March 18th, 2012, 05:50 AM | #1 |
Join Date: May 2011 Motorcycle(s): 2002 ZZR 250 Posts: 127
Anyone replace a shift shaft seal.
Just curious i anyone has replaced thiers and what was required.
I mean i dont mind topping up oil and having a self lubrcating chain lol but oil Gets all over the garage floor... No good |
March 18th, 2012, 08:18 AM | #2 |
Have not done it for this engine.
If you can see the seal (Kawasaki part 92051) you should be able to pry it out and then reset the new one in place using a piece of pipe to tap it in. Exterior diameter and face are metal covered with a thin layer of neoprene, while the interior diameter is a soft lip of neoprene with an annular ring to put pressure over the shaft. Be careful not to damage that lip for the new seal while sliding it over the shaft. The old seal can be destroyed if needed for removal. Be careful not to damage the surface of the shaft or the crankcase at the seal areas while pulling the old one out. Check this for a reference: http://www.kzrider.com/forum/2-engin...fter-arm-shaft
March 18th, 2012, 08:25 AM | #3 |
Ambrosia.
Join Date: Aug 2011 Motorcycle(s): 1974 Honda CB550K0 W.I.P. Posts: A lot.
I changed the shifter seal on my CB550. Your best bet is to try screwing a screw in it, then pulling it out. It's fairly difficult and will require some muscle. Make sure you tap in the new one evenly.
Life's better on the Mountain. |
March 18th, 2012, 09:32 AM | #4 |
Join Date: Dec 2011 Motorcycle(s): 09Ninja250, Ducati Monster 800ie, Harley FXSTS,Rebel 250,CR144,KX85,RM85L Posts: 142
I have used Mountain Dew's method many times. U usually tape up the shaft, drill a 1/16" hole in the seal. screw in a sheetrock screw and I hook to my slide hammer with a wire. bam and its out.
you must excercise care when drilling the hole, the bit will want to walk. go slow with low pressure and you are golden. alternatively you can split the motor and push out from the inside...
Thanks to: , DUNLOP, WHOOPIE RACING, 995 PAINTWORKS, South Austin Motorcycles |
shift shaft seal | BukkShot | Items Wanted | 4 | March 21st, 2015 10:35 PM |
modified counter shaft cover, GP shift | iZapp | Motorcycle-related | 14 | May 16th, 2014 02:14 PM |
KX250 shift shaft replacement | YamiLionheart | General Motorcycling Discussion | 6 | March 17th, 2013 10:55 AM |
Is this shift shaft damaged? | indr | 2008 - 2012 Ninja 250R Tech Talk | 4 | January 5th, 2013 05:49 AM |
shift shaft oil seal replacement | lolibater | 1986 - 2007 Ninja 250R Tech Talk | 20 | October 10th, 2012 04:22 PM |
