July 26th, 2015, 08:37 PM | #1 |
Join Date: Feb 2013 Motorcycle(s): 2014 Ninja 300 ABS, 2013 Ninja 300 ABS (RIP), 2015 FZ-09 (sold) Posts: 78
How would you approach this corner?
As the title states, how would you go around this corner? It's an off ramp in Downtown LA which requires a significant drop in speed. What makes it challenging is that the pavement has portions where it looks like very wide potholes that aren't deep but very jagged/rough so it's like riding through gravel and I can feel the rear slip the past 2 times that I have been on here. I think one way around this is just to 1) avoid this exit 2) slow to a crawl (5-10 mph) and try to navigate around the left/right side of the lane and somehow avoiding the patchy/rough areas. Any other suggestions?
July 26th, 2015, 09:45 PM | #2 |
Track Clown
MOTM - Sep '15
what speed are you traveling?
what is the posted speed? what does the warning sign say(yellow sign with black number)? what is the speed of the road you are exiting onto? |
July 26th, 2015, 10:28 PM | #3 |
MOTM - July '15
Take everything everyone on here has to say about this particular topic with a grain of salt; there are people on the internet who'll talk a lot about how they'd hit that corner dragging a knee, but only because they'll never have to prove it. Most people here are honest, but let's be real. Someone will exaggerate their abilities.
Id say, take it however you feel comfortable doing so, and dont worry about how you compare to others so much. |
July 27th, 2015, 04:57 AM | #4 |
Simple. Same as any corner.
Slow down before the bend and ride through it at the speed appropriate to the conditions. If the pavement is rough or broken, ride at the speed that will let you get through that without losing control. Get the weight off the seat... remember your MSF training. Slowing to 5-10 mph (seriously, that's jogging pace) seems extreme assuming the surface not actually loose (i.e. gravel) but impossible to say without actually seeing it. I notice that it's actually a two-lane and that half of it is marked as non-travel. Is that part broken? Is it full of debris? Does it have rumble strips? If it's just paint, use it.
July 27th, 2015, 06:25 AM | #5 |
not an actual panda
Join Date: Aug 2012 Motorcycle(s): 2008 Ninja 250, 2009 CBR600RR (Sold) Posts: A lot.
like a boss.
July 27th, 2015, 06:49 AM | #6 |
MOTM - Sep '14
A little slip of the back is not anything to worry. Take it like you have been.
And relax
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
July 27th, 2015, 07:04 AM | #7 | ||
MOTM - Mar '13, Jun '14
I'd take it in second gear at redline!
July 27th, 2015, 07:29 AM | #8 |
July 27th, 2015, 08:12 AM | #9 |
Fogwalker
Join Date: Mar 2015 Motorcycle(s): '09 Ninja 250 "Matilda" Posts: 124
I took that exit for a while when I worked in downtown. It wasn't so bad then...
I'd flash my brake lights to get the attention of the drivers behind me, then go to the left side of the lane to get the best view of what was ahead, then slow to a comfortable speed while looking as far ahead as possible. That would give me more time to see, adjust for, and avoid the pot-holes. Ride on, J~
Take care of new riders, for we were them, and they will be us. Y. Hong 2004 |
July 27th, 2015, 07:48 PM | #10 |
Thanks for the comments and suggestions everyone, I'll drag a knee through it next time Just kidding! Anyway, I usually take one of the exits before 4th, either 6th or 9th since they roads are paved better as opposed to looking like someone dragged a backhoe through the center of it. To answer some questions about the off-ramp itself, it's 1 lane with a warning sign of 20 mph and taking at my WRX at that speed today was quite a rumbly ride. It's a one lane road and the left side is an emergency lane littered with debris.
As CC Cowboy has mentioned, I will definitely get more comfortable with corners in general as I get more experience with them since I am almost relearning everything since I have only put a little over a hundred miles on this new-to-me 300. I'll probably be avoiding this off-ramp anyway because of the uneven road with random potholes scattered throughout and I was just curious to see how other riders would approach a less than ideal corner such as this. |
July 27th, 2015, 07:52 PM | #11 | |
Private Joker
MOTM - Mar '14
if it's bad you wanna go supermoto style with your foot down sliding the back wheel this I cannot do, mostly because I don't have a dirt bike/sumo more seriously though, msf style slow-look-press/lean-roll still works, if the surface is that bad then slow more and tap your brake light waving your left hand like a madman to make sure you don't get your ass rammed normally if I'm braking I'm trail braking but on a bad surface I'll get my braking done before hand and try to coast through on minimal maintenance throttle using my body to force the bike more upright...basically how I'm going to be riding in the rain for a bit since the tires I just put on my bike are basically slicks (luckily they have the dry grip to match )
July 28th, 2015, 04:52 AM | #12 |
Join Date: Oct 2011 Motorcycle(s): 06 KLR 650,12 250 Ninja, 86 DR 125, 07 CRF 100, 09 Tomos Streetmate LEL Record Holder, 88 K100 RT Posts: 434
if the surface is that bad why not look at finding another exit? Depending on depth and jaggedness (is that a word?) tires and rims take a beating. Definitely keep air pressure at recommended psi.
wardie |
July 28th, 2015, 06:57 PM | #13 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
I like this way myself.
But take the turn at what's safe which is probably Faster than you think.
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. Last futzed with by verboten1; July 29th, 2015 at 12:09 PM. |
July 29th, 2015, 05:03 PM | #14 |
٩(͡๏̯͡๏)۶
Join Date: Nov 2014 Motorcycle(s): 09 Ninja 250 held together by duct tape and zip ties Posts: 122
Just take it as slow as you need to and be smooth with the throttle. Personally, if there are pot holes and stuff, I try to lower my center of gravity as much as possible (ie put more weight on the pegs) so I can maintain balance, but really depends on the situation. And remember to look through the turn and not target fixate.
July 29th, 2015, 07:30 PM | #15 | |
The problem with that approach is that following traffic should be monitored just in case some driver decides passing you in a dangerous manner. If 20 mph is recommended, it should be a safe curve at 30 mph. It is not a race, but traffic dictates how slow is safe enough.
August 19th, 2015, 06:26 PM | #16 |
Join Date: Aug 2015 Motorcycle(s): Ninja 300, Ninja ZX6r, NSR50, XR50r Posts: 65
August 19th, 2015, 07:32 PM | #17 | |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
Anyone who who is worth their salt at ridding knows that the obvious way to approach any corner is to .....
1.) Down Shifty super slick 2.) Pin it to Win It .... 3.) Rev Limmtterrrrr ? 4.) Drift like a BOSS> So swing by sometime and I will show you how its done// Quote:
I have had a lot of experiences where my traction has been a little sketchy and my bike handles a bit freakishly. Such as my home road. They just put down oil and loose stone. While before it was a beautiful nice paved road and they ruined it. No pot holes or anything. But alas they cheap resurface it because of the tractor trailer traffic.... And I digress. When I first began ridding this after the stone was applied I slowed way down and took it super easy and steady. My bike feels wobbly and unpredictable while on this road but I have no choice I live here. I went from tooling along at 35 until I got comfortable until now I can come onto my road with a nice gentle curve at a regular speed of 20-30 mph with no noticeable lean and just roll on down the road. My back tire breaks loose sometimes when I shift and give it the gas but I have a feel for it. Basically - GET used to it gradually and if ya dont like it and can avoid it.... do that I avoid lots of crappy roads. When I am not drifting around on ramps like a BOSS @Panda
LIFE IS NOT FOR REGRETS OR EXCUSES. Breath deep, seek peace. Embrace the Madness. Life is good, let it be |
Rethinking my approach to protection/armor | adouglas | Motorcycle Gear | 49 | September 5th, 2014 10:17 AM |
[crash.net - MotoGP] - Espargaro to try FTR, corner-by-corner electronics | Ninjette Newsbot | Motorcycling News | 0 | June 15th, 2014 01:50 PM |
[superbikeplanet.com] - Do Not Approach These Men | Ninjette Newsbot | Motorcycling News | 0 | April 27th, 2012 08:50 AM |
[nytimes.com] - Italian Twins That Took a Different Approach | Ninjette Newsbot | Motorcycling News | 0 | October 29th, 2011 01:00 AM |
As I approach 10,000 miles... | adouglas | General Motorcycling Discussion | 13 | July 21st, 2011 05:07 PM |
