Old October 15th, 2009, 04:10 AM   #1
Robbo81
Robbo81's Avatar
Motorcycle(s): 250r
Rear spool thread size
Would anybody know the thread size of the rear spools for the lifting stands? I just bought a set and they gave me the wrong ones, I've got m10x 1.5. But I think they are definitely m10 but don't know if they are .25 or .75.
Oh and its for a 09 250r
Cheers
Robbo81 is offline   Reply With Quote
Old October 15th, 2009, 04:20 AM   #2
bob706
bob706's Avatar
Does the .25 and .75 indicate length of the bolt? When I got mine it was labled 10mm with no other value and they were for a zx-6 if I remember correctly. If the ones you got are made for kawis then it should fit.
Old October 15th, 2009, 04:38 AM   #3
Robbo81
Robbo81's Avatar
Motorcycle(s): 250r
the .25 is for the TPI (threads per inch) and the M10 is thickness of the bolt. on the back of the box it say's zx-6 but they still don't fit.
Old October 15th, 2009, 04:39 AM   #4
what makes you say they don't fit?
Old October 15th, 2009, 04:54 AM   #5
Robbo81
Robbo81's Avatar
Motorcycle(s): 250r
As soon as the thread makes contact it locks up. Pretty sure they are m10, just not .5
Old October 15th, 2009, 05:01 AM   #6
I guess it's possible that the spools you bought are of the wrong thread pitch, but it's unlikely. It's more likely that the threads in the spool bosses on your swingarm are notchy and perhaps not fully cut. If you have a chance to get to a dealership (or anywhere there are other bikes), try and handscrew your spools into another kawi (or any bike that has an M10 spool boss), and it's likely they will work fine. If that turns out to be the case, the fix is to clean your threads on the bike so they'll accept the spools.
Old October 15th, 2009, 05:08 AM   #7
Robbo81
Robbo81's Avatar
Motorcycle(s): 250r
Will do. thanks
Old October 15th, 2009, 11:48 AM   #8
yes, there have been bikes that had the swing arm threads for the spools filled with paint which made them difficult, if not impossible, to thread in the spools without cleaning the threads first with proper sized a tap.
Old October 15th, 2009, 07:28 PM   #9
killerkay3
killerkay3's Avatar
Motorcycle(s): 2009 Yamaha R6 / 2008 Green Ninja 250 (Sold)
i know this is a super noob question, but do i need spools to put the front tire on a stand?
killerkay3 is offline   Reply With Quote
Old October 15th, 2009, 07:31 PM   #10
Nope. Front stand is held up either by a pin through the triple tree, or on rollers at the bottom of each fork. Nothing needs to be added to the bike.
Old October 15th, 2009, 07:34 PM   #11
bob706
bob706's Avatar
No, but I think I've seen spools that are made for the front. MotorcycleSuperstore might have em.
Old October 15th, 2009, 08:04 PM   #12
HKr1
IC2(SW)
HKr1's Avatar
Kinda Yes! If you dont have spools on the rear, and up on the rear stand. You cant put the bike up on the front stand.
Old October 16th, 2009, 02:03 AM   #13
Robbo81
Robbo81's Avatar
Motorcycle(s): 250r
For anybody that needs to know, The thread size is M10 x 1.25 most other ninjas are 1.5 but not the 08/09 250r.
Old October 16th, 2009, 05:33 AM   #14
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
The bolts are indeed M10 * 1.25 however on my Ninja the holes were full of paint, I used a tap to clean the threads out. If you don’t have a tap cut a slot in the side of a bolt and that will do the trick.
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old October 16th, 2009, 05:55 AM   #15
I've seen 8mm and 10mm spools in the exact same packaging but with a dot or a mark indicating which one. They would both have something about Kawi and Honda on them, for example.
Old October 16th, 2009, 09:47 AM   #16
Thank you for that clarification.
Did you get spools on, yet?
Old October 16th, 2009, 10:53 PM   #17
Robbo81
Robbo81's Avatar
Motorcycle(s): 250r
Yep got them on. I think i'll just leave them on now.
Old August 5th, 2014, 08:34 PM   #18
CANADIENS
CANADIENS's Avatar
Motorcycle(s): 2012 NINJA 250R
I know this thread is old, however i also have encountered a M10*1.25 sized swing arm thread on my 2012 ninja 250R.... kind of a p*ss off because the spools i bought came with M10*1.5 bolts...
CANADIENS is offline   Reply With Quote
Old August 5th, 2014, 08:42 PM   #19
Most are M10 with a 1.25 pitch. Every once in awhile people are coming across ones that have the 1.5 pitch though, including one swingarm that had different pitches on either side.
Old August 18th, 2014, 12:31 AM   #20
Wickedrick
Wickedrick's Avatar
Motorcycle(s): 2011 Imperial Blue 250r
I had some problem with ebay spool thread size also, ive ordered spool and they came with one with the good tread size , the other one was off, so i asked that they resend the bolt, still bad
I finally ordered a venom stand that came with free spool and took those bolt since they were the good thread size
Wickedrick is offline   Reply With Quote
Old August 18th, 2014, 01:48 AM   #21
Skullz
Skullz's Avatar
Motorcycle(s): 2012 Ninja 250
Bought some cheap ones off ebay that came with 1 correct size and the other was an M6 for a different bike requiring me to drill it out and pop the centers out so they both looked the same, yes i could have sent them back, but the time it would have taken would have been too long and not really worth the time and effort.
Not another tire size thread!?!?? really!? gantt 2008 - 2012 Ninja 250R Tech Talk 10 March 23rd, 2015 08:01 AM
Mismatched swingarm spool thread pitch? krakatak 2008 - 2012 Ninja 250R Tech Talk 24 May 16th, 2014 09:41 AM
Spool size? spool bolt length? Runeknight95 2008 - 2012 Ninja 250R Tech Talk 1 November 29th, 2013 08:48 PM
swingarm spool bolt size? maxgohan 2008 - 2012 Ninja 250R Tech Talk 2 August 12th, 2013 02:54 PM
Thread pitch and size for Spool bolts Xuracing 2008 - 2012 Ninja 250R Tech Talk 5 July 5th, 2009 01:21 PM
