Old May 21st, 2011, 02:01 PM   #1
forevertwowheels
forevertwowheels's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R 2011 Honda CBR600RR
Unhappy Projekt D and DMP alignment
I installed a projekt d fember eliminator and and dmp integrated taillight on my bike but they are not fitting together 100%. There is a gap on the right side and on top between the light and the stock flat black part. I was wondering if anyone else had this problem and how they fixed it. Thanks
Here's a not so great quality pic. ill put a better pic up later if i can.
Projekt D Fender Eliminater / DMP Integrated Taillight / Proton Flushmounts / Area P 18" CF High Mount Race System / Kleen Air System Removed / Airbox Removed / K&N R-0990 / DynoJet Jet Kit
forevertwowheels is offline   Reply With Quote
Old May 23rd, 2011, 11:09 AM   #2
DarC
DUCEATR
DarC's Avatar
Motorcycle(s): RVT1000R
The two piece housing is a pain. I loosened all the bolts and got things aligned, held in place with painters tape as needed and then slowly tightened everything together in place. Once I went with the once piece light housing I didn't have any issues and only had to center the light.
Play with the bushings holding your light and see if you can get the play to help take up and even out the gap.
DarC is offline   Reply With Quote
Alignment off? APEmike 2013 - 2017 Ninja 300 Tech Talk 1 October 14th, 2014 07:32 PM
tire alignment reroka 2008 - 2012 Ninja 250R Tech Talk 7 July 2nd, 2014 05:02 PM
FS: Smith Optics Projekt Sunglasses tfkrocks Miscellaneous 3 September 22nd, 2013 04:13 PM
Wheel alignment? jack_bm 2008 - 2012 Ninja 250R Tech Talk 2 June 1st, 2012 03:56 PM
Projekt D Universal GPS mount for EX250J CZroe 2008 - 2012 Ninja 250R Farkles 8 December 17th, 2009 01:41 AM
