Old January 19th, 2014, 10:08 PM   #1
burnrich
burnrich's Avatar
Motorcycle(s): gpx 250
Great way to test your thermostat without taking it off the bike.
Just thought I'd share my test findings. Feel free to hang crap on my conclusions if you want
Just finished testing the thermostat on my GPX 250 as I had suspicions it wasn't opening.
I bought an Automotive DMM with inductive pick-up for this job which made it really easy as it measures temperature as well.
Once the bike had warmed up I measured the temp of the thermostat housing which was reading about 76 degrees Celsius or 168.8 Fahrenheit when the thermofan kicked in.
The workshop manual acceptable temperature range for thermostat to open is 177 -182 Fahrenheit so I figure the thermostat is still working well.
I can thank the multi meter with temperature probes for helping with this job as I didn't have to pull the thermostat out of the radiator to check the temperature so purchasing one is a must if your doing any maintenance on your bike as it reduces your workload if your lazy like me.
Of course if the thermostat housing is giving out readings well above 182 Fahrenheit then you've started to cook the engine....
"Revenge is so very, very sweet"
burnrich is offline   Reply With Quote
Old January 20th, 2014, 01:18 PM   #2
baxtc1
baxtc1's Avatar
Motorcycle(s): '92 GPX 250 (Gone and replaced with '08 V-Strom), 2005 Suzuki C50.
There is a temp gauge on the dash, keep an eye on it as the engine warms up, you will see if your thermostat is working.
baxtc1 is offline   Reply With Quote
Old January 21st, 2014, 01:55 PM   #3
burnrich
burnrich's Avatar
The purpose of the test is to gauge if the thermostat is operating within the correct temperature range according to the workshop manual. I thought the coolant was getting way to hot before it was opening and the bike was cooking a bit too long. Plus I don't trust the gauges to be accurate.
Old January 21st, 2014, 05:55 PM   #4
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
It'll never read if coolant doesn't touch it also...
Mods: Offset clutch pressure plate
Taking my road test tomorrow! corksil Riding Skills 9 September 26th, 2013 08:07 PM
Bike Won't Start After Taking It Apart bkh2 2008 - 2012 Ninja 250R Tech Talk 19 July 23rd, 2012 07:27 AM
Putting the bike on a diet - Thermostat housing removal + radiator fan 675Raisinator Ninjettes At Speed 4 July 11th, 2012 09:53 AM
Taking the bike back out! NikkitaNinja General Motorcycling Discussion 2 March 24th, 2012 08:42 AM
Birds keep taking a s**t on my bike! Matz General Motorcycling Discussion 25 November 14th, 2011 03:03 PM
