October 9th, 2009, 02:48 PM | #1 |
Join Date: Jun 2009 Motorcycle(s): 2008 Ninja 250R Candy Plasma Blue Posts: 72
installed my vr exhaust!!!
woo..im freakin stoked man!.
FINALLY got my vr exhaust which sounds sexy as hell! i also rejetted it..and it running perty good....only things is it gets a very tiny bit flat between 7-8k rpms...so idk... will taken off the snorkel affect the current jetting system? |
October 9th, 2009, 03:07 PM | #2 |
It will let in more air. So you will most likely need to richen it. Is it overly loud? How about clearances around fairing?
Posted via Mobile Device |
October 9th, 2009, 04:05 PM | #3 |
The Sportisi Master
Rigo that flat spot is common in the 250's. Its hard to get rid of but you can make it less noticeable. Which map are you running?
Sportisimoto USA is born. |
October 9th, 2009, 04:22 PM | #4 | |
funny story though after all of our jetkit debates..they ended up using...a 95 main jet or something like that..the guys over at factory pro were right!!...smaller may be better..lol i definitely recommend those guys they are a frkn wealth of info.. i sure hope the brt tis wont mess with the jetting..the guys at the shop siad it shldnt..i can only pray!.... |
October 9th, 2009, 04:24 PM | #5 |
clearance is excellent! and noise..well ima young gun so noise isnt really bad for me..but my 43 year old dad liked it too!!! ...damn!...so looks like pulling the snorkel is a no go?
October 9th, 2009, 04:56 PM | #6 |
jetting should be the last thing you do.
get the bike in the configuration you want first (intake, exhaust, ignition) and then jet the bike... unless you like doing the jetting multiple times. Every time you change a performance related piece of hardware, you're going to need to fine tune jetting. |
October 9th, 2009, 04:59 PM | #7 |
The Sportisi Master
It shouldn't mess with the tis. I don't know what FP uses for a needle in their kit which is generally what dictates the main jets size. For your tis the flat spot should be less noticeable. look on the white sheet that came with it and for map one where you see the 39 in I think the 9000 spot bump it up one degree and should help even more.
October 9th, 2009, 05:00 PM | #8 |
The Sportisi Master
Also some pics would be nice
October 9th, 2009, 05:11 PM | #9 | |
in a previous thread, didn't you say the TIS required richer jetting and that was the reason you guys were recommending horrendously rich main jets? ... and now you're saying it shouldn't mess with his jetting? which way is it? |
October 9th, 2009, 05:38 PM | #10 |
The Sportisi Master
With the tis it it run fine with his current setup but going to the limits of the tis would need a bigger jet is what I have been told. I am not a jetting expert nor to I claim to be one and kelly you are right. Racer X will say one thing, Bram another, and Marc from FP another. I have a head ache because of it.
October 10th, 2009, 07:08 AM | #11 |
I was just reading GAMMA500's post and his touched the fairing a bit.
I wonder if the pipes vary, the fairing varies, or just positioning the exhaust then tightening? |
October 10th, 2009, 11:12 AM | #12 |
The Sportisi Master
I don't understand why his vr6 (the other model) was touching. All headers vary very slightly but are within spec. I haven't had anyone else report back with fairing touching. Its close but all headers for aftermarket are pretty close
October 10th, 2009, 02:58 PM | #13 |
yo ztrack can u please send me some english instructions through message to give me an idea of how to install the brt tis?..
thanks man .... |
October 10th, 2009, 03:29 PM | #14 |
The Sportisi Master
Go to my website. There's a quick intro to it on there. if your still confused then give me a call.
October 10th, 2009, 04:13 PM | #15 | |
and i have the module connected... i kinda just need to know how to program it..and where.... you know? like what u recommend. |
October 10th, 2009, 04:25 PM | #16 |
The Sportisi Master
If are you looping it or using the switch. With the control unit plugged in turn your key to the on position. lt-01 should show on the controller. Press enter. 01 should show. Now scroll to the spot on the white sheet reads 39 should be spot 16. get to 16 and hit edit you'll see 2 lines one saying 39.0 the other saying 9500. Place the 39 to 40 then hit enter. Then scroll to the 21st spot (12000rpm) and do the same moving it from 40 to 41. Then make sure everything matches up to 16000rpm (yes I know the bike won't rev that high). After you go past the 30th spot it will save. Then press menu until you hit Limit and then press edit adjust it to 13800rpm and press enter. Turn the key off and unplug the controller. Then start the bike and go for a spin. Stay close to home just in case to start. You also may want to adjust your idle. Double check the vaccuum lines too.
October 10th, 2009, 04:55 PM | #17 | |
October 10th, 2009, 05:21 PM | #18 |
The Sportisi Master
no . off is map one on is map two. Map two will be less aggressive than map 1 in the higher rpm range so use that as your default. If you wish to program map 2 I need to talk to bram first because I have only looped it to run map 1 before and don't have a programmable unit on hand right now to go figure it out. I think when lt-01 flashes if you hit enter then you can do map 2 but like I said I don't have one right in front of me.
October 10th, 2009, 05:27 PM | #19 | |
spot 16 to 40 and spot 21 to 41..and then i make sure that from 22-30 its all 40 across the board!? woo hope it works...cant wait... |
October 10th, 2009, 05:29 PM | #20 |
The Sportisi Master
no
22-30 should be at 41
October 10th, 2009, 05:30 PM | #21 |
October 10th, 2009, 05:37 PM | #22 |
The Sportisi Master
Ok Im ass backwards. ON is map1 OFF is map 2
October 10th, 2009, 05:39 PM | #23 |
October 10th, 2009, 06:42 PM | #24 |
well just got finished installing the badboy!..
i havent driven it since its cold outside adn i was shirtless and in shorts but my dad who is way more knowledgeable and experienced than me did!.... i was hoping it would make a difference and especially one that was noticeable so that he wouldnt hound me for buying this..lol on the "on" postion his words were "it is wicked"..lol..map 2 he says is about the same as stock..so looks like its mission accomplished..coming from a man who rides a m109r..they mean alot. when i ride it..ill chime in with my own review.. thanks matt! oh and i forgot to set the rev limiter of excitement..but might just leave it like that for a while.. |
October 15th, 2009, 01:49 AM | #25 |
Join Date: Oct 2009 Motorcycle(s): 2008 Kawasaki Ninja 250r Posts: 5
this is a bit off topic, i apologize... but kkim said that you shouldn't re-jet until you are done modding correct? Are there potentially any risks that I run if I were to install an exhaust and intake and did not rejet for some period of time?
October 15th, 2009, 01:57 AM | #26 | ||
I'm lovin' it.
Join Date: Feb 2009 Motorcycle(s): '09 Black 250R Posts: A lot.
Son: When I grow up I want to ride a motorbike. Father: You can't do both son. |
October 15th, 2009, 02:09 AM | #27 |
My advice was based on minimizing the number of times of having to fine tune the jetting after each mod is made. Rejetting is a slow, time consuming process.
Be advised, also, that the 250 ninja already comes lean from the factory. By adding an aftermarket exhaust and intake, you further lean out the already lean mixture. While I have not heard of anyone causing damage by just installing bolt ons, performance gains will not be fully realized unless you rejet to compensate and in some cases, diminished performance, depending on what parts you add, will result. I assume the purpose of adding an intake and exhaust is to reap some performance gains? If so, you will not realize the full gains unless you fine tune the jetting. |
October 15th, 2009, 02:35 AM | #28 |
self wrencher
What about the non-programmable one? On is still map1 and off is map2 or visa versa? I think off is map 1 (conservative) right?
October 15th, 2009, 11:47 AM | #29 |
The Sportisi Master
I'm going by what bram told me. Map one is on map 2 is off. I don't use the switch so looped is map one broken is map 2
Previous owner said he installed an exhaust from an '08... questions. | peterpayne | 1986 - 2007 Ninja 250R Tech Talk | 13 | September 23rd, 2013 08:25 AM |
Washed, and new exhaust installed! | mattmosphere88 | Pictures | 10 | April 12th, 2012 09:07 AM |
GB Area P Exhaust installed! | Bosgarage57 | 1986 - 2007 Ninja 250R Tech Talk | 17 | August 6th, 2011 05:55 PM |
Installed my Sportisi Exhaust today | CrzyFstMnM | 2008 - 2012 Ninja 250R Tech Talk | 11 | October 23rd, 2009 05:26 PM |
Installed 2 Bros Exhaust with P1 Tip | addy126 | 2008 - 2012 Ninja 250R Tech Talk | 17 | September 13th, 2009 06:59 PM |
