December 28th, 2014, 04:10 PM | #1 |
Join Date: Aug 2012 Motorcycle(s): ex300, gave up looking for a 250 Posts: 435
Bursig center lift stand (Ninja 300)
A search didn't turn up anything so I figured I'd post this up in case anyone was interested.
It's packed almost fully assembled. You just need to attach the handle and screw in the allen screws for the wheels. You can also screw in rubber feet instead which aren't included but should be free if you request them. How it lifts the bike. The top plastic? "pin" is threaded and goes over a long bolt like a very long nut and the bottom pin acts like a regular nut with a shorter bolt. The bottom pin comes out of the box loose so you're supposed to position it yourself but it's not super easy to get the adjustment right because the slot for lower pin is effectively angled so you're adjusting two dimensions at once away from the bike. The allen bolt at the top will adjust and hold the angle of the whole plate. This is the lower position. The front wheel is about a D cell battery high and the back can clear a chain cleaner spray can. This is the higher position (about 3/4" higher). The front almost clears the can. On my second try, I finally adjusted it so it goes in pretty easily. You do have to balance the bike momentarily (that moment of faith) with the kickstand up but it's not too bad. Taking it out is a little sticky sometimes. To lower the bike you have to relieve the pressure on the pin by raising the bike a bit so you won't be surprised and smacked in the head by the handle. The wheels are small so they catch on my garage's deep (inverted triangle) seams if you roll it too slowly. Two wheels have brakes to keep the stand in place. Overall, I'm pretty happy with it. I can easily roll the bike into the corner now instead of doing an Austin Powers routine. One fringe benefit is being able to check the oil sight glass if you don't raise the bike at all. That always seems sketchy to me. |
December 28th, 2014, 06:28 PM | #2 | |
Long Time Rider
Kawasaki Center Lift Paddock Stand | DaBlue1 | 2008 - 2012 Ninja 250R Farkles | 38 | September 21st, 2015 02:03 PM |
[motorcycledaily.com] - MD Product Review: The Bursig Stand (News) (Product Reviews) | Ninjette Newsbot | Motorcycling News | 0 | October 21st, 2013 05:00 PM |
Center Stand for 300/250 | old3 | General Motorcycling Discussion | 5 | August 4th, 2013 08:06 PM |
Ninja 250 Center stand install pictures | 510triple | 1986 - 2007 Ninja 250R Farkles | 12 | May 7th, 2013 06:40 PM |
Center stand for 2004 Ninja | 510triple | 1986 - 2007 Ninja 250R Tech Talk | 2 | April 18th, 2013 12:16 AM |
