April 22nd, 2011, 07:31 PM | #1 |
Fighting Texas Aggie '08
Join Date: Feb 2009 Motorcycle(s): 2008 Ninja 250r (Race), 2005 Kawasaki Ninja ZX-6R 636 (Track), 2005 Ducati Monster 620 (Street) Posts: 541
Oil level glass gauge/Frame bracket for exhaust hanger questions
The glass guage on the engine cover was cracked in my wreck at the track. On bike bandit there is a part number for the glass piece, but can it be replaced.
Also the bracket on the frame where the passanger peg/exhaust hanger connects is bent in. I couldn't straighten it out with my hands. My idea is too get a torch and heat the bracket up to help me be able to bend it, is this a bad idea? Thanks for the help Mitchell |
April 22nd, 2011, 08:44 PM | #2 |
April 22nd, 2011, 08:53 PM | #3 |
i am guessing the instructions are for expanding the metal ring and making it fit.
Any ideas on the exhaust hanger frame bracket |
April 23rd, 2011, 01:34 AM | #4 |
depends on how it's bent. pictures?
April 25th, 2011, 08:07 AM | #5 |
In my attept to bend the exhaust hanger back I was unsuccessful. I did realize though that in the accident the bolts holding on the rear passenger peg/exhaust hanger were stripped. So now my option is to take the frame to an establishment that can cut and weld the other side bracket onto this side of the frame. I do not plan on having a passenger on the back so the rear pegs do not need to to back on. Is this a bad idea?
April 25th, 2011, 03:22 PM | #6 | |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
April 25th, 2011, 03:51 PM | #7 |
ModMy250.com
I didn't bother putting it into the freezer. I'm not sure why you would want to. I drained the oil and pulled the cover off. It's pretty easy to do. Then you just tap it out with a screw driver and mallet. The new one has a rubber seal on it and you just press it in. You can tap the edges with a rubber mallet until it seats in. I replaced mine this way 7 months ago and it doesn't leak a drop. I think it took me longer to pull off the cover and put it back on than to replace the glass gauge.
The www.ModMy250.com guy |
April 25th, 2011, 04:31 PM | #8 | |
April 26th, 2011, 08:11 AM | #9 |
ModMy250.com
There's no need to make it contract. The metal ring is smaller than the hole already. I've replaced mine before and there's no need to freeze it. Just put a dab of oil on the seal and tap it in lightly with a rubber mallet.
April 26th, 2011, 09:57 AM | #10 |
Did you actualy have to remove the cover or was that by choice?
April 26th, 2011, 11:25 AM | #11 |
ModMy250.com
I wasn't sure if the sight glass was pressed in from behind or from the exterior so I removed it. It did make things a lot nicer to work with. I found that I had to punch out the old glass from the inside because the glass was cracked but still all together. There's no way to pull it out unless the glass is broken through. If it is broken through it's a good idea to take the cover off and see if there are any glass chunks inside. Either way to me, it wasn't hard. You just need to get a new clutch cover gasket and that's it.
Oil level sight glass | adouglas | General Motorcycling Discussion | 53 | May 16th, 2013 02:30 PM |
White Marks in Oil Level Gauge | dnovosel | 2008 - 2012 Ninja 250R Tech Talk | 1 | April 8th, 2013 07:36 AM |
Level in sight glass is rising! | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 17 | August 3rd, 2009 02:07 PM |
Oil level sight glass | divingtigger | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 28th, 2009 04:29 PM |
Oil Sight Glass | empyrean | 1986 - 2007 Ninja 250R Tech Talk | 7 | June 25th, 2009 10:25 AM |
