Old November 18th, 2019, 01:32 PM   #1
Zbk
Zbk's Avatar
Motorcycle(s): Ninja ex250r & Ninja zx6r
Lightbulb Ninja 250R for track use only
Hello everybody !
In August I bought a ninja 250 R (2008) in completly stock version & i was preparing it for track using. At first I changed oil with oil filter and replace a air filter. After that I did some needed modifications :
- tyres - dunlop d213
- clip-ons
- laminates
- adtermarket sport footrests (with reverse gears)
- new exhaust (gpr)
- swingarm rollers
- steel brake line (hel)
- brake pads (ebs sinter)
...and this is how it looks, before mods:
..and after mods:
I have to change the crash pads mounting, and I really have to mount the short rollgas (throttle control) because the stock one is really long I don't know yet how to do it, whether to use ready-made solutions (which are quite expensive) or try to do something yourself
Zbk is offline   Reply With Quote
Old November 18th, 2019, 01:49 PM   #2
Zbk! Glad to have you aboard...
Old November 18th, 2019, 02:32 PM   #3
BoBO
BoBO's Avatar
Motorcycle(s): SC28 Fireblade
Nice! I have the same exact bike year/color. Mine is semi track/fun bike. Nice frame sliders!
94 900RR
04 BMW Z4 2.5 M Package
01 R170 AMG Sport Package
Old November 18th, 2019, 05:12 PM   #4
AwDang
Welcome!
Read this for short rollgas
https://www.ninjette.org/forums/showthread.php?t=26270
Old November 19th, 2019, 12:23 AM   #5
Zbk
Zbk's Avatar
Thanks ! i have to do some modifications with this frame sliders. Now they have one mounting point and I think that after the first accident they can bend. I want to add an adapter for two points of mounting.
Old November 19th, 2019, 12:28 AM   #6
Zbk
Zbk's Avatar
Originally Posted by AwDang View Post
Welcome!
Hi! Thank you for the tip. I will read carefully after work I have the opportunity to buy a domino set on Black Friday for PLN 500, it's about 129 USD and it is a good price here.
Earlier I used aprilia rs 2t on the track, there the rollgas was much shorter, but it was 2 stroke with a carburetor
Old November 19th, 2019, 07:23 PM   #7
Hello and welcome!
Old November 19th, 2019, 08:44 PM   #8
Tylerscott86
Tylerscott86's Avatar
Motorcycle(s): 1999 Ninja 250
Welcome aboard
Tylerscott86 is offline   Reply With Quote
Old November 19th, 2019, 09:00 PM   #9
BoBO
BoBO's Avatar
Any plans on a slip-on or full exhaust?
94 900RR
Old November 20th, 2019, 12:51 AM   #10
Zbk
Zbk's Avatar
I installed a new exhaust last weekend, but didn't take the picture. It is slip-on from GPR exhaust system. Unfortunately i can't remove the catalyst because then I will exceed the dB limit.. You can't have more than 96 dB on tracks in Poland
Old November 23rd, 2019, 06:44 PM   #11
Cool mods!
BTW, where did you get one-piece tail section? Who makes it? thx
Last futzed with by DannoXYZ; November 24th, 2019 at 11:23 AM.
Old November 24th, 2019, 10:16 AM   #12
Laguna Seca has 89db limit. This is how I get around it with full Tyga exhaust and straight-through muffler. Full Tyga is definitely worth it for +20-22% more power. No other bolt-on will give that much power increase.
Old November 24th, 2019, 10:49 AM   #13
Zbk
Zbk's Avatar
Cool mods!
One guy in Poland makes sport fairings for motorcykles, i bought from him. But in sport laminates , the tail on always one-piece. Unfortunatelly there is no acces to battery because the seat is glued in place of the screws
Old November 24th, 2019, 11:24 AM   #14
Are you using factory seat or is that foam pad?
Old November 24th, 2019, 11:27 AM   #15
Autos also do similar mods to get under Laguna Seca's 89db limit. Noise-monitor is on right side of track between turn 5 and 6. It's an uphill section, so engines tend to be loudest there.
Old November 24th, 2019, 12:57 PM   #16
Zbk
Zbk's Avatar
This is the foam pad, with these fairings can not be used the stocking seat.
These solutions in cars look crazy but it's important that they work
Old November 24th, 2019, 02:01 PM   #17
I've been looking for N250 one-piece tail like that for long time, no one in U.S. makes it. I guess shipping tail section from Poland would be expensive?
I may just convert mine by adding carbon-fibre middle section. To access screws I don't glue seat pad in corners above screw-holes. Or cut holes in foam before gluing to access screws later.
Old November 24th, 2019, 09:52 PM   #18
Welcome!
Old November 26th, 2019, 12:46 AM   #19
Zbk
Zbk's Avatar
In dedicated sport fairings, the tail is usually always one-piece, but many manufacturers do not offer a set for ninja 250.. I can send you in a private message the man who makes these fairings i you wont?
Yeah, i must cut holes in foam but unfortunatelly after gluing but I'll wait until I have to change the battery
Old November 30th, 2019, 06:53 PM   #20
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome
Old December 1st, 2019, 04:24 PM   #21
BoBO
BoBO's Avatar
I see just like in Laguna Seca. I have a slip-on with a baffle to make db limit sometimes I even short shift but it works.
94 900RR
Old December 1st, 2019, 04:28 PM   #22
BoBO
BoBO's Avatar
I did the exact same thing on my Boxster. I found a guy with a pre-welded glass pack at the track lol. I gave him two Pilot Sports for his setup.
94 900RR
Old December 23rd, 2019, 02:18 PM   #23
Zbk
Zbk's Avatar
there is no driving season so it is the garage season
almost ready
Old December 23rd, 2019, 11:22 PM   #24
liaryilera
Motorcycle(s): FielermalaRE
Hi and welcome to the forum
Apart from the aforementioned splines and plug caps I dont believe that there have been any other specific issues - I think that the reg/rec was uprated for the 700?
Colin
liaryilera is offline   Reply With Quote
Old January 19th, 2020, 09:00 AM   #25
Zbk
Zbk's Avatar
Finaly I decided to use domino solution for short rollgas and the difference is big I can't wait for the first trackday
Old January 22nd, 2020, 08:53 AM   #26
JFMNINJA400
JFMNINJA400's Avatar
Motorcycle(s): GSXR 750, GSXR 600, Ninja 400, Ninja 300
That looks sexy as hell! I went with the earlier R6 throttle mod and I loved it. I now have the later R6 throttle 06-09 and it’s even a shorter throw. Had to trim a little bit to make it spin freely. Haven’t tried it on the street yet, still too cold out!
The R6 throttle mod was less than 15 bucks!
JFMNINJA400 is offline   Reply With Quote
Old January 22nd, 2020, 04:13 PM   #27
One thing i’d like is variable-radius cam. Start out at stock size and gradually increase radius as it turns.
Old February 5th, 2020, 01:35 PM   #28
Zbk
Zbk's Avatar
Before the season, all I had to do was remove the side leg and visual details
in the meantime I invite you to my channel on YT:
https://www.youtube.com/channel/UCKZ...FQarzsGhF9UmHw
Old March 25th, 2020, 11:35 AM   #29
Zbk
Zbk's Avatar
Hi to all!
I present to you my new purchase. My second moto for road use. I bought it on last saturday
Old March 25th, 2020, 03:53 PM   #30
OOhh, Ahhh very nice!
Old March 26th, 2020, 06:29 AM   #31
Zbk
Zbk's Avatar
Due to the coronavirus, the tracks are closed and all events canceled. I hope everything is back to normal, and now I will have more time for service during this period.
Old March 29th, 2020, 04:11 PM   #32
Good-looking bike!
Old March 30th, 2020, 12:10 AM   #33
Zbk
Zbk's Avatar
I was very surprised where the oil filter is
just think how much cleaning there is ...
Old March 30th, 2020, 05:19 AM   #34
Zbk
Zbk's Avatar
Btw. breake pads in this zx6r are also a nice invention. I've never seen such before.
but for now I'm struggling with screws that are hard to move ...
Old March 30th, 2020, 07:00 AM   #35
Engineers should be forced to work with their designs in final form. Whoever designed that oil-filter assembly should be forced to change oil at least 10x !!!
ninja 250r track toy build htndfw 2008 - 2012 Ninja 250R Tech Talk 17 February 10th, 2021 10:59 AM
2009 Track Ninja 250r For sale NGagne Motorcycle-related 11 September 21st, 2015 01:11 PM
Portugal - Track-Day - Ninja 250R '10 Cabecinhas Videos 2 May 30th, 2015 01:45 PM
FS: 2012 Ninja 250R street/track combo iZapp Motorcycle-related 11 May 31st, 2014 05:11 PM
Ninja 250r track review Daeldren Videos 5 December 14th, 2009 05:16 PM
