Old August 7th, 2013, 05:47 PM   #1
rweyerts
Motorcycle(s): Honda
LED stop, Brake and Running lights
I have some questions about some light issue.
What I'm trying to build is a String of 7 red LED's on each of my saddle bag.
How can I run all 7 LED's to do all 3 functions(Turn, Running and Break). I have done a lot of looking online but most of it is way above my head. I was hopping that someone out there can help me with this problem. I have a BASIC knowledge of how to wire a single LED to make it work..
Thanks
rweyerts is offline   Reply With Quote
Old August 7th, 2013, 06:33 PM   #2
beazy411
beazy411's Avatar
Motorcycle(s): 2013 Ninja 300
I am just going to talk about one side, since the other one would be the same, and in general terms too since I am a bit rusty.
In order to have one string do both tasks, you will either have to have a constant power and tap into the grounds on both brake and turn-signal or tap into the power on each and have a constant ground.
I would suggest tapping into the power on each one with a constant ground, making sure to solder everything and use heat shrink to seal it all up. When making the splices, leave plenty of room away from the light you are stealing power from and splice the new wire into it, again making sure to use solder and not vampire clips.
Maybe someone else on here can be a little more specific for you. This can be done, it will just take some time, patience and maybe a second set of eyes.
~B.
beazy411 is offline   Reply With Quote
Wiring LED strips as brake lights, turn signals, and "day-time lights" blackninja18 2008 - 2012 Ninja 250R Farkles 32 August 7th, 2013 03:41 PM
Looking to improve visibility (LED running lights) headshrink 2008 - 2012 Ninja 250R Farkles 16 December 5th, 2011 12:15 AM
[webbikeworld.com] - PIAA LED Running Lights Ninjette Newsbot Motorcycling News 0 September 22nd, 2008 08:04 PM
