Old October 13th, 2009, 12:23 PM   #1
Majik
Majik's Avatar
Motorcycle(s): 2008 Ninja 250R RED!
For The Short Riders...
Before you lower your bike, try a pair of boots that will add some height to your legs first. I am 5'2" and couldn't put my feet flat on the ground. This made me too uncomfortable to ride. I didn't want to have to balance the bike on my tippy toes. The boots worked perfectly and I will not have to lower my bike now. When you are a beginner, you want to feel as safe as possible! This did it for me. Hope this helps.
Connie
Majik is offline   Reply With Quote
Old October 13th, 2009, 12:32 PM   #2
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
+1.
Work boots with lugged soles are great.
You can also get boots a size to big and put insoles in them to get even more height.
It's not the height of the heel that's important... you need extra at the ball of your foot too.
Old October 13th, 2009, 12:35 PM   #3
rockNroll
rockNroll's Avatar
Motorcycle(s): black
If just your toes are already touching, couldn't a higher heel make it so your whole sole touches? Hmmm... whole sole doesn't soud right together. Say it... whole sole.
Old October 13th, 2009, 01:03 PM   #4
HKr1
IC2(SW)
HKr1's Avatar
Old October 13th, 2009, 01:11 PM   #5
adouglas
adouglas's Avatar
You're more stable if your toe isn't pointed as much. So the more sole you can get under the ball of your foot/toe, the better.
Old October 13th, 2009, 01:13 PM   #6
zail
zail's Avatar
Motorcycle(s): 08 Ninja 250r
And the flip side of the coin ... as a shorter rider I found taller boots with thicker soles didn't suit me at all, making my feet feel clumsy and making my gear changes messy.. I prefer to tip toe and slide on the seat (which I have cut down slightly... It's all personal preference so do what works for you!
Bristol, UK - R&G Tail Tidy, Exhaust Hanger, Bar ends & Crash Protectors, Skidmarx Hugger & Double Bubble, SW motech mirror extenders, Scorpion Exhaust, Cycle Control levers & Rearset Adjusters
zail is offline   Reply With Quote
Old October 13th, 2009, 01:50 PM   #7
Talonne
Talonne's Avatar
Motorcycle(s): '09 Metallic Diablo Black
Yep, I agree totally. Heel height can help if you're just a LITTLE bit too short, and want that extra bit of stability. If you're really short, the heel won't touch the ground anyway. For example, I'd need 4" heels to have my entire foot on the ground.
The most important thing is to get as much foot on the ground as possible. Thicker soles can take you from tiptoe to ball-of-foot contact.
Talonne is offline   Reply With Quote
Old October 13th, 2009, 02:56 PM   #8
Tigress
Musical Genius
Tigress's Avatar
Motorcycle(s): 09 Ninja 250R Blue AKA "The Kid" 08 Vulcan 900 Classic Blue(for now) AKA "Honey"
Ball of foot contact works for me on The Kid. But when I was on the Katana, I didn't feel comfortable at all because of the weight and I hardly rode it.
ti·gress n.
1. A female tiger.
2. A woman regarded as daring or fierce.
Tigress is offline   Reply With Quote
Old October 13th, 2009, 05:03 PM   #9
Majik
Majik's Avatar
Tigress...yep..that's what I want..the balls of my feet on the ground. Thank goodness the boots I had (but forgot I had till recently) puts my feet all the way flat on the ground. When you are short and a weakling and a beginner, you want your feet flat...or I do anyways. Thanks for all the replies!!!
Connie
Old October 13th, 2009, 10:26 PM   #10
zartan
zartan's Avatar
Motorcycle(s): 08 250 R
Hi, Hope this helps.
I like the ICON boots they are a bit boxy but the sole rocks. Thick to add height.
Heel about an inch and then is cut back at an angle so you don't catch on the foot pegs.
I have had mine 3 years and they really take a beating. Also don't kill your feet if you want to walk around.
we are talking about less than 26 inch inseam here. I am an expert on being short
I had to lower my bike. I want a good amount of foot touching the ground. It is so easy to get off camber when stopped at intersections or coming out of driveways when there is a hill. I have been riding a loooooong time and still like that foot contact.
"Don't let adverse facts stand in the way of a good decision" Colin Powell
zartan is offline   Reply With Quote
Old October 13th, 2009, 11:01 PM   #11
emt250
2 Wheel Newb
emt250's Avatar
Motorcycle(s): 2007 250r
I use shoes with giant springs on the bottom. Its a little bouncy but I like it.
"Always remember, your mind is like a parachute. It works best when not being eaten by zombies"
-Someone
emt250 is offline   Reply With Quote
Old October 13th, 2009, 11:10 PM   #12
zartan
zartan's Avatar
well we will keep that in mind..
Old October 14th, 2009, 03:35 AM   #13
adouglas
adouglas's Avatar
Springs shmings. I rock a pair of these:
That's the real reason I don't need more than a 250. The acceleration is awesome.
It does tend to annoy the drivers following me, though....
Old October 14th, 2009, 04:13 AM   #14
bob706
bob706's Avatar
Yeah, but does it come in Kawi Green?
Old October 14th, 2009, 09:46 AM   #15
Majik
Majik's Avatar
Yall are funny! LOL!! Thanks Zartan for the info on the Icon boots. I will be looking at these soon. I have some boots that are working for now, but I'd rather have the "true" motorcycle boots and will be getting some.
Connie
Old October 15th, 2009, 01:57 AM   #16
welcome2thedawn
welcome2thedawn's Avatar
Motorcycle(s): 08 ninja 250r modded, 73 honda cl200, 74 kawasaki 400 triple
what boots do you have??? just curious...
welcome2thedawn is offline   Reply With Quote
Old October 15th, 2009, 08:48 AM   #17
Majik
Majik's Avatar
I wish I had pictures to show you. Sorry! They are burgundy colored with a 1/2 sole and the heels are stacked and are about 2 1/2 inches tall. They come up mid calf on me. I don't even know the brand of these boots because it doesn't say. I will be getting some riding boots but for now, I'll use the ones I have. I'm not riding on the highway yet...just by my house on back roads. If I were to crash, these current boots wouldn't offer much protection I'm sure!
Connie
Old October 15th, 2009, 08:52 AM   #18
Hedge36
SooperChikkin.
Hedge36's Avatar
Motorcycle(s): BMW R1200GS Adventure, '07 250 Ninja
As an added bonus, once you're off the bike you can look people in the eye
Hedge36 is offline   Reply With Quote
Old October 15th, 2009, 09:04 AM   #19
bob706
bob706's Avatar
Old October 15th, 2009, 09:12 AM   #20
Majik
Majik's Avatar
You ain't kidden!
Connie
Old October 15th, 2009, 09:18 AM   #21
Hedge36
SooperChikkin.
Hedge36's Avatar
Double-added bonus: boots making neckin' a whole lot easier.
Old October 15th, 2009, 10:41 AM   #22
DarkNinja52
DarkNinja52's Avatar
Motorcycle(s): Red 09 Ninja 250r aka Sheila (RIP), Red '10 Ninja 250r aka Sasha (Sold), White '13 Ninja 300 (To be Purchased)
Jet Boots RULE!!!!!!!!!!!!
DarkNinja52 is offline   Reply With Quote
Old October 16th, 2009, 03:19 PM   #23
LaDeeRyDer
Just go!
LaDeeRyDer's Avatar
Motorcycle(s): 06 Ninja 250 (sold) :(
I'm 5"2' as well and I'd rather tiptoe than wear thick soled boots or shoes. Like Zail, it would make it harder for me to change gears. I had A* Stella SMX4 boots that did the trick. It really is just what you prefer though.
LaDeeRyDer is offline   Reply With Quote
NORTH GA RIDERS - Official Thread! Atlanta, N.Ga, TN, NC Riders-Check for latest info BlueJeepYJ Group Rides and Local Events 946 July 13th, 2016 05:33 PM
Undeniable proof that sportbike riders are smarter that cruiser riders Sigma.40 General Motorcycling Discussion 80 March 22nd, 2014 04:41 AM
[hell for leather] - The Easiest Motorcycles For Short Riders Ninjette Newsbot Motorcycling News 0 July 24th, 2013 09:50 PM
short riders Blackwidow General Motorcycling Discussion 41 July 19th, 2010 04:18 PM
Super Sport for short riders? bluphobic General Motorcycling Discussion 40 August 25th, 2009 07:28 PM
