May 20th, 2013, 05:31 PM | #41 |
I know this is an old thread but im having the exact same problem and cannot find any answers....my motorcycle was running good before i cleaned the carbs and now that i did i put it back together and it dies when i use the throttle
heres a video of it |
March 14th, 2014, 03:31 PM | #42 |
Join Date: Jun 2013 Motorcycle(s): '05,06,12 yamaha r6, 2009 Ninja 250 Posts: 1
just wanted to give this thread a bit of a bump. My wife's bike is having the same issue with the bike dying on throttle up (after it's warmed up) Like others with the issue, I've done a bit of carb cleaning and all that, so I was curious if anyone's figured out the cause and/or a solution to this?
<edit> oh and look at that, this is evidently my first post on this forum. so, hello! |
March 14th, 2014, 05:12 PM | #43 | |
April 9th, 2014, 03:31 PM | #44 |
Join Date: Apr 2014 Motorcycle(s): 09 Ninja 250 Posts: 3
New here, have been lurking almost since I got my bike. I'm having the exact same problem that the user above posted a video of.
I was planning on replacing the carbs since the screws are stripped and won't budge, but last time I took them apart and cleaned them, everything seemed in order. I replaced my petcock after reading somewhere that it could be the culprit. Background: Bike was running fine for a long time, went into storage and then was ridden less and less. Finally one day it was super boggy and then eventually began behaving exactly as the video posted. Halppp! |
just cleaned carb now it bogs down and dies | toomanyproblems | 1986 - 2007 Ninja 250R Tech Talk | 27 | May 20th, 2015 05:58 AM |
Carb problem? | Carytowncat | 1986 - 2007 Ninja 250R Tech Talk | 15 | March 8th, 2014 11:21 AM |
carb problem | radioflyer | 2008 - 2012 Ninja 250R Tech Talk | 1 | July 19th, 2013 06:55 PM |
Carb Float Problem | Trainsk8 | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 4th, 2012 12:31 PM |
08 dies on idle now, is the carb cleaning covered in warranty? | novak2k9 | 2008 - 2012 Ninja 250R Tech Talk | 7 | September 6th, 2009 08:33 PM |
