August 29th, 2011, 09:13 PM | #1 |
Join Date: Jul 2011 Motorcycle(s): 2009 Kawasaki Ninja 250R Red Posts: 316
Ninja Dash Cracked
So this happened about a month or 2 ago, but my dash has developed a heat crack in the dash due to this hot southern weather. I was pretty upset and still am as its spreading across my fuel gauge now and water just got in a little after a wash. I was going to just seal it with some clear adhesive glue.... But first I was wondering if this has happened to any of you and if it would be covered under the warranty? I'll get a picture of it tomorrow as it is dark out now
My YouTube Channel |
August 29th, 2011, 09:15 PM | #2 |
Join Date: Aug 2011 Motorcycle(s): 2011 ninja 250 special edition Posts: 54
Is it in direct sunlight during the day ?
August 29th, 2011, 09:18 PM | #3 |
Nope almost always in shade. Happened during mid-day hot ride on the interstate.
August 29th, 2011, 09:20 PM | #4 |
Do you have the stock windscreen or an aftermarket one?
August 29th, 2011, 09:21 PM | #5 |
Stock
August 29th, 2011, 09:21 PM | #6 |
I hate driving...
Join Date: Jul 2010 Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12) Posts: A lot.
Interesting, Mine has sat in 90 degree weather in the sun a few times at work without problems. Warranty might cover it sounds like a defect in workmanship.
09 ninja 2fiddy SE Driving slow things fast |
August 29th, 2011, 09:23 PM | #7 | |
August 29th, 2011, 09:26 PM | #8 |
I hate driving...
I do remember talking to someone whose gauge lens were getting cloudy (didn't seem like condensation) and they got them replaced under warranty. Guess it depends on the people in the dealership as well.
Edit: are you still in warranty? Bike only comes with a 1 year warranty
August 29th, 2011, 09:28 PM | #9 |
Cool. Sometimes aftermarket windscreens can cause surprising hot spots underneath and melt gauges, etc. But if it's happening when things are completely stock, that sure does sound like a defect. The bike may be out of warranty, but I still would share the info with a dealer you have had good luck with, and hope for the best.
August 29th, 2011, 09:31 PM | #10 |
/thread moved to new-gen tech
August 29th, 2011, 09:56 PM | #11 |
step 1. shake fist at flaming ball in the sky
step 2. apply ducttape. step 3. profit.
August 29th, 2011, 10:48 PM | #12 |
Join Date: Aug 2011 Motorcycle(s): '09 Ninja 250R Posts: 260
I've had the same thing happen in the same place to 2 different '09 250R's, both with stock windscreens. On the second bike it happened within a month of getting the bike, I was pissed to say the least.
The crack starts just to the upper left of the fuel gauge on the black plastic, then slowly creeps it's way down into the clear gauge face the more I ride. There's nothing that can be done about it once it's into the clear, because there's no glue out there that won't "craze" the clear plastic and cause it to become opaque white. |
August 30th, 2011, 04:56 AM | #13 |
Join Date: Jul 2011 Motorcycle(s): 2008 Ninja 250r Posts: 784
the opaque white usually just rubs off with paint thinner
August 30th, 2011, 02:34 PM | #14 |
So here is a picture of what I'm talking about.
August 30th, 2011, 02:35 PM | #15 |
I am still under warranty until April 2012
August 30th, 2011, 02:36 PM | #16 |
I'd be pissed. That should definitely be covered under warranty.
August 30th, 2011, 03:09 PM | #17 |
August 30th, 2011, 03:35 PM | #18 |
Clear plastic "crazes" everyplace that the glue would touch it.
Build enough plastic models with model glue or superglue and you learn real quick that it's impossible to get rid of it. Even the thin water-like Testor's glue that flows into seams by itself wouldn't work because of what it would do to the clear plastic. To me this is just one more reason to get the Koso RX-2 and a light smoke PUIG windshield painted Silver underneath. Because if the stock gauges get replaced, it's just going to happen again, and again, and again until something gets changed. |
August 30th, 2011, 04:53 PM | #19 |
Oh wow that's awful. I'll be keeping a close watch on mine.
August 30th, 2011, 06:23 PM | #20 |
I'm taking it to the dealer tomorrow or Monday. I would like to get the Koso gauge but thats really more work than its worth cause I would not be doing the install.
August 30th, 2011, 06:42 PM | #21 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
No, it doesnt unfortunatly. Mine is crazed, and I've tried everything to get it off. It wont come off, mainly because its not something on the lens, its actually etched into the plastic.
Im wondering if that headlight restoration goop stuff would work. |
August 30th, 2011, 06:45 PM | #22 |
I hate driving...
dude that looks like crap, definitely warranty issue.
August 31st, 2011, 01:55 AM | #23 |
Join Date: Jul 2011 Motorcycle(s): '10 Ninja 250r FI Posts: 31
Here in Portugal most of the Kawa dealers gave us 5 years warranty...
August 31st, 2011, 11:06 AM | #24 | |
The only solution is to replace the clear plastic (if that's possible). If it is possible to get the original clear lens out, replace it with some sort of outdoor Lexan or Plexiglass that won't discolor or crack. |
September 1st, 2011, 08:02 AM | #25 | |
Wartown, USA
There is no doubt the dash on the ninja 250R has always been Kawasaki's poorest design element. Has anyone figured out how much, and where to just get a replacement cover? |
September 1st, 2011, 08:06 AM | #26 | |
September 1st, 2011, 08:43 AM | #27 |
Oldie but a goodie
Join Date: Nov 2010 Motorcycle(s): 08 Ninja 650r, 06 SV 650 race, 08 250r race, 03 Buell XB9s, 01 KTM 300 EXC Posts: 131
I have the gauge cluster from an '08 I am selling for $120 shipped if interested.
September 1st, 2011, 09:43 PM | #28 |
September 3rd, 2011, 02:30 PM | #29 |
Any updates?
September 15th, 2011, 09:06 PM | #30 |
Just now had a chance to talk to the dealer today over the phone and he said I would need to bring it by the shop for them to look at it and then send a picture of the problem to Kawasaki directly for them to decide if it will be a warranty issue. A.K.A. they gave me the dealer run around. If it isn't fixed under warranty I will be going to Kawi directly until it is fixed.
September 15th, 2011, 09:07 PM | #31 |
Thank but no thanks. If I have to buy a new gauge cluster I will be purchasing the Koso gauges.
September 15th, 2011, 09:12 PM | #32 | |
I wish my dash was cracked.
September 16th, 2011, 02:25 PM | #33 |
Join Date: Sep 2011 Motorcycle(s): 2008 Kawasaki Ninja 250 *Nikkita* - 2003 Buell XB9R Posts: 274
September 16th, 2011, 04:01 PM | #34 |
ninjaholic
Join Date: Jun 2010 Motorcycle(s): 09' SE 250R (sold), 03' ZX-6R, 99' XL1200C SP Posts: A lot.
Alex, you crack me up... and I second the whole Koso gauge idea... That's what I want to do... but it's just so expensive that I can't do it anytime soon.
Good luck with the dealership and the warranty
09' SE Ninja 250R $2,547.83 worth of mods installed... come on Unregistered, you know you want to know what? Check my Blog "Modification List" |
September 21st, 2011, 07:30 PM | #35 |
I am definitely thinking of just getting the Koso instead of warranty replacement since it may just crack again and I will be keeping my Ninja for quite a while and would love an updated gauge. Anyone know of the best place to get one?
October 8th, 2011, 10:09 PM | #36 |
Considering that the plastic shroud and the clear lens are two different pieces, I suspect that someone hit your bike when you weren't looking or something. It's hard for a crack to spread from one to the other.
Cracked!!! | Adrrrrianna | General Motorcycling Discussion | 2 | July 27th, 2013 03:43 PM |
My Ninja + Custom dash | zzrguy | Pictures | 20 | August 19th, 2011 07:38 AM |
This cracked me up | CThunder-blue | Videos | 16 | August 13th, 2011 10:41 PM |
