Old January 24th, 2010, 05:15 PM   #1
Underkill
Underkill's Avatar
Motorcycle(s): 08 Ninja 250, 08 KTM 250 XCF-W
Base sticker placement?
Hey there, finally got my stickers so I can ride my baby to work! (theres like 4 of them...bah) I tried to put them on the left fork leg since I plan on painting the bike soon, but they didn't stick. I have packing tape covering the stickers to help keep them on, but it's not going to work. I was thinking about peeling the stickers off the fork and taping them on the back of the windscreen. Does anyone have any other ideas?
Underkill- Because there's no such thing as overkill
Underkill is offline   Reply With Quote
Old January 26th, 2010, 01:09 AM   #2
Nickds7
Nickds7's Avatar
On the top triple t. near where you put your key, works.
Nickds7 is offline   Reply With Quote
Old January 26th, 2010, 04:30 AM   #3
Banzai
Psychic war veteran
Banzai's Avatar
Make or purchase a small plate that you can bolt on. I removed those sillly little reflectors on the front fender, and you can use one of those mounting studs. I made a small plate that mounts under the bolt on the left side fender support.
Old January 27th, 2010, 09:37 AM   #4
Duvivr6
Motorcycle(s): 09 Ninja 250R Special Ed
why do you need stickers to go on base? AF ruled those out a few years ago!
Duvivr6 is offline   Reply With Quote
Old January 27th, 2010, 05:44 PM   #5
Banzai
Psychic war veteran
Banzai's Avatar
Ashley, what service and what base are you on? I'm in the Navy onboard Norfolk (well, NPN shipyards now) with CVN71. I've seen only two other 250s on base, both red, so green really sticks out!
You're right there, the Air Force is on the right track. The trouble is, in my case, the Navy has no intention anytime in the near future of getting rid of the stickers.
It's a useless beauracracy that just eats up man hours and money printing/issuing/tracking otherwise useless stickers that are easily forged. No one gets on base anymore without an ID, but there are literallly thousands of NEXCOM authorized vendors on the naval bases in their own vehicles daily, and their IDs are easy to forge with any copier.
The more they regionalize services for the various bases in any given geographic area, the harder it becomes for the Air Force to stand out like that, though. I'm down here in Norfolk, and the Langley base refers out a LOT of it's folks to the Norfolk health clinics, which are all on Navy bases.....thus, AF folks have to get guest passes each and every time. They can't get stickers because, being Air Force and not Navy, they're not attached to COMNAVREGMIDLNAT.
To add to the butt pain, taking your bike onboard Langley, you MUST show your motorcycle safety riders card (BRC), and it must be dated within the last 3 years, day for day. As far as the Navy is concerned, it's a one time qual (for now) followed up with either Experienced Riders Course or the Sport Bike Riders Course within 90 days of BRC class.
Every time I've been on Langley (to go to the gym, no less), it's been an inquisition event at the gate because the ID and the sticker aren't good enough without matching my driver's license (to check the M endorsement), my military ID, and the BRC card. Maybe it's just because I'm a squid.......not really sure, but it's 3 for 3 so far.
Bottom line (other than it being a royal pain in the a$$), if you have to have a sticker, it's a pain in the butt. Most guys put them on the fork sliders or some out of the way place on the body work. The rest of us make/buy a plate and mount to some bolt already in place.
Incidently, I read a white paper recently on WHY the AF went away from stickers. Other than the huge amount of money that they saved NOT printing/issuing/tracking/giving a fudge about the stickers, the added benefit was one of force protection.
It seems that in non-concentrated force areas (areas with one base or very few service members) the rate of property crimes (both vehicles and dwellings) against active duty service members was well above local averages. Elemination of the stickers almost overnight brought the statistics in line with local levels. In force concentrated areas, getting rid of the stickers almost completely eleminated property crime against service members. The disparity comes from the fact that it's easier to identify service members in smaller communities than in larger ones.
None of the other services seem to have gotten the clue that that base sticker is a great big sign to would be vandals and thieves that readily identifies individuals that get paid pretty good money the 1st and 15th of every month.
Old January 28th, 2010, 07:58 AM   #6
addy126
Motorcycle(s): '09 Kawasaki N-250 + '09 Vulcan 900 Classic Lt
A sample link to inspection sticker plates which I use for parking sticker applications. Other companies provide them in a black finish. No fuss, no muss on the bike! I hate parking stickers slapped on any motorvehicle.
http://www.texascyclechrome.com/insp...plateuniv.aspx
addy126 is offline   Reply With Quote
Old January 28th, 2010, 08:11 AM   #7
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
I taped my temp reg to the inside of the windscreen facing outward when I bought the bike. It stayed there for 6-8 weeks no problems. I laminated it first so it wouldn't get wet and stuck on better. You can get laminate machines from office supply stores for scrapbooking.. we end up using it all the time for all kinds of stuff now.
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old January 28th, 2010, 10:07 AM   #8
Banzai
Psychic war veteran
Banzai's Avatar
Click here for ebay example
Old January 28th, 2010, 11:37 AM   #9
HKr1
IC2(SW)
HKr1's Avatar
Since the AF stickers were brought up. Our base mentioned they saved $200,000 a year not having them. But the funny thing is, you should see all the people with there out dated stickers on there vehicles Lazy, lazy..... lazy
+1 for some sort of plate thou
Old January 29th, 2010, 09:29 AM   #10
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
I think it is a shame that service members would be targeted for crime. Not that its ever right but especially in this day and age. My wife and her classroom run a veteran's dinner every year in appreciation. A coworker's daughter and her Marine boyfriend recently went to a nice restaurant. He was in uniform and was treated rudely by the waitor. One less restaurant on my list. Imagine some A**hole whose biggest job stress that day is to remember the specials giving rude treatment to an active military member.
Old January 29th, 2010, 11:31 PM   #11
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
i decided that i didn't wanna stick a base decal ANYWHERE on my bike. i took a piece of velcro and glued it to the 'dash-board'. top of the instrument cluster, behind the windscreen. i shaped a piece of rigid plastic for the decals with the velcro strip on one end, and a square block made of duct tape on the other to keep it level. this way i can remove it whenever i'm not riding to work. technically, i could get tagged cuz it isn't attached really 'on' the cycle, though i've had no problems with this yet. tried to take a few cell phone pix of this but...they suck'd..so will try to get some posted soon.
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
High visibility decal/sticker placement jackliu239 General Motorcycling Discussion 15 September 5th, 2013 12:24 PM
Butt camera placement Jiggles Ninjettes At Speed 4 August 7th, 2013 07:37 AM
Mirror placement and your preferences CThunder-blue General Motorcycling Discussion 18 November 11th, 2012 07:29 PM
[roadracingworld.com] - Updated: AMA Pro Racing Clarifies Patch And Sticker Placement Ninjette Newsbot Motorcycling News 0 March 6th, 2012 03:00 PM
[roadracingworld.com] - AMA Pro Racing Clarifies Patch And Sticker Placement And Usag Ninjette Newsbot Motorcycling News 0 March 6th, 2012 02:00 PM
