Old January 7th, 2014, 02:26 PM   #1
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250r (Slightly Modded)
Custom Headlamp/Front Fairing Project
I was inspired to start my first DIY on my Ninja 250r. I love her but I've always wanted a unique look for her and decided to give her a facelift. I was inspired after seeing the ninja 250 rr mono, as well as JohnnyBravo's advice (don't know how to tag, otherwise I would haha).
So I threw together some photoshop garbage together for general ideas before I get some felt, and eventually fiberglass, and try to bring it life. Some of these might require a completely new light assembly, which will be the "fun" part.
But I just thought I would post these for 2nd opinion and see if anyone had some advice on the subject. I'm fairly partial on #2 and #5
Sykes92 is offline   Reply With Quote
Old January 7th, 2014, 02:37 PM   #2
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Only one of the bulbs is the normal light, the other side is the high beam. In any of your ideas, you're going to lose light output by covering your headlight.
The www.ModMy250.com guy
Old January 7th, 2014, 02:39 PM   #3
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
I think #2 might be alright because of how similar it is to the sportisi cover. But I figured I would have to make my own light assembly to account of the shapes.
I mean the entire thing could just be way too dodgy in $ and legality to pursue. But at I least I entertained the idea haha.
Old January 7th, 2014, 03:02 PM   #4
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
It looks like you are cutting your light output in half.
Old January 7th, 2014, 03:18 PM   #5
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
Well lets say the bulbs position changed to accomodate the shape. Would a stronger bulb or possible contour of the plastic allow for more output? I've seen some pretty small bulbs on some bikes, but they were older bikes. Maybe perhaps using 3 Hyosung headlamps for something like #4? Outer two would be daytime, center would be highbeam. Would that be plausible?
Old January 7th, 2014, 03:28 PM   #6
fishdip
fishdip's Avatar
I think if you did a custom light you be good.
Old January 7th, 2014, 03:57 PM   #7
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Some of the HID kit switch the headlight to having both bulbs on all the time with low beam. Just an idea if you are going to play around with the lights.
I like the second design.
<-- Linky
Old January 7th, 2014, 05:48 PM   #8
CThunder-blue
ModMy250.com
OEM headlights aren't just about bulb placement. Shifting where the bulb sits isn't easy because of how it is mounted in the headlight. Then you have to consider the reflectors and the curvature of the lens. All these things will determine your light output.
I'm not saying don't do it, but it's not as simple as you may think. You could go with custom mounting some HID projectors so you don't have to worry about the reflectors.
Old January 7th, 2014, 05:57 PM   #9
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
Sounds like HID projectors is the way to go about tinkering with it. I'll start researching and see what I can come up with in the next few weeks. Figured I should get the lighting issue out of the way before I start molding anything. But yeah definitely won't be a walk in the park haha. Thanks for the advice guys.
Old January 13th, 2014, 01:51 PM   #10
Rekognize
Rekognize's Avatar
Motorcycle(s): Ninja 300
lol... oh boy
My Ninja 300 Build Photoblog
Greater Toronto Area 250/300 Riding Group
Rekognize is offline   Reply With Quote
Old January 13th, 2014, 01:53 PM   #11
Xtina
Xtina's Avatar
Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :(
Xtina is offline   Reply With Quote
Old January 13th, 2014, 03:50 PM   #12
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
2 or 3 an throw in some HID's !!! 4&5 won't be so great,to much lost light
FYI
To link from one thread to another there is a lil button at the bottom right of the post, it's the one in the middle, then when you start your next post a lil thing is down below the post saying about you have one or more quotes from another thread, would you like to add or delete... You can go down to that an add it before you even start the post, so you can get it placed in just the spot you choose. Easy peasy once ya get used to it
Old January 13th, 2014, 03:54 PM   #13
JohnnyBravo
Some folks I ride with have race noses with HID's poking out the front.
Old January 13th, 2014, 05:00 PM   #14
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
Originally Posted by Rekognize View Post
lol... oh boy
Originally Posted by Xtina View Post
Sorry that I had an ambitious imagination and you find it amusing. I didn't say "yeah for sure I can do this no problem" I had an idea and wanted to see if it was plausible. As of right, #2 is actually pretty reasonable. Due to the fact there is already a very similar face mod for the 250 like that.
FYI
Yeah! I've seen that, it looks great! I heard it was from using an HID from a Lexus haha.
Old January 13th, 2014, 05:17 PM   #15
JohnnyBravo
This guy just has a regular car HID kit, looks like the little ones ya get for fog lights or something. Ill ask where they came from next time he is out
In the world of customs almost anything is possible... Ever see the tyranasaurus Rex at the monster truck show, a jet bike, jet truck? The list goes on.
Old January 13th, 2014, 06:48 PM   #16
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
Considering HID's are something your looking at, then I think #3 with 1 HID can be made to work the easiest.
Plz post pics as you go, luv the idea!
Old January 13th, 2014, 07:58 PM   #17
JohnnyBravo
Oh if you just wanna tag a person it's @Name and it does it all by itself like @Sykes92
Old January 13th, 2014, 08:09 PM   #18
Sykes92
Jedi on Two Wheels
Sykes92's Avatar
Ah, awesome thanks @JohnnyBravo
Old January 13th, 2014, 08:31 PM   #19
JohnnyBravo
Folks around here are pretty helpful, some ya gota catch between jokes though to get a straight answer
I tried doin the whole finding the user number and doing the mention thing myself before (not fun) total fail... Somebody finally showed me, that was a funny thread if you ever find it!
Old January 13th, 2014, 08:52 PM   #20
NevadaWolf
NevadaWolf's Avatar
Straight answer? Around here?? HA!
<-- Linky
Old January 14th, 2014, 08:02 AM   #21
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
For the HID's... I have Xentecs in my car and absolutely love them. Invest in some 3m double stick foam tape.
Don't let these hooligans get you down. Except for @Alex. Do everything he says. He is the almighty.
Oh, and #2
Old January 14th, 2014, 09:19 AM   #22
hey kids, hids and projectors are totally 2005.
the hip **** is all about LEDs. much better output than hids, no ballasts or fragile bulbs, no need for bulky projectors, the LEDs have much lower power consumption, run cooler, and can more easily be mounted pretty much anywhere. plus since they're so small you can mount them on active control surfaces for aiming patterns (aim around turns, up or down for high beams etc)
buy a spare headlamp assembly, stick it in the oven, open it up, take the reflector out, throw in a bunch of LEDs in the pattern you want (make sure to aim them correctly)
presto chango
custom headlamp.
seriously. even harley has switched to LEDs. do you really want to be behind even harley?
Old January 14th, 2014, 09:25 AM   #23
TnNinjaGirl
Ms. Personality
I want to see this
Old January 14th, 2014, 10:01 AM   #24
Old January 14th, 2014, 10:03 AM   #25
EsrTek
EsrTek's Avatar
Is that one of your bikes Alex??
Asking cause I'm curious to know how well the actual light output is when driving at night?
Old January 14th, 2014, 12:47 PM   #26
TnNinjaGirl
Ms. Personality
Yes, because while I asked to see it you should have read my mind and automatically posted a picture of the output. After all you are a man and I am a woman. That's how it works.
Old January 14th, 2014, 02:12 PM   #27
I'm not worthy!
WTB: 2001 Red fairings - right front and below headlamp saint_foo Items Wanted 0 October 25th, 2010 08:37 AM
