Old October 7th, 2009, 01:35 PM   #1
LazinCajun
LazinCajun's Avatar
Motorcycle(s): 2008 Ninja 250 (Blue!)
Checking Coolant with the fairing on?
This is going to sound dumb...
I'm having trouble checking my coolant level with the fairing still on. I'm using the proper coolant (green, diluted properly etc.) but I just can't see where the level is inside the container with the bike upright. If I take the filler cap off with the bike on the sidestand, the coolant comes up to the level of the cap, so I can't imagine putting any more in there. I checked it with the fairing off, and the level is fine.
Is this just me? Any tips for seeing the coolant through the container while outdoors? I'd hate to have to pull a fairing off every time I want to check the level.
LazinCajun is offline   Reply With Quote
Old October 7th, 2009, 02:39 PM   #2
Kawikaze
Kawikaze's Avatar
Motorcycle(s): '09 Ninja 250R SE (Sold)
I use a mini flashlight key chain that I simply place up against the reservoir. Once the light shines through, it shows where your coolant level stands.
I started out with nothing & still have most of it left.
Kawikaze is offline   Reply With Quote
Old October 8th, 2009, 01:45 AM   #3
TrueFaith
TrueFaith's Avatar
Motorcycle(s): 2011 Honda CBR250R
I used to use a good flashlight pointed in from the radiator area or below, but it can still be difficult to see the level on a bright day. I don't know why they didn't use a clearer plastic for the coolant jug, it's just a PITA.
I got so ticked off the other day I pulled off the front of the side cover so I could fit my fingers behind the fairing to screw off the coolant cap. Just the front grommet after I had losened the phillips nut holding the side cover on. I could see the level perfectly like that and it was actually a lot easier and less aggrivating than trying to see the level with a flashlight and I didn't have to touch the fairing.
TrueFaith is offline   Reply With Quote
Old October 8th, 2009, 06:03 PM   #4
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
much easier on a dark night with a bright flashlight - seems kind of odd doesn't it.
Old October 8th, 2009, 11:50 PM   #5
I was able to see it with sunlight once shortly after I got the bike. Even a year and a half later I've had to dip in the reservoir every other time, usually after I get frustrated because I've wasted half an hour moving the bike in and out of sunlight trying my best to see it.
Old October 11th, 2009, 09:40 AM   #6
zail
zail's Avatar
Motorcycle(s): 08 Ninja 250r
I think the difficulty of seeing the coolant level is one of the most annoying things about this bike! Esp considering it's something that should be part of a regular visual check!
Bristol, UK - R&G Tail Tidy, Exhaust Hanger, Bar ends & Crash Protectors, Skidmarx Hugger & Double Bubble, SW motech mirror extenders, Scorpion Exhaust, Cycle Control levers & Rearset Adjusters
zail is offline   Reply With Quote
Hello! Checking in from CA diamond1 New Members 6 June 26th, 2013 02:48 AM
Question about checking coolant reservoir. wild-bill 2008 - 2012 Ninja 250R Tech Talk 4 January 1st, 2011 09:28 AM
[roadracingworld.com] - Fact Checking? Who's Got Time For Fact Checking? An Industry Ninjette Newsbot Motorcycling News 0 November 20th, 2009 12:40 PM
[roadracingworld.com] - Fact Checking? Who's Got Time Time For Fact Checking? An Indu Ninjette Newsbot Motorcycling News 0 November 20th, 2009 11:40 AM
