Old December 7th, 2012, 01:51 PM   #1
akcalhoun
Motorcycle(s): 2013 honda shadow phantom
turn signal help
okay so both my turn signals (front and rear) are 12v 23w but everytime i use my blinker a grinding noise happens where the turn signal relay is (and blink rly fast). do i have to replace the bulbs or could i replace just the turn signal relay? also would i have to replace a fuse or anything else? and would my bikes battery handle this?
reason id rather just replace those parts is because i cannot find a replacement thats 12v 10w.
akcalhoun is offline   Reply With Quote
Old December 7th, 2012, 02:00 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Did you swap out the OEM bulbs for these 23w one? And Now your having this problem?
Old December 7th, 2012, 02:09 PM   #3
akcalhoun
no they are after market turn signals
Old December 8th, 2012, 10:10 AM   #4
akcalhoun
k think if i just get a relay the noise and fast blinking will stop and i believe thats all i need to do
Old December 8th, 2012, 10:46 AM   #5
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
I had a similar issue with my aftermarket signals. It's drawing too much for the thermal relay. Pop down to an auto parts store with your two prong relay and pick up an electric relay. The electric one has the stock sounding click and a steady slow blink.
Only downside will be the lights will continue blinking even if one is burnt out, whereas right now, the one not burnt will come on solid and not blink.
<-- Linky
Old December 9th, 2012, 07:50 AM   #6
akcalhoun
yep that fixed it just put in a new relay and its good now
Old February 18th, 2013, 06:11 AM   #7
hraklos
Motorcycle(s): ninja 250r
hey, which relay did you put?
because mine didn't work!
hraklos is offline   Reply With Quote
Old February 20th, 2013, 06:23 AM   #8
akcalhoun
i used the tridon ep34: http://www.autozone.com/autozone/par...dentifier=6416
u have to ground one of the terminals, more detail here : http://www.ninjette.org/wiki/L.E.D_Lighting
are any of them leds?
Old February 20th, 2013, 04:56 PM   #9
hraklos
i have the front led, and i have a led taillight too.
i also have two resistors on each side. ( 4 in total)
Old February 21st, 2013, 05:03 AM   #10
akcalhoun
should be good to go then with those resistors on, maybe the relay u got was a bad one. try the tridon one i linked just ground the 3rd pin with some wiring and a ring connector.
Old February 21st, 2013, 10:08 AM   #11
hraklos
If I put on resistor on each side will I solve the problem?
Old February 24th, 2013, 09:37 AM   #12
hraklos
guys, i bought this flasher : http://www.ebay.com/itm/170936578711...84.m1439.l2649
i put off all the resistors.
then i put on this relay(it says that it is electronic) but nothing happens. i mean the turn signals wont even turn on. they are "dead"!!!!
what is the problem?? im getting mad with this situation!!!
maybe the flasher isnt right??
please heeeeeelllpppp!!!
Old February 24th, 2013, 09:08 PM   #13
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Did you read the wiki link that akcalhoun posted? Did you ground the E pin by running a ground wire? Even if it's not a Tridon relay, it should still work the same way.
The www.ModMy250.com guy
Old February 25th, 2013, 04:08 AM   #14
hraklos
yes i grounded the E pin by running a ground wire. but nothing happens.
it looks like dead!!
Old February 25th, 2013, 07:23 AM   #15
CThunder-blue
ModMy250.com
Did u turn ur bike on? What did you ground the e pin to? Try grounding the other pin.
Old February 25th, 2013, 03:20 PM   #16
hraklos
i followed the procedure exactly as described above.
and nothing happens.
could you please suggest me an electronic flasher 2 pin that matches with my bike? in ebay please.
i want to buy a flasher that will surely work!!
not 3 pin, but 2 pin , i want it plug n play!
thank you very much!!
Old February 25th, 2013, 03:27 PM   #17
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Plug and play, it what I and many others used http://www.superbrightleds.com/morei...asher/781/835/
Old February 25th, 2013, 03:32 PM   #18
S1att3r
S1att3r's Avatar
Motorcycle(s): White 2013 Ninja 300(Storm), Silver 2003 Fjr1300
Or go to Tri's websight thats where I got mine.
ATGATT
For all I know, women who ride motorcycles are all man-hating dominatrix's.
It was like a mild panic attack!
S1att3r is offline   Reply With Quote
Old February 25th, 2013, 04:04 PM   #19
hraklos
sorry one last question before i buy the item above.
should this work?
1)http://www.patronos.gr/uploads/image...LED%202plo.JPG
2)http://www.moto-rider.com/product-view.aspx?pid=31882 --> is that the same of the one you told me to buy? they look like i think
(because a market near my home sells a relay like this and i prefer to buy it from there so i can fix my motorcycle tomorrow.
if it doesnt fit i will buy the relay above(http://www.superbrightleds.com/morei...asher/781/835/). please your help!!
Old February 25th, 2013, 05:14 PM   #20
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
The second one at least has the same look but with the info being in some other language besides English I can't really tell. The first one has zero info so I have no idea. Take you bike over there with the left side rear fairing removed unplug yours, plug in theirs if it works buy it if not order online. Or take then the specs of the one I sent you to show them what you want.
Old February 25th, 2013, 05:32 PM   #21
hraklos
thats ok. and one last question.
the leds have one yellow cable, and one black/yellow.
ninja 250r has one black and one green.
what goes with what??
and i have 4 led turn signals. should i use any resistor with this: http://www.superbrightleds.com/morei...asher/781/835/
or just plug the flasher?
sorry for so many questions!! thank you for everything!!
Old February 25th, 2013, 05:38 PM   #22
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
I'd say black to black & yellow and yellow to green but you may want to comfirm with the maker of the LEDs which is supposed to go to positive and negive then confirm on the bike the matching polarity with ether the wiring diagram or voltage meter.
Old February 25th, 2013, 05:47 PM   #23
hraklos
because i have 4 led turn signals, should i use any resistor with this: http://www.superbrightleds.com/morei...asher/781/835/
Old February 25th, 2013, 05:56 PM   #24
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
I'm using All LEDs and it works fine, its made to ignore any resistance differences and always blink at the same speed.
Old February 25th, 2013, 06:09 PM   #25
hraklos
ok thank you so much!
Turn signal issue... YMCMB 2008 - 2012 Ninja 250R Tech Talk 8 July 21st, 2012 04:58 PM
Turn signal terminal Avenged7Fold 1986 - 2007 Ninja 250R Tech Talk 4 June 6th, 2012 04:34 PM
will this turn signal work skateboarder1210 2008 - 2012 Ninja 250R Farkles 12 June 29th, 2011 08:52 PM
Turn signal went out, looking for a new turn signal austinm911 2008 - 2012 Ninja 250R Farkles 3 January 23rd, 2011 08:58 PM
