July 6th, 2022, 07:42 AM | #1 |
[webbikeworld.com] - 2022 Ducati Desert Sled [Specs, Features, Photos]
Click here for full story...
Desert X Too Much? Take A Look At The 2022 Ducati Scrambler Desert Sled Contents Most of the Scramblers models in the 2022 Ducati lineup haven’t been updated for the new year. The Scrambler Desert Sled remains the same for 2022. Very much a homage to the desert racers of the past from the Italian Manufacturer, it’s got red and white details on the tank and mudguards, plus a new, off-road character for tackling the dunes. While the engine has seen a bit of an upgrade to meet emissions standards in Europe, nothing drastic has changed. Ducati Motorcycle kept the motor the same 803cc Desmodromic L-twin engine as before, producing the same outputs of 73 horsepower and 48.8 lb-ft of peak torque. In terms of standard equipment, it also features the usual cornering ABS technology, with smart LED lighting and LCD instrumentation. The Desert Sled does get a few tasty mods though. These come in the form of an aluminum handlebar with a cross-strut, front stem protectors, a high front mudguard, a longer rear mudguard, and a specially designed seat for real desert scrambling. For 2022, the Scrambler Desert Sled is available in a stunning “Sparking Blue” color option with red and white details. “Look Ma! It comes with golden rims!” The 2022 Ducati Desert Sled starts at MSRP: $11,695 USD / $13,295 CDN On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Ducati Desert Sled in one place. Model Overview </p>General Info
Main Specs
Competitors
2022 Ducati Desert Sled Specifications ENGINE Engine803cc, L-Twin, Desmodromic distribution, 2 valves per cylinder, air cooledPower73 hp (53,6 kW) 8250 rpm/minBore x Stroke88 x 66 mmCompression Ratio11:1Fuel InjectionElectronic fuel injection, 50 mm throttle bodyStarterElectricExhaustStainless steel muffler with catalytic converter and 2 lambda probes, aluminium tail pipesTorque6,7 Kgm (66,2 Nm) @ 5750 rpmDRIVETRAIN ClutchHydraulically controlled slipper and self-servo wet multiplate clutchTransmission6 speedFinal DriveChain, front spocket 15, rear sprocket 46CHASSIS Suspension Front46mm fully adjustable usd forksSuspension RearKayaba rear shock, pre-load and rebound adjustable. Aluminium double-sided swingarmBrakes FrontØ330 mm disc, radial 4-piston calliper with Bosch Cornering ABS as standard equipmentBrakes RearØ245 mm disc, 1-piston floating calliper with Bosch Cornering ABS as standard equipmentTires FrontPirelli SCORPION RALLY STR 120/70 R19Tires RearPirelli SCORPION RALLY STR 170/60 R17Fuel Tank Capacity13,5 l – 3,57 gallon (US)ColorELECTRICAL IgnitionSpark PlugsHeadlightLEDTail LightLEDDIMENSIONS Max Length2.200 mm (86,6 in)Max Width940 mm (37,0 in) (mirrors)Max height1.213 mm (47,8 in) (brake reservoir)Wheelbase1.505 mm (59,3 in)Rake24°Trail112 mm (4,4 in)Seat Height860 mm (33,9 in) – low seat 840 mm (33,0 in) available as accessoryDry Weight193 kg (425,5 lb)WARRANTY Warranty24 months, Unlimited mileageExtension 2022 Ducati Desert Sled Features New livery New “Sparking Blue” livery enriched with red and white details on the tank and mudguards. This livery is a tribute to the Enduro bikes of the 80s and enhances the distinctly off-road character of the bike, along with the golden rims and the classic black frame. Premium LED Lighting Headlight with glass lens and DRL. LED turn indicators. Offroad setting High front mudguard. Extended rear fender. High plate holder. Variable cross-section handlebar. Adjustable Kayaba Suspensions with 46mm fork and 200mm excursion. Pirelli SCORPION RALLY ST tyres Front 120/70 R 19 M/C 60V M+S TL and rear 170/60 R 17 M/C 72V M+S TL tyres, for the right balance between off-road and enduro street performance. Brand new seat 860mm, with dedicated riding position. Optimize riding experience & safety Ducati Multimedia System ready. Selected gear indicator and fuel level. Handlebar switch controls. Hydraulic clutch control with adjustable lever. Dual-channel Bosch Cornering ABS. 2022 Ducati Desert Sled Photos 2022 Ducati Desert Sled Videos Links Ducati Motorcycle Official Websites Social Media Links The post 2022 Ducati Desert Sled [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Ducati Panigale V4 R [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | June 12th, 2022 04:43 AM |
[webbikeworld.com] - 2022 Ducati Multistrada V2 / V2 S [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 25th, 2022 01:27 AM |
[webbikeworld.com] - 2022 Ducati Streetfighter V4 SP [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 25th, 2022 01:11 AM |
[webbikeworld.com] - 2022 Ducati Streetfighter V2 [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 25th, 2022 12:54 AM |
[webbikeworld.com] - 2022 Ducati DesertX [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 19th, 2022 02:12 PM |
