Old August 16th, 2011, 02:09 PM   #121
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
I don't care about color, just seeing that I don't have to shift to the elusive #7 gear is good with me.
I too can pre-pay if it would help at all!
Old August 16th, 2011, 02:12 PM   #122
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
When the first five are finished I will take pre-order payments for the next set.
I may have to... to buy the parts.
Not until the first five are done. This is the test run..
I may also send you guys upgrades later or new gauges. I have tons of ideas but trying to keep it basic for now and make sure it works. Hard enough just to finish a few for now.
It works on my bike. If you guys can install the pick up switches exactly right on the sprocket cover and tap into your harness and neutral lines, it'll work on yours also.
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old August 16th, 2011, 02:14 PM   #123
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
KC What is the power output of the LED? Or can it be hooked to some sort of relay? I have an Idea for the shift light LEDs!
----> My Youtube! <----
Old August 16th, 2011, 02:37 PM   #124
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
You can hook the output to a transistor pair which can drive a heavier current load, and then to a relay.
The output is ttL level digital signal for that LED.
On off 5V, but it's only like 35mah.
In other words, yes. lol
LMFAO!
Weaksauce
Old August 16th, 2011, 03:05 PM   #125
Navigator
Motorcycle(s): 2011 Ninja 250R, 1979 Elsinore 125R
Thumbs up
Originally Posted by ninja250 View Post
Off hand does anyone know how many plug fires for one side of the engine (one cylinder) we get per revolution?
Just one right? I suppose it doesn't matter now as I can figure it out after I'm reading pulses. Just would be nice to know ahead of time for the setup.
@KC:
The plug fires 2 times per revolution. The ninja uses a "wasted spark" type ignition wherein both plugs fire at the same time: once at BTDC and another one at BBDC. As such, the plug firing frequency is double the engine rpm and you need to consider this when you do your programming. Proof of this is there's only 1 piece of trigger coil and it's for both cylinders.
The signal going to the tach is a negative-going pulse (from +12v) and it is the same signal going to the ignition coil. Be careful when you tap off of this wire because the flyback voltage of the ignition coil (NOT the voltage to the sparkplug) is a few hundred volts and it will easily fry the input ports of your processor if you connect it directly. Some signal conditioning is required.
Gear indicator: You kept mentioning "switches" and you place these inside the sprocket cover. So do you have a cam mounted on the shifter to activate these switches, or are you using magnetic switches? So 2 switches goes inside the cover, one for upshift and the other one for downshift, right?
Congratulations on the gear indicator!!!
Navigator is offline   Reply With Quote
Old August 16th, 2011, 03:11 PM   #126
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
There is already a lobe on the bike outside the sprocket cover that can be sensed when you shift.
The ball attached to the shift rod with a clamp. I sense the clamp with limit switches. I also have a neutral tap so I know when I'm in neutral.
The gauge does not missfire, but if it does it resets next time you hit neutral.
It's a hands free operation. If I add features that you can program, I will make it so you can program by using shifting inputs while the bike is turned off.
So far it already has a potentiometer onboard I can use to select what it does if I want using the programming. That will be used for RPM shift light selection though later. You'll turn the dial, the digit will read the RPM you selected, and then the LED will fire when it's time to shift as the bike hit that RPM.
I have a plan for the input already... it's sort of tricky..
all the hardware is onboard already. I just have to do the program part of the shift light.
People that want to modify or update their program can do so by purchasing the programming kit or send it back to me and I'll do it and send it back. The kit to program these chips is $100... and then needs a custom connector to fit my gauges. the programming package I use is outdated... I'm not even sure how to do it with the new USB system they use but haven't tried. I have a serial system and old software.. but they work just fine obviously.
LMFAO!
Weaksauce
Old August 16th, 2011, 07:06 PM   #127
jdoucet93
jdoucet93's Avatar
Motorcycle(s): 2009 R6
my bike is green
jdoucet93 is offline   Reply With Quote
Old August 17th, 2011, 07:33 AM   #128
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Here's my Schematic.. Minus the RPM circuit I am working on now and one or two minor changes not shown.
I'll get a wiring diagram up later.
LMFAO!
Weaksauce
Old August 17th, 2011, 07:43 AM   #129
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Going to get the switches and fuses today. Found the screws last night.. saved some money. Waiting for the final pieces to arrive. Then I'll make the switch brackets and waterproof them.
LMFAO!
Weaksauce
Old August 17th, 2011, 07:50 AM   #130
adri99an
adri99an's Avatar
Motorcycle(s): "Is that a Ninjer 1000?"
Donger likey schematic!
Posted via Mobile Device
adri99an is offline   Reply With Quote
Old August 17th, 2011, 08:06 AM   #131
Havok
Internet Slut
Havok's Avatar
Motorcycle(s): 04 FZ1, 07 FZ6
If you are still looking to have people test them I am more then happy to put one on my 250.
Havok is offline   Reply With Quote
Old August 17th, 2011, 08:24 AM   #132
DjDiablo
DjDiablo's Avatar
Motorcycle(s): Kawasaki Ninja 250R 2010 - FI - Blue
Well i was thinkg of puting on the original panel of the bike... just by the fuel indicator (here in brasil is the temperature, since we dont have fuel indicator).
By the way... do u think u could help me get a fuel indicator on my bike?
I got the FI bikes...
and all we got on that model is a light that tels us that u are almost out o f gas!!!!
I also asked if since i am in brasil and we work in km(kilometers) and not miles, if u have to do any changes for the shifting light to work???
Looking forword for testing it!!!
DjDiablo is offline   Reply With Quote
Old August 17th, 2011, 06:11 PM   #133
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
I don't think any changes will be necessary for miles or KMh.
Not sure about a fuel gauge.
Do you know if your tank has the sensor on it?
Just picked up all the switches and fuses for each unit.
We're just past the testing stage. Now we're to the first public trial run!
I tested the second one out today and no problems to speak of!
LMFAO!
Weaksauce
Old August 17th, 2011, 06:14 PM   #134
DjDiablo
DjDiablo's Avatar
As far as i know there is a sensor...
dont realy know how it works...
what i know is that when it is almost empty it stat to light a light on the panel warning me that i hava almost no fuel
Old August 17th, 2011, 10:27 PM   #135
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Almost have everything together for 5 kits.
I need to make switch brackets and I'm waiting on digits and processors in the mail. Just about all caught up.
Straight after these are done and shipped I'm going to the RPM addition.
Doesn't look like much but dang that cost me a grip of money to produce. lol
I hope you guys are good at installations. This one will test your patience/skill but I can assure you it works when I install it.. and quite well.
I drove it around today for three hours in 100* weather with no problems even though it runs hot.
I was really pleased with the visibility in the bright sun! I put it down in the fairing some and could see it all day no problem.
LMFAO!
Weaksauce
Old August 17th, 2011, 11:57 PM   #136
headshrink
headshrink's Avatar
What is the RPM addition?
EDIT: Just re-read a couple posts up.
Does V1.0 still give the ability to adjust the shift point relative to RPM? I gathered V1.0 & V2.0 functionally do the same thing, with 2.0 having an easier way to set the shift point.... Did I get that right?
Old August 18th, 2011, 05:11 AM   #137
wellcraft
wellcraft's Avatar
Motorcycle(s): Ninja 250R
The next one will be super bright white.
I have a white LED that is three times as bright as the blue or green. lol 7000mcd vs 2000mcd
The first five people to get them will each get a different color LED and maybe even each some different program lines? I think I also have amber and yellow after the white I forget.
I can't complete any more until more parts come but I'm working around those parts and finishing up what I can ahead of time. Gotta go get switches pretty soon. I have the switch screws around here too have to find them so I don't have to buy more.
Please, count me in for the first run. I commute every day around 50 miles so I can give you a lot of report.
Very.interested in one.
wellcraft is offline   Reply With Quote
Old August 18th, 2011, 05:12 AM   #138
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
For now the gauge only displays current gear, and the LED fires when the gauge detects a shift. (just a little visual indicator you made a complete shift for now)
Later, the LED will be adjustable to fire when you want to shift at your desired RPM.
The hardware is included already with the gauge onboard, I just have to add a program later for the shift light to work. For now it's just on there looking good and letting you know if you turn the bike on without being in neutral. Will explain more later.
LMFAO!
Weaksauce
Old August 18th, 2011, 10:15 AM   #139
EsrTek
EsrTek's Avatar
Sounds good man.. thanks for the time and effort put into getting these to work !!
Old August 18th, 2011, 12:38 PM   #140
key3thermal
key3thermal's Avatar
Motorcycle(s): 2009 Ninja 250r Blue
awesome, i better be the first person on the second run!
key3thermal is offline   Reply With Quote
Old August 18th, 2011, 08:38 PM   #141
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
It looks as though there will be one freed up if anyone is interested.
The question is which one of you.
I believe Alex is going to set up a group buy shift gauge thread but leave this thread here for tech support when you guys get the gauges and need install help. If that's what he decides to do.
Discussion of the selling of the gauges has to be kept to the market place from now on.
LMFAO!
Weaksauce
Old August 18th, 2011, 08:43 PM   #142
For sale thread ---> here
Old August 28th, 2011, 01:19 PM   #143
jdoucet93
jdoucet93's Avatar
Originally Posted by Phil7153 View Post
I might have missed it, but how exactly are these installed? Are they plug and play or have to do some technical wiring?
this should answer just about any questions you have
http://www.ninjette.org/forums/showthread.php?t=82970
Old September 3rd, 2011, 09:29 PM   #144
PlaneGuy
Annoying gadfly
PlaneGuy's Avatar
Motorcycle(s): 2006 Ninja EX250R
Sorry for the late post. I am new to the forum. I build stuff like this too. I have a complete hot air reflow SMD rework bench at home if you need some help getting boards stuffed.
BTW, if you want a clean, reliable source of RPM info, pick off one of the stator windings in the alternator. No potential high-voltage spikes you need to clamp.
I did look through and try to find what you were using as a gear position sensor but must have missed it.
I am interested but have one of the older carbureted ninjettes (2006).
Brian --
World domination through science!
PlaneGuy is offline   Reply With Quote
Old September 7th, 2011, 10:23 PM   #145
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Cool!
Perhaps you actually can be of some help at some point.
Sorry, missed your post for a bit there. We can set you up on the pre-gen too, I don't see why not.
I wouldn't mind having a pregen myself now, like the one they tried to sell me back in '05.
I'm in the middle of gathering resources to complete the second step of the programming now but a good chunk of assembly is sure to follow.
I have actually installed a few gauges on bikes by now that work.
Friday I have another appointment to finish up Adrian's In-Dash gauge after which I'll try and get more video.
Tomorrow have to catch up with crap around home and Sat have more work to do on Sixe'rs bike.
I think sunday or Monday I can come back to the gauges to present what I have completed.
Busy Busy Busy.
The fishing club is wondering where I've been!
LMFAO!
Weaksauce
Old January 14th, 2012, 06:10 PM   #146
icbm
icbm's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250R, 2006 Suzuki Hayabusa GSX1300R, 2004 Kawasaki ZRX1200R, 1985 Kawasaki 750 Turbo
Are these being made anymore?
icbm is offline   Reply With Quote
Old January 14th, 2012, 06:26 PM   #147
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
I haven't made any more of the ones I was making for a while.
For some reason unknown to me, they were working on some people's bikes and not others'.
One of these days, I need to build a more reliable version.
I think it was something to do with my power regulator design on the board.
The program I wrote seemed to work great.
I may get working on them again one day if there is enough interest.
I think there is people making them in China now to fit any bike though and selling them on ebay.
If they work, I can't compete with China.
I put several hundred bucks into this project and ended up getting nowhere with it.
If I could get somebody to help fund a third and better working version, I'd give it a go.
LMFAO!
Weaksauce
Old January 21st, 2014, 03:08 PM   #148
corksil
Motorcycle(s): A lot.
Dead in the water?
Old January 21st, 2014, 05:22 PM   #149
headshrink
headshrink's Avatar
Originally Posted by corksil View Post
Dead in the water?
He hasn't been heard from since..... hope he's ok.
Old February 18th, 2014, 02:08 AM   #150
DuplexUno
Motorcycle(s): CharlesdiubsOB
has this been finished yet because i would be interested in one
DuplexUno is offline   Reply With Quote
Old February 18th, 2014, 02:20 AM   #151
headshrink
headshrink's Avatar
The project was terminated long ago.
He couldn't source parts for less than what the ebay indicator sells for in a smaller package.... with China and all.
Old February 18th, 2014, 02:35 AM   #152
DuplexUno
Damn
Old February 18th, 2014, 02:57 AM   #153
headshrink
headshrink's Avatar
Get the ebay one. It's a little better for 1/4 to 1/3 the cost (but no shift light).
Old February 19th, 2014, 08:19 PM   #154
Hunsy34
Hunsy34's Avatar
Motorcycle(s): 2009 Ninja 250 2016 Ninja 300 1994 KTM 300 EXC
Link to the ones on ebay?
Hunsy34 is offline   Reply With Quote
Economy light to Shift light??? Tigerpaw 2013 - 2017 Ninja 300 Tech Talk 36 December 11th, 2012 05:32 PM
Shift Light, Gear Indicator, Temp Gauge - WHERE ARE YOU???!!! 2013 kawi girl 2013 - 2017 Ninja 300 General Discussion 14 October 21st, 2012 12:00 AM
Gauging Interest: Gear Indicators (one with shift light, one without shiftlight) SlowBoyRacing Motorcycle-related 13 March 2nd, 2012 11:27 PM
Shift Light / Gear Indicator - Custom by ninja250 ninja250 Motorcycle-related 277 February 4th, 2012 11:25 PM
Home-made Shift Light is now running!!! Navigator 2008 - 2012 Ninja 250R Farkles 14 August 29th, 2011 09:05 PM
