September 10th, 2009, 09:31 AM | #1 |
Join Date: Feb 2009 Motorcycle(s): 08 Black Ninja 205r - SOLD, Now -> a Z750 Posts: 101
no horn
My horn doesn't work now... huh
i've checked the fuse, connections...but still no sound. i'll bring to a bike shop to replace the horn. |
September 10th, 2009, 09:53 AM | #2 |
"Is that the Ninjer 1000?
Join Date: Nov 2008 Motorcycle(s): 2008 Quarter Liter Kawi Posts: 275
If the horn is indeed defective then take the opportunity to upgrade to a FIAMM horn (Less than $20 at autozone).
Nevermind I see you're not in the states.
My Mods |
September 10th, 2009, 06:21 PM | #3 |
September 10th, 2009, 06:35 PM | #4 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
One too many HTTP://s
Should be: http://www.fiammamerica.com/HornsIntro.asp and there is a great DIY here: http://www.ninjette.org/forums/showthread.php?t=14308 |
September 10th, 2009, 11:58 PM | #5 | |
anyway, it's quite hard for me to squeeze through traffic since my horn is out of order. I need to warn them not to change lane suddenly, otherwise I'm sandwiched! |
September 11th, 2009, 10:07 AM | #6 |
Horns don't go bad very often... not sayin it's not your horn, but it's probably a problem with another component in the horn system.
September 11th, 2009, 11:11 AM | #7 |
Join Date: Aug 2009 Motorcycle(s): 90 Suzuki gsx600f Katana, 03 Buell XB9R Posts: 868
Don't need a meter, just connect a light bulb between the two horn terminals, press the button and see if the light comes on. No light --> no power.
September 11th, 2009, 11:38 AM | #8 |
Join Date: Jul 2009 Motorcycle(s): 2009 Ninja 250R Posts: 157
I upgraded to the "Freeway Blaster" last week after reading the reviews here. The low end horn sounds like a truck is coming. It really wakes people up. I got it at Autozone for $17 and it was a very simple install.
www.edmcqueen.com Last futzed with by edwinmcq; September 11th, 2009 at 11:39 AM. Reason: me stupid |
September 11th, 2009, 10:02 PM | #9 |
I don't know. I don't have the mood to check the horn today. My day already ****ed up. My car suddenly broke down 3 am while getting some food from MacD and then MacD says..." Sorry sir, the order that you want is finished."... to add some more, my date also cancelled. Great.
September 12th, 2009, 12:08 AM | #10 | |
September 28th, 2009, 07:04 AM | #11 |
Okay.. the drama is continued...
After I came back from the Eid holiday, I quickly went to my usual repair workshop for some parts. They checked my electrical system and suggested that to do a by pass to the existing horn system. So, on went with the surgery. It sounded great and VERY loud. move away granny. |
Horn only works when it wants to | LNasty | 2008 - 2012 Ninja 250R Tech Talk | 15 | September 5th, 2013 10:43 PM |
Thank you Horn! | nvxdiz | Ride Reports | 11 | October 20th, 2012 12:19 PM |
Horn Not Working | Liist | 2008 - 2012 Ninja 250R Tech Talk | 2 | October 30th, 2011 11:01 AM |
Installed Stebel Nautilus air horn, a.k.a. Wolo "Bad Boy" horn | FrugalNinja250 | 1986 - 2007 Ninja 250R Farkles | 8 | June 23rd, 2011 05:37 AM |
Horn mount | mohns6062 | Items Wanted | 2 | May 27th, 2011 06:31 PM |
