and two more hoses so that the fumes can't just float away into the air (at $4/gallon!) Instead, the fumes go through one of the hoses down to a container with charcoal in it, the charcoal captures the fumes and when the bike is running the fumes are sucked out of the charcoal and burned in the engine like any other fuel.
Now sometimes liquid fuel may wind up going through that hose instead of vapors, that fuel goes to the bottom of the canister where there is a small electric pump. That pump will pump the liquid fuel back into the tank through a hose, the second of the three hoses. The third hose is the same hose that the 49-state bikes have, and it's just to drain any water that gets into the recess that the filler cap sits down inside, otherwise when you opened your filler cap on a rainy day to fill up the bike a load of water would drop right into your tank. So, to recap, there are three hoses, one for fuel liquid and vapor to be captured by the charcoal canister, one for liquid fuel to be pumped back up into the tank through, and one to drain water from the filler cap recess. It's really not complicated once you understand how it all works together, and one benefit is that your garage doesn't smell like gasoline on hot summer days from all the fuel evaporating out of the tank. |
2007 OEM Silver gas tank and front fender only | Ghostt | Items Wanted | 7 | February 17th, 2017 08:49 AM |
*WANTED* 2007 250EXE Tank bag | seth hall | Items Wanted | 0 | August 21st, 2014 08:12 AM |
2007 tank fit | Tenacity10 | 1986 - 2007 Ninja 250R Tech Talk | 6 | May 17th, 2014 11:28 AM |
hoses on my gas tank and antifreeze overflow | J>A>V | 1986 - 2007 Ninja 250R Tech Talk | 5 | July 11th, 2012 05:53 PM |
Fuel tank hoses ca model... | sixer | 2008 - 2012 Ninja 250R Tech Talk | 2 | May 2nd, 2010 05:20 PM |
