Old August 31st, 2009, 09:42 AM   #1
TheAmazingKickstand
Motorcycle(s): yellow ninjette
2003 charging issue
Hey,
So the bikes 2003 with 900 miles on it. I got it with 600 miles last month and the previous owner supposedly put in a new battery right before i bought it.
Bike ran great until yesterday. We went for a 100 mile ride and all was well until I turned it off at a store 5 miles from my house.
Went to turn it on and it just went trrrrr.trrrrr.
The starter wouldnt turn but the lights were on.
Ive turned it off a number of times during the ride and no problems.
Got home and started it from my car battery with no problems. Started right away and ran perfectly.
I put a multimeter on the battery while running and it read 15.7-16.
Then turned off the bike and it read 14. The bike started perfectly under its own power a minute later.
So I'm guessing something didn;t charge the battery along the ride. Regulater/rectifier/stator????
How do I logically and properly check all of the things?
Thanks!!!!
TheAmazingKickstand is offline   Reply With Quote
Old August 31st, 2009, 10:46 AM   #2
CRXTrek
FORMER MOTORCYCLE RIDER
CRXTrek's Avatar
This "Other Forum" has good info for the old gen... http://faq.ninja250.org/wiki/Electrical_%26_Lighting
Old August 31st, 2009, 11:06 AM   #3
JCCJMM_
JCCJMM_'s Avatar
Motorcycle(s): 2007 EX250
15 to 16 volts seems a bit high. I have never seen over 14.3 at any rpm on my bike.
I would suspect the regulator in your case.
I recently had to replace my battery, it showed an open-cell voltage of 12.9 volts but would not even light up a 2 watt bulb.
Several places can load test the battery for you, some for free.
JCCJMM_ is offline   Reply With Quote
Old August 31st, 2009, 11:13 AM   #4
Snake
Snake's Avatar
Auto zone will load test your battery for you.
Old August 31st, 2009, 12:05 PM   #5
TheAmazingKickstand
16 did seem high to me. I i remember from auto shop, batteries should never be more than 15.7 while running.
Do you think the fact that i ran a heated vest for 4 hours had anything to do with it?
My FZ1 ran the vest with no problems but maybe it's too much for this little guy.
But more importantly, I was concerned about seeing 16 last night.
Old August 31st, 2009, 12:55 PM   #6
It definitely could have. A perfectly functioning charging system on the pre-gens (and new-gens, for that matter), only has a little less than 100 watts of extra juice. If you're running the high beam, it may have a little less. Depending on the heated vest, the ones I've seen vary from 50 watts up to about 100 watts. If you were running it continuously, and either the charging system wasn't working completely optimally or the battery wasn't charging perfectly, the bike could very well have been in a discharging state.
Old August 31st, 2009, 04:48 PM   #7
TheAmazingKickstand
Problem solved. It was the vest!!!
Now I need to buy a warm jacket.
Bike runs and charge fine.
Thanks
Old August 31st, 2009, 04:53 PM   #8
There are vests with electric controllers that can limit the wattage effectively. That way you can turn it way up to heat the vest up to full temp, then back it down to much lower while you're moving along, allowing the battery to come back up to full capacity. I use a Gerbing electric liner with an electronic controller all the time on the ninjette, rated at 75 watts at full bore (if I'm remembering correctly) and haven't had an issue as of yet, knock on wood.
Old August 31st, 2009, 09:24 PM   #9
TheAmazingKickstand
hmm... Im premanantly cold in life, so the vest is always turned up to 11 on the controller =). I tried it on lower settings a few times but whenever i need the vest, Im freezing.
Old September 3rd, 2009, 12:47 PM   #10
Wes
Wes's Avatar
Motorcycle(s): EX250-F14
You just need to dress better. Get some thermal undershirts and long johns. Long johns alone add about 20 degrees F of tolerance for me.
Wes is offline   Reply With Quote
Battery charging Proteus The Ex-Ninjetters Lair 7 August 5th, 2014 05:33 AM
electrical and charging trex 2008 - 2012 Ninja 250R Tech Talk 7 July 8th, 2012 02:25 PM
Charging Problem Nstoltz 1986 - 2007 Ninja 250R Tech Talk 7 May 19th, 2012 01:06 PM
Have a lean issue with my bike, issue with coasting enricher. twiggy2cents 1986 - 2007 Ninja 250R Tech Talk 7 February 24th, 2010 06:54 PM
charging the battery ajaygraci 2008 - 2012 Ninja 250R Tech Talk 11 July 23rd, 2009 03:48 PM
