Old July 28th, 2015, 03:14 PM   #1
TheJeepGuy
TheJeepGuy's Avatar
Motorcycle(s): TRX 450 R Quad, no street
Help! Slipping clutch??
The bike will take off fine, pulls... okay I guess considering I had been riding a 600 earlier today(can-am quad not streetbike). But the problem lies on the highway. Doing 70 today tucked in like a baby (it was raining) the 250, 2008, with 1300 miles was redlining just to maintain 70. Good thing I rode the bike out in the sticks, because anyone behind me would have run me down going that slow. The bike is in immaculate shape, only has 1300 miles, and is garage kept, so I'm not sure what the problem is other than maybe a slipping clutch or stretched cable. Please advise.
ALSO, cable screw was sticking out about... 3/8 inch of exposed threads. So theres something to consider.
TheJeepGuy is offline   Reply With Quote
Old July 28th, 2015, 03:37 PM   #2
MrAtom
MOTM - July '15
Make sure its adjusted properly.
http://faq.ninja250.org/wiki/Adjusting_the_clutch_cable
Also, if not, its probably just your clutch springs. Replace em with EBC's. They're good stuff.
Old July 28th, 2015, 03:54 PM   #3
TheJeepGuy
TheJeepGuy's Avatar
So no worries?
Let me pose this question then, knowing multiple friends are excellent mechanics, would you buy a Ninjette with 1300 miles and this single issue? and assuming its clean clean chain, no grease etc. (no drop evidence) what would you say is a fair price?
Old July 28th, 2015, 05:07 PM   #4
100% sure you were in 6th gear?
Old July 28th, 2015, 05:37 PM   #5
TheJeepGuy
TheJeepGuy's Avatar
100% absolutely positive.
I often check when riding just because as a track guy, when you call on the power that's not in whatever gear.. its a let down.
Old July 28th, 2015, 06:59 PM   #6
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Any chance the clutch cable needs to be adjusted?
Old July 28th, 2015, 08:13 PM   #7
TheJeepGuy
TheJeepGuy's Avatar
It's a possibility. I only had a few min today. And I always go over a buy twice. You're always excited the first time. So I'll be back looking over it Saturday.
Old July 28th, 2015, 08:51 PM   #8
Floki
Motorcycle Nurse?
Floki's Avatar
Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100
stock gearing?
Floki is offline   Reply With Quote
Old July 28th, 2015, 09:09 PM   #9
TheJeepGuy
TheJeepGuy's Avatar
Bike is bone stock. Even the front tire is stock.
Old July 28th, 2015, 09:13 PM   #10
/moved to new-gen tech
Old July 28th, 2015, 11:25 PM   #11
Ghostt
Ghostt's Avatar
Assuming the clutch cable is properly adjusted, it could be the wrong kind of oil causing the slippage, the bike uses a wet clutch, so if the oil is not the proper kind, could cause slippage.
Some oils contain additives that while work for car engines to be super slippery, are a no-no for wet clutch, any 10w-40 to 20w50 rated JASO-MA/MA2 oil will do just fine. Shell Rotella synthetic is safe, and popular choice.
Personally I'd change the clutch springs themselves now, as they are the weak link in the clutch set-up, the clutch itself is more than capable, Kawasaki used it on the bigger bikes like ZX1000 etc.. it's the springs you need to change, this should be on the list of must have IMHO.
Upgrading to performance clutch springs by Ghostt
Choosing Clutch Springs
Barnett aftermarket clutch springs for a 1985-1989 ZX-600, Part # 501-50-05055. You can view them online at the Barnett catalog, here: http://www.barnettclutches.com/produ...&clutch_cc=600 They can be ordered through your local dealership, or at a number of online sources. Here is one such online catalog: http://www.exoticsportbike.com/6001.htm
Another option is the EBC CSK10 (see http://www.ebcbrakes.com/motorcycle_..._springs.shtml). This kit isn't quite as stiff as the Barnett, but is better than stock and usually a little cheaper. The kit does include six springs, while the ninja 250 only uses four.
Category: Clutch & Transmission
Below you can see the difference between the stock(yellow stripe) vs hd springs(red stripe) themselves, they are thicker, and a little bit longer. And no need to worry about it making the clutch too stiff, remember the Ninjette only uses 4 not 6, even more of a reason to upgrade to better springs.
I have done this on both my EX500 and Ninjette bikes.
violente et ignorantia
ZX-2R BLOG
Old August 2nd, 2015, 08:33 PM   #12
TheJeepGuy
TheJeepGuy's Avatar
Update:
Threaded the cable in about 2 turns and the rpms were stable and the bike managed to muster about 80 before I couldn't see anymore. Should have worn my goggles instead of my glasses. Lesson learned.
Old August 2nd, 2015, 11:54 PM   #13
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
The cable should have a few mm of free play before feeling any tension. Is that how you adjusted it? I assume you rotated it clockwise (to loosen the cable a bit)?
Riding it like I financed it.
How to tell if your clutch is slipping? Hero Danny 2008 - 2012 Ninja 250R Tech Talk 29 July 29th, 2014 09:13 AM
Slipping clutch The_big_dill 1986 - 2007 Ninja 250R Tech Talk 11 July 29th, 2013 05:43 PM
{HELP} Clutch Slipping sprtonyy 2008 - 2012 Ninja 250R Tech Talk 20 April 21st, 2010 05:42 PM
Clutch slipping? and lube? :D kyle98927 2008 - 2012 Ninja 250R Tech Talk 7 October 20th, 2009 09:32 AM
back tire slipping/clutch slipping???? help? richierich781 2008 - 2012 Ninja 250R Tech Talk 17 June 19th, 2009 07:13 AM
