Old February 13th, 2010, 11:19 PM   #1
aloh
lolwut
aloh's Avatar
Unhappy Motor Problems...need help!
UPDATE!
Installed the Factory Pro jet kit along with the AreaP exhaust system I picked up from their shop a couple weeks ago. Seems like all of my previous motor problems are all gone after these changes! It was a pain removing the airbox, but it was definitely worth it. Working on the bike will be so much easier now.
I love this exhaust. Its like riding a whole new bike!
08 Blue Ninja 250R
Last futzed with by aloh; February 28th, 2010 at 11:46 PM.
aloh is offline   Reply With Quote
Old February 14th, 2010, 02:47 AM   #2
randomwalk101
self wrencher
randomwalk101's Avatar
Take the carb apart and look at the diaphram. Let's hope you didn't rip it. Two washers should be good for stock bike.
Posted via Mobile Device
Old February 14th, 2010, 02:57 AM   #3
aloh
lolwut
aloh's Avatar
Im pretty sure I was careful with the diaphrams... I'll confirm in the morning when I am working on the bike again. I hope I can get it fixed by monday so I can go for a ride..
08 Blue Ninja 250R
Old February 14th, 2010, 04:57 AM   #4
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Make sure all the carb jets are clear. There are ones called pilot jets they are in a tight tube like part of the carb . You will need a thin screwdriver to get at them. They may be clogged if it sat for a while .If they are they will need to be reamed or replaced. They sorta corrode closed. I see it a lot.
Old February 14th, 2010, 11:39 AM   #5
aloh
lolwut
aloh's Avatar
Could I spray/soak them in carb cleaner to get rid of the gunk?
08 Blue Ninja 250R
Old February 14th, 2010, 01:38 PM   #6
randomwalk101
self wrencher
depends..but best to take everything apart and clean it with a little metal wires (your main/pilot jet) and clean it with carb cleaner spraying thing. Gas nowadays has EtOh in it..if you set the tank sit a month or so, deposit will form and hell break loose..bikeshop loves you though
Old February 14th, 2010, 07:55 PM   #7
aloh
lolwut
aloh's Avatar
So I spent alot of today cleaning the jets and tinkering with the idle mixture screws and it seems like it idles much smoother now. I think two washers is a bit much, so I'm going ot try to remove one and see if that helps any.
08 Blue Ninja 250R
Old February 14th, 2010, 08:00 PM   #8
ninja250
You are sleeping
ninja250's Avatar
Motorcycle(s): 2
Sounds like your idle screws aren't adjusted right for sure. Maybe even the idle speed out of whack with the idle mix adjustment too.
Try putting both the idle mixture to 2.5 turns out and see if that helps any. Then adjust idle speed. then synch, then adjust the mixture screws closer from there. Then finally synch again and adjust idle speed again. lol
http://www.ninjette.org/forums/signaturepics/sigpic2121_4.gif <Yeah, it's a 250.
LMFAO!
Weaksauce
ninja250 is offline   Reply With Quote
Old February 14th, 2010, 08:17 PM   #9
aloh
lolwut
aloh's Avatar
Yeah I figured that out today. Im at about 2.25-2.5 turns out. Like i said a little earlier, im gonna try pulling out one of the two shims (Im getting a little backfire on decel if I rev above 5k) and adjust the idle mixtures accordingly.
08 Blue Ninja 250R
Old February 15th, 2010, 12:52 PM   #10
aloh
lolwut
aloh's Avatar
Went out for a test ride, and my low end power is very low. It pulls nice and hard once I get the revs up though.
08 Blue Ninja 250R
Old February 28th, 2010, 11:47 PM   #11
aloh
lolwut
aloh's Avatar
updated first post!
08 Blue Ninja 250R
[roadracingworld.com] - MPT Industries Named "Official Motor Oil" Of New Jersey Motor Ninjette Newsbot Motorcycling News 0 January 19th, 2015 10:40 AM
[sportrider - latest stories] - American Suzuki Motor Corp to become Suzuki Motor of Ninjette Newsbot Motorcycling News 0 March 6th, 2013 02:00 PM
[hell for leather] - Motor cop injured at memorial for motor cop killed in head on co Ninjette Newsbot Motorcycling News 0 June 7th, 2011 12:40 PM
[topix.net] - Motor cop killed in head-on collision with motor cop Ninjette Newsbot Motorcycling News 0 May 28th, 2011 02:30 AM
[hell for leather] - Motor cop killed in head-on collision with motor cop Ninjette Newsbot Motorcycling News 0 May 27th, 2011 02:20 PM
