May 3rd, 2014, 12:31 PM | #1 |
Join Date: May 2014 Motorcycle(s): 2004 ninja 250 Posts: 1
04 ninja 250 carb issue
Hi there I've got a 2004 ninja 250 and when I crank the bike over to start it fuel shoots out of the overflow on the carbs.. Not sure if it's a vacuum issue or what. Any help will be greatly appreciated thanks!
May 3rd, 2014, 01:09 PM | #2 |
edit- read it wrong completely the first time. stuck float valve on your carbs. rebuild them
May 3rd, 2014, 01:59 PM | #3 |
Join Date: Dec 2013 Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD) Posts: A lot.
I am not sure of the problem you are describing but I did have a similar issue with a Vulcan 750. When the bike started the carbs would flood out and the bike would stall. This issue was incorrectly connected vacuum hoses to the vents on the carbs. Since you said your issue happens while cranking I believe the post above saying to rebuild the carb is correct. I believe the Ninja 250 has the vacuum fuel shut off so when the motor cranks (which creates vacuum) the fuel flows and there is nothing stopping it from over filling the carb. You can try pulling the bad carb(s) and cleaning the float valve seat but it would be smarter to just rebuild them since you will have them out anyways. Good luck and post up your results.
May 3rd, 2014, 03:20 PM | #4 |
/moved to pre-gen tech
Yet another Carb issue | Foxrider64 | 2008 - 2012 Ninja 250R Tech Talk | 7 | October 2nd, 2013 09:38 AM |
Carb issue | zach | 2008 - 2012 Ninja 250R Tech Talk | 4 | May 24th, 2013 10:54 AM |
carb issue. | justin_ninja | 1986 - 2007 Ninja 250R Tech Talk | 8 | January 19th, 2013 07:16 PM |
Possible Valve or Carb Issue? | schmdty420 | 1986 - 2007 Ninja 250R Tech Talk | 25 | June 20th, 2012 09:12 AM |
throttle or carb issue!!!!! | danjaho | 2008 - 2012 Ninja 250R Tech Talk | 4 | March 23rd, 2011 07:33 PM |
