August 17th, 2015, 11:57 AM | #1 |
Help diagnosing metallic sound
Story:
Bought the bike with a seized engine. I put a ratchet on it and got it to spin relatively easily. Cleaned the carbs and it just barely started but wouldn't idle without full throttle. It had low compression in the cylinder #2 and an exhaust leak I don't remember if it had the same metallic sound. I dropped the engine to check the piston ring gaps. The bores looked fine, ring gap was a little loose but well within tolerance. valves did not leak, basically nothing was wrong with it when i opened it up. I only got it down to pulling the barrels off I did not check the crank or con rods. Put it back together and checked the timing and it will start it right away but with this horrible sound. It is firing on both cylinders but the cylinder block around #1 is very hot compared to cylinder #2. I tried unplugging one of the coils but the engine will not idle with either one of the coils unplugged. The engine will rev a little and the tapping noise gets faster. I've adjusted the cam chain tensioner and it wasn't any better. The engine will easily idle for a long time but I've only had it running for 20 seconds due to the sound. Video 1: http://youtu.be/8YUr1axV1IA Video 2, little more accurate sound: http://youtu.be/NJunGAX8ISI Video 3, best sound: http://youtu.be/Aet5jdHYrvc Last futzed with by thejaredhuang; August 18th, 2015 at 09:41 PM. |
August 17th, 2015, 01:06 PM | #2 |
Sounds like a valve adjustment, and also I noticed a manual cam chain tensioner, which is probably not adjusted properly.
Personally get rid of the manual tensioner, and double check the valve adjustment.
August 17th, 2015, 01:09 PM | #3 | |
I've cracked 2 OEM cam chain tensioners probably due to my fault. I do not like the design of them OEM one though and I'm going to stick the manual one. I know what an improperly adjusted one sounds like and I'm sure this one is adjusted adequately for now. |
August 17th, 2015, 02:14 PM | #4 | ||
I'm not a big fan of manual adjuster for common street use, track use only maybe? Often times people over tighten. True you should rebuild OEM adjuster every so often, but it's a self adjusting unit. But if you know how to adjust it properly then it's all good. When adjusting the valves make sure your using the proper scale mm or inches Quote:
http://faq.ninja250.org/wiki/What_is...t_procedure%3F http://faq.ninja250.org/wiki/Hints_%...lve_Adjustment Also if your planning on keeping the Ninjette for awhile I recommend picking up the Kawasaki tool, I found one on eBay for less than $20.00 http://faq.ninja250.org/wiki/Is_ther...this_easier%3F
August 17th, 2015, 02:19 PM | #5 | |
I'm using .003in for intake and .004in for exhaust. I'll update hopefully tonight. On a side note I listened to the video and it sounds different in person. In the video it sounds high and light but in person its lower and louder. Its almost like a hammer hitting metal. Thanks for the suggestion Ghost, I'm doing just fine with a screw driver and socket though and I'm trying to save $$$ for other projects. |
August 17th, 2015, 02:27 PM | #6 | |
It's worth checking into, just in case, and helps eliminate a variable.
Custom Carb Service Ducatiman Carb Service
August 17th, 2015, 09:37 PM | #7 |
Checked the timing and valves. Intake cam was off by one tooth, cylinder #2 exhaust valves were a little loose. Put it back together and it sounds almost the same.
New video below, I think the sound is more accurate on this video. Beware of the first 3 seconds the starter sound is kind of surprising. It sounds a little bit like an exhaust leak but I'm pretty sure it isn't. http://youtu.be/NJunGAX8ISI |
August 18th, 2015, 09:41 PM | #8 |
Just recorded a new video, the sound is pretty spot on in it. Any suggestions or ideas are welcome.
http://youtu.be/Aet5jdHYrvc |
August 19th, 2015, 02:33 AM | #9 |
Grab a piece of vinyl tubing that's pretty good sized and start listening around the bike to isolate where the noise is coming from.
Diagnosing possible electrical issues | simook | 2008 - 2012 Ninja 250R Tech Talk | 5 | January 29th, 2015 02:01 PM |
Need Help Diagnosing Bike That Wont Run | Yondaime | 2008 - 2012 Ninja 250R Tech Talk | 25 | October 4th, 2014 01:18 PM |
Help diagnosing front end clunks and knocks | dooby | 2008 - 2012 Ninja 250R Tech Talk | 6 | July 8th, 2013 04:29 PM |
Help diagnosing electrical issue | Lvr | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 16th, 2011 02:41 PM |
Need help diagnosing: Bike keeps dying | altomista | 1986 - 2007 Ninja 250R Tech Talk | 6 | July 14th, 2010 06:58 PM |
