Old August 7th, 2012, 09:14 AM   #1
tjkamper
tjkamper's Avatar
Head Gasket Replacement
Well boys at 22,000 and change It looks like I blew my head gasket. I have a watery mixture of oil and coolant bubbling out of the seam between the cylinder block and the head, right below the #2 cylinder exhaust port. That is what I get for running 12,000+ RPM for 60 miles a day every day for the past year. I ordered the parts I need and I will dig in this weekend. Parts should be here Monday. (Bike Bandit screwed me so I cancelled my order and went with Cheap Cycle Parts. They said that it would ship in 1-2 days, but when I placed the order they said it would take 5 to get the part, then it would ship in 1-2 days and then 2 day air. That a week and a half. Cheap Cycle Parts had it in stock and will have it to me by Monday at the latest).
Does anyone know if you put a sealant on the gasket? I didn't see any details in the manual. I hope to be running by Wednesday.
Old August 7th, 2012, 09:19 AM   #2
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
Yes
Hondabond 4 seams to have its love all over in the motorcycle community.
THE GOOD LIFE
Old August 7th, 2012, 09:22 AM   #3
cuong-nutz
cuong-nutz's Avatar
I never put any type of sealant or adhesive on head gaskets before on all my automotive rebuilds. I imagine the same goes for motorcycle engines.
HalfFast Racing Team
Old August 7th, 2012, 09:28 AM   #4
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Clean everything and use a new gasket.
If you want a copper head gasket. I payed the set up fee to have the gasket pattern put into the computer at copper head gaskets. com.
Old August 7th, 2012, 09:47 AM   #5
Clean all old gasket trace with acetone or something similar; no sealant.
Tightening sequence and proper torque will do.
Old August 7th, 2012, 10:08 AM   #6
tjkamper
tjkamper's Avatar
What is the advantage of copper, other than it's malleability for a good seal?
Any potential problems with using a copper and not the oem? This is the first time I've heard of this.
Old August 7th, 2012, 10:12 AM   #7
Racer x
Racer x's Avatar
I don't have a link to the page . But if you go on the web page for copper head gaskets . Com they have a big article . I got thicker than stock gaskets to lower compression.
Old August 7th, 2012, 09:28 PM   #8
LoD575
LoD575's Avatar
Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636
I have never heard of using any kind of sealant on head gaskets. The gasket itself with deform under torque creating a quality seal.
Seems like a copper gasket is great when dealing with modified engines as used by Racer X. For typical applications a normal crush type gasket is fine.
LoD575 is offline   Reply With Quote
Old August 8th, 2012, 09:53 AM   #9
tjkamper
tjkamper's Avatar
Thanks for the advice. I've used sealant on old engines, and on an old outboard. I also did my T/A dry (newer engine). So I just wanted to check that I will do the OEM replacement dry. Thank you all.
Posted via Mobile Device
Old August 13th, 2012, 12:21 PM   #10
tjkamper
tjkamper's Avatar
I noticed to 10 holes underneath the exhaust sports on the head. does anyone know what these are for?
Old August 13th, 2012, 01:58 PM   #11
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
On the flat machined surface? Sounds like coolant and oil passages but I haven't had mine off so I don't know what it looks like in there.
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
Gasket, Exhaust Pipe C (11009-1667) fell apart? Replacement options? Bones85 2008 - 2012 Ninja 250R Tech Talk 5 May 8th, 2013 10:31 AM
head gasket? NorthKoast 2008 - 2012 Ninja 250R Tech Talk 14 March 10th, 2012 04:01 PM
Cylinder base gasket replacement kevlar250 1986 - 2007 Ninja 250R Tech Talk 1 October 22nd, 2011 07:19 AM
Re-use old head gasket ? Tony B 1986 - 2007 Ninja 250R Tech Talk 10 June 1st, 2011 06:27 AM
copper head gasket Racer x 2008 - 2012 Ninja 250R Tech Talk 3 February 13th, 2010 05:08 PM
