Old June 14th, 2011, 03:51 AM   #1
lonewolf05
lonewolf05's Avatar
Motorcycle(s): 09 Ninja 250R
Valve Adjustment Price
Hey guys quick question. I am planning on getting my valves adjusted and having a jet kit put in since I lost some low end power with the new exhaust. I got quoted $365 that is with the parts for valve adjustment and then me providing the jet. Just wanted to see if that sounds like a good deal? Thanks guys
09 White - Custom Carbon Fiber Undertail Exhaust w/ License Plate Bracket - K&N R-0990 - Driven 15t - DynoJet 106 Main Jets- Custom Flush Mounts - HID 5k -
lonewolf05 is offline   Reply With Quote
Old June 14th, 2011, 05:45 AM   #2
whiteboy
whiteboy's Avatar
Motorcycle(s): 2009 blue ninja 250r
See how much it would cost to do the jet yourself But to me that a little much to spend and I would find a diy
If you’re going to lead, then lead. If you’re going to follow, get the hell out of my way!
whiteboy is offline   Reply With Quote
Old June 14th, 2011, 06:41 AM   #3
TXJ
Cranky Old Fart
TXJ's Avatar
Motorcycle(s): 08 DRZ400SM
I'd invest that money in tools and DIY the whole adjustment and install if you feel comfortable with it/mechanically inclined. There are a lot of FAQs and videos online for visual aid if it's your first time.
If you're in a apartment complex or no access to a garage then that seems like a ok price for a shop to do it. The only thing I can think of to knock down the price is if you strip down the bike, put it in the back of a truck and take it down there. Might lower the price by $50-$100. If that's possible get another quote saying your bike will come in stripped down. I find to disassemble and assemble the bike harder then checking the valves. lol.
TXJ is offline   Reply With Quote
Old June 14th, 2011, 07:06 AM   #4
lonewolf05
lonewolf05's Avatar
Correction ithat price includes the jet kit and tuning it correctly
Old June 14th, 2011, 07:33 AM   #5
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
That's a good price. Valve adjustments run anywhere from 125-175. Add in the jet kit and time to tune and you're in the right ball park.
The www.ModMy250.com guy
Old June 14th, 2011, 11:40 AM   #6
lonewolf05
lonewolf05's Avatar
actually that price now includes them installing the K&N pod filter as well ... Im starting to like this place
Old June 14th, 2011, 11:46 AM   #7
lonewolf05
lonewolf05's Avatar
I do live in a townhome so no access to a garage. This is a very good shop probably 2 miles down from the dealership. I checked the dealer to see how much they would charge and $400 for the valve adjustment includes oil change, oil filter, new seals, air filter and spark plugs. To install and tune the jet kit that I need to provide would cost $300 PLUS the jet kit!
Old June 14th, 2011, 12:41 PM   #8
randomwalk101
self wrencher
randomwalk101's Avatar
I paid a guy who worked as a tech who claimed to know how to adjust valve $50 to check my valves...we worked together (and I learned the process). Honestly, I can tell he never worked on the newer gen 250 before but he knows what to look for when the valve cover was pulled...
It wasn't hard at all...do it yourself and save a bunch. My valves were still in spect after 8K miles. Next time I'll do it myself for sure. It does take a little time though.
Old June 14th, 2011, 01:12 PM   #9
lonewolf05
lonewolf05's Avatar
If the bike was like my weekend ride i would probably have attempted this myself because i like a challenge and it feels good when accomplished BUT right now this is my main mode of transportation. I have 13k miles on it and never had it checked before. I can't afford for something to take a wrong turn and it take me even longer to get my bike back up and running! I was gonna do the jet kit and air filter myself but if they have it apart there then why not? especially if they will tune it for me
Old June 14th, 2011, 01:31 PM   #10
Momaru
Momaru's Avatar
For what it's worth, this thread has prices from a bunch of other people that have had their valves checked by shops (including me for my first valve check), or at least inquired about it. $300 for valves + jetting, pod and tuning it seems like an outright steal. I had to leave my bike with the shop for several days for them to do everything, so be prepared. The valve check + maintenance is doable in a day, but add in the jetting & tuning, it'll be a LONG day for the mechanics.
That said, make SURE you ask them for both before and after clearance measurements on your valves. They have to take them anyway to do the adjustments, so it's no extra time for them. It'll tell you how bad they'd gotten and will (help) prove they actually looked at them.
Proud member of the Blue Army
Old June 15th, 2011, 12:25 AM   #11
Even independent shops quote me $280+ in San Diego. That's valves ONLY.
Old June 15th, 2011, 08:16 AM   #12
lonewolf05
lonewolf05's Avatar
Yea they said they will have to order in the parts so it will be a couple days but whatever to see the difference of $365 here vs. like $900 at the dealer im cool with
Old June 15th, 2011, 09:16 AM   #13
demonchild
Motorcycle(s): 2010 Kawasaki ninja 250R
That price is really steep to have valve adjusted and jetted. I had my bike in for a jett and valve adjustment @ Performance cycle for $180, but total bill was $220 they also did oil change and adjusted my chain. Their labor rate is $80 an hour. I brought in the jett kit and oil filter only bought oil from them. Could have done oil myself but since they offered I said what the hell. I believe their is a Performance cycle shop in Pensacola Fl, don't know where your at in Florida. Hope it works out for you.
demonchild is offline   Reply With Quote
Old June 15th, 2011, 10:20 AM   #14
WOTurtle
WOTurtle's Avatar
Motorcycle(s): 09' 250 ARRRRRR
I have almost 12k on my bike and have not had the valves checked either. A local shop here in columbia quoted me 350 just to adjust the valves. I kinda have noticed some power loss, and even a little hesitation at WOT. Could they be that much too tight by now? Stock bike, 2 shims, no snorkle. Sorry to threadjack.
WOTurtle is offline   Reply With Quote
Old June 15th, 2011, 10:36 AM   #15
lonewolf05
lonewolf05's Avatar
all good man! Yea i am at 13k miles now and never had them check until now. I just had a full exhaust and 3 washers with no snorkle. I can post up the measurements when i get my bike back!
Old June 15th, 2011, 11:08 AM   #16
Momaru
Momaru's Avatar
That could be valves getting way out of whack, restricting influx of gas (amongst other things). Alternately it could be some jets accumulating crud. Either way, you're way overdue for some service, I'd get it done before something happens that'll cost more.
Old May 12th, 2014, 10:52 AM   #17
Norway
Name: S n 0 r r £
Location: Stjoerdal, Norway (San Diego, CA, USA, 2015-2016 , Bielefeld, Nordrhein Westfalen,Germany 2021-'22)
Motorcycle(s): TMZ 5.952 "Tula" 200, Ninja 250 -Special ed. '11, ZZR 1400 (ZX14), Honda CB 1100 F Super Bol D'or
I get the impression that valve adjustments often cost in the range of 3 - 400 USD. What does it translate to in work hours?
Norway is offline   Reply With Quote
Old May 12th, 2014, 12:04 PM   #18
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
depends on the skill of mechanic and if anything needs to be replaced, most often it takes longer stripping the bike down then it does to do the adjustment.
TEAM ALFALFA
www.apexassassins.com
Old May 12th, 2014, 12:32 PM   #19
Norway
Name: S n 0 r r £
Like always, when humans (and bikes) are involved, there will be huge variations.
It probably follows some statistical distribution, with some average
number of hours and a standard deviation.
Given that a large number of Ninja 250 R owners answered, we could start
making a graph similar to the one to the upper right corner in the link below..
http://en.wikipedia.org/wiki/Standard_deviation
Old May 12th, 2014, 03:20 PM   #20
Ytse Frobozz
Not dead yet!
Ytse Frobozz's Avatar
I just did this a week ago. It had been a long time since I had done any work requiring front fairing removal, and I had to look up each step and be really methodical, so it basically took me all day to do it. Now that I've done it once, I think I could do it again in about 4 hours. I was able to get to the valve cover in under an hour the second time I took everything apart to fix my oil leak. So I figure another couple hours to actually check the valves, take the camshafts out, shuffle the shims around, and put the camshafts back in, and then another hour to put everything back together again. Don't forget to test for oil leaks before you put the fairings back on!
Ytse Frobozz is offline   Reply With Quote
Valve adjustment help jgcable 1986 - 2007 Ninja 250R Tech Talk 5 July 22nd, 2014 09:25 PM
Valve adjustment ninjaryda 1986 - 2007 Ninja 250R Tech Talk 6 April 6th, 2013 06:02 PM
Valve adjustment blink General Motorcycling Discussion 7 February 21st, 2013 01:41 PM
valve adjustment little fish 1986 - 2007 Ninja 250R Tech Talk 8 November 4th, 2011 10:10 AM
Valve Adjustment-Really Tight adjustment screw? mikesova 1986 - 2007 Ninja 250R Tech Talk 5 May 2nd, 2010 04:57 AM
