September 11th, 2016, 07:05 AM | #1 |
Join Date: Sep 2016 Motorcycle(s): 2005 Ninja 250R Posts: 3
bolt size for gas tank
I need to replace the bolts that secure the gas tank on my 2005 Ninja (the ones accessible by removing the seat). One of them snapped and I'm not sure the other is actually the right size. A lot of bolts on this bike were stripped by the previous owner (including the drain plug- ended up drilling it out and tapping it to the next size up and that at least is resolved now) and I've been replacing them as I go. I don't necessarily trust the bolt I have to be the proper size.
What is the actual correct size for these bolts (length, diameter, thread count)? I have a repair manual for the bike but it doesn't have those measurements. |
September 11th, 2016, 07:14 AM | #2 |
Welcome, Ryan !!!
It is great that you have asked, because that particular bolt, when the wrong length is used, perforates the tank, which is a common occurrence.
September 11th, 2016, 07:15 AM | #3 | |
When you find the part number it should list the dia, length, and pitch. |
September 11th, 2016, 07:27 AM | #4 |
I did actually perforate my tank after mixing up my fairing screws. Fixed it with some epoxy putty and I learned my lesson on that one- but I'm talking about the bolts under the seat, not the fairing screws.
I looked at the diagram on kawasaki parts house - and it has the bolt in the diagram - but I can't find anything with that part number. |
September 11th, 2016, 07:48 AM | #5 | |
http://www.ronayers.com/oemparts/a/k.../fuel-tank-4-4 Part 130 is a M6x0.75 / Length from neck to tip = 10 mm Part 180 is a M6x0.75 / Length from neck to tip = 25 mm 6 mm is the exterior diameter of the bolt 0.75 mm is the pitch for fine threads of M6 Fine threads are mostly used in applications with vibrations, like a motorcycle is. https://en.wikipedia.org/wiki/ISO_metric_screw_thread
September 11th, 2016, 07:54 AM | #6 | |
Thanks for the help! |
September 11th, 2016, 07:59 AM | #7 |
You are welcome
I just added some more info to my previous post. Home Depot and Pep Boys have drawers with the type of bolts displayed. In this low-stress case, the grade of the steel does not matter.
September 11th, 2016, 11:25 PM | #8 |
Are you referring to #180?
If so, here's the part # and size 180AA0625 BOLT-UPSET-WS,6X25
September 12th, 2016, 09:06 AM | #9 |
Join Date: Jan 2015 Motorcycle(s): 2000 EX-250; several other years of the same Posts: 460
I think that he is looking for 92009.
http://faq.ninja250.org/images/7/7e/...HAIN_COVER.png 2 - 6x25mm Side Covers (6x28mm stock) http://faq.ninja250.org/wiki/Replaci...asteners/bolts
... can't stop updating the bike! |
Anyone know what size bolt goes on here? | agentbad | 1986 - 2007 Ninja 250R Tech Talk | 13 | March 24th, 2015 06:39 PM |
bolt size | james250ninja | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 5th, 2014 10:29 PM |
Dropped Bolt in Gas Tank? Major or Minor Issue? | JBinSD | 2013 - 2017 Ninja 300 Tech Talk | 19 | July 15th, 2013 08:48 PM |
93 EX250 ..Gas tank issue w/fairing bolt | rockstarcordova | 1986 - 2007 Ninja 250R Tech Talk | 6 | July 23rd, 2011 12:04 AM |
Fairing Bolt Size? | dyeclan | 2008 - 2012 Ninja 250R Tech Talk | 3 | April 10th, 2009 05:26 PM |
